Local Time 18:39 24 Oct 2026 Privacy Policy
Forum Index : Windmills
  Topics Started By Replies Views
Last Post By
Sticky Topics
Forum upgrade Gizmo, 05/07/2019 314 365834 wiseguy  04:07am 12 Dec 2025
Forum Guidelines Gizmo, 11/12/2011 2 534880   02:49pm 16 Dec 2015
Normal Topics
   Page 5 of 99
Why Not In Reverse? Kamak, 05/05/2021 3 5992 Kamak  03:58am 06 May 2021
Swapping out the stock magnets? Kamak, 14/04/2021 17 7897 Kamak  03:48am 06 May 2021
Has Anyone Ever Figured It Out? Kamak, 21/04/2021 1 6117 kitestrings  12:32am 04 May 2021
So, how would you go about removing the stock magnets from the rotor? Kamak, 23/04/2021 2 6087 Kamak  12:36am 27 Apr 2021
Made to be High Voltage Low Current Kamak, 25/04/2021 5 7395 Kamak  03:59am 25 Apr 2021
Importance of Balanced Load on Phases on Wind Turbines? Technophiliac, 21/04/2021 4 7062 Kamak  05:30pm 22 Apr 2021
Motor Winding Wire Gauge Sizing as per Good rule of Thumb Approach Kamak, 21/04/2021 0 6867 Kamak  05:22am 21 Apr 2021
3PH rectification? Delta or Star/Wye Configuration? Kamak, 21/04/2021 0 5626 Kamak  06:12pm 20 Apr 2021
This Thread Needs a Newcomers Introductory Glossary of Terms Kamak, 14/04/2021 1 5621 Butcher  07:47am 20 Apr 2021
F&P stator coil count Gizmo, 05/02/2021 7 6951 Butcher  06:19am 20 Apr 2021
The Story of Makani Kamak, 20/04/2021 2 5608 Kamak  08:27pm 19 Apr 2021
Skystream 3.7 Mods! Ozark Wind, 27/01/2021 1 9112 Kamak  08:43pm 17 Apr 2021
The other Brands 3 Phase Induction Motors? Kamak, 14/04/2021 16 5793 Kamak  02:24pm 16 Apr 2021
Small Vertical Axis Wind Turbine Solar Mike, 14/04/2021 12 6019 Davo99  07:09am 16 Apr 2021
The Permanent Magnetic Pole Magnetic Flux Density? Kamak, 14/04/2021 0 5234 Kamak  12:13am 14 Apr 2021
Gilco mgilb, 14/08/2020 4 6809 brucedownunder2  12:06am 26 Feb 2021
Chinese Wind Turbines on eBay. Chinese Rubbish, 26/07/2020 14 8785 pollenface  03:18am 25 Jan 2021
Memories brucedownunder2, 03/01/2021 3 5784 Clockmanfr  06:06pm 19 Jan 2021
Few starting out questions BarkyJ, 26/04/2018 80 55575 get real  03:01am 31 Dec 2020
Hook an F&P up to a battery? get real, 28/12/2020 1 5594 Technophiliac  09:46am 28 Dec 2020
A bearing assembly Storm, 13/10/2005 3 8185 get real  03:54am 28 Dec 2020
Diodes on star centre connection Gizmo, 05/06/2017 46 63252 get real  02:35am 28 Dec 2020
Variable Dump Load - Oil Heater with 3 phase element? Technophiliac, 20/12/2020 3 5341 Warpspeed  01:09am 21 Dec 2020
F&P 42 pole 0.8mm copper from 9Kg Washing Machine - 25 cm diameter Technophiliac, 19/12/2020 1 5505 Warpspeed  05:01am 19 Dec 2020
Dump load control pollenface, 21/10/2020 2 5959 pollenface  03:30am 11 Dec 2020
= New posts since you last visited .
   Page 5 of 99
