Local Time 19:18 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Chinese Wind Turbines on eBay.
Chinese Rubbish
Posted: 12:04pm 26 Jul 2020
Hi guys, I'm new to the whole wind turbine scene, so please bear with me.
I am at present camping my way around Australia in a caravan and was thinking about getting one of these
I don't for one minute believe one of these Chinese turbines would produce anywhere near what they claim, but I'd be happy with 300w+ for the price.
I want to charge a 12v 120ah battery, so my question is; do I get a 12v one and it'll have to run a higher rpm to make 300w or should I get 24v one and it runs slower but makes more power at a lower rpm?
I know it sounds like a stupid question, but surely there's a method in my madness...or I could just buy the Eco-Worthy  400w turbine for 3x the price, but maybe a more reliable product?
What's your thoughts?
Anything helpful would be greatly received.
Thanks,
Paddy.
Warpspeed
Posted: 01:42am 27 Jul 2020
Welcome to the Forum Paddy.
I suppose it depends how much wind you are seeing in your travels, location is everything.
It would be brilliant on a yacht out at sea, or along the top of coastal cliffs.
Not so great camped out in the bush among very tall trees, obviously.
Full ratings 11.4 metres/sec (41.4 Kmh) you would be lucky to be able to stand up in that.
Then there is the problem of carting the whole thing around, plus a pole long enough to mount it on around with you in your wanderings.
Cheers,  Tony.
Chinese Rubbish
Posted: 03:17am 27 Jul 2020
Hi Tony, thanks for the welcome.
I'm seeing a fair bit of wind as we camp on campgrounds on the coast, most days according to BOM the wind is somewhere between 15 and 30kph.
The pole will be in 2 x 2metre sections so I can fit it in the front locker of the caravan, the blades unbolt and I can put the whole thing back in its box, in the back of the car for traveling to other destinations.
I guess if it doesn't work out as I envisage, I could always sell it I guess.
Cheers,
Paddy.
Edited 2020-07-27 13:20 by Chinese Rubbish
Warpspeed
Posted: 03:25am 27 Jul 2020
That is quite a bit of wind, and at this time of year, might well be worth a try.
Cheers,  Tony.
Chinese Rubbish
Posted: 04:15am 27 Jul 2020
I'm still trying to weigh up which model, and which will last in our conditions, I guess they're all made in the same factory.
I've been looking on YouTube, but not many of the cheap Chinese Rubbish ones on there - a couple in America.....hmmm!! decisions decisions.
Warpspeed
Posted: 05:41am 27 Jul 2020
I have not been looking, but some of the feedback on e-bay can sometimes be quite useful.
Cheers,  Tony.
Chinese Rubbish
Posted: 05:55am 27 Jul 2020
Should I get the 24v model of the cheaper one,this will have a lower cut in speed for less windy days?
Turbine
Warpspeed
Posted: 07:01am 27 Jul 2020
Using a 24v controller regulator with a 12v battery may be tempting fate a bit.
It may also possibly load down the turbine to the point of blade stall if the control system is really primitive.
Don't really know, but there may even be a small microprocessor in there, and attempting to fool it may not produce the improved results you expect or hope for.
Cheers,  Tony.
Chinese Rubbish
Posted: 03:02am 28 Jul 2020
Ok no worries, thank you.
pollenface
Posted: 01:42am 09 Sep 2020
I just bought the cheapest 12/24v 400w turbine on ebay. It comes with a controller but I plan to use only a 3-phase rectifier and old car battery to function as a "service battery" for the turbine system.
I plan to use a vsr + 200w boost converter @ 55v to supply additional current to one of my mppt solar controllers (I only have 250w of headroom left) between 13.3-12.8v and another vsr to run a 12v/200w water heater between 15-14.5v.
My logic is probably flawed and I'm still learning so I'll let you know how it goes.
Off grid man caver
Chinese Rubbish
Posted: 09:33pm 15 Dec 2020
Hi pollenface,
How did your turbine experiment turn out?
Technophiliac
Posted: 07:27am 27 Dec 2020
To me the considerations are whether to go for a 5 bladed propeller - smaller, readily available, and maybe better in the winds you are expecting. Lastly for a short cable run with a 12V battery....go 12 volts and keep it simple!
Probably too late commenting for the original poster, but may be helpful considerations for some one else?
pollenface
Posted: 12:17am 18 Jan 2021
  Chinese Rubbish said  Hi pollenface,
Hi mate, I'm still experimenting and my wife is getting sick of me always hanging about in my shed.
I didn't get much joy from the included PWM charge controller, I think it loaded the turbine too much and made it refuse to spin. I bought a BOOST type from ebay which seems to let the turbine spin up a bit more. It does work but I don't see constant wind where I live so best I've seen is 225w for about 2seconds. It has a built in brake which comes on/off at 28.7v. I'm going to try going straight through a bridge rectifier and make my own brake to come on at 27.5v as it doesn't need to spin when the sun is up and I prefer the idea of a brake on the AC side instead of a dump load (less complication). It will still spin slowly with the brake on in heavy wind but won't whirl it's head off (unless you're in a hurricane) or produce any power.
I'll check back later.
Off grid man caver
Old_Dunlite
Posted: 02:33am 25 Jan 2021
I think for your application you'd be better off with solar panels. Of course I see the appeal in trying out a wind turbine. Solar is so cheap and effective.
pollenface
Posted: 03:18am 25 Jan 2021
post deleted
Edited 2021-01-25 13:21 by pollenface
Off grid man caver
