Local Time 19:18 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Swapping out the stock magnets?
Kamak
Posted: 10:24pm 13 Apr 2021
Has anyone ever swapped out the stock magnets for a stronger Neodynium type? This could definitely be done. For example, my Samsung unit has 4 mag poles per brick, with a 36 pole stator ( probably helps with decogging, 3 coils per 4 pole of magnets). Each pole is approx 30mm long x 18mm wide x 5mm thick. I can find 25mm long x 15mm wide x 5mm thick Neodynium N35 magnets. What would be the results if I could replace the stock mags with these epoxied in place?
Kamak
Posted: 04:08pm 17 Apr 2021
  Matt Lyons said  <P>Hi Chris,</P>
<P>The earlier ones I made used 12mm wide magnets which were too powerful and yes tended to warp the rotor.</P>
<P>The new design uses 8mm wide magnets at 6mm deep and 36mm long which has less pull on the rotor. And plenty of power.</P>
<P>The one I have been testing so far is fine, but I am still looking into ways of strengthening the rotor or as other people have mentioned, build an alloy/steel one.</P>
<P>In my testing, one converted Neo rotor has distinctly more power than two standard ferrite rotors on the same shaft.</P>
<P>I could get 35-40Amps @14V with two standard motors on the same shaft, which I was happy with, now I get over 50A with one Neo rotor.</P>
<P>The possibilities are endless, maybe 10mm deep magnets on a steel rotor.</P>
<P>Matt Lyons.</P>
Wow OK, so going way way back to the beginning days here (2005) Matt Lyons did just this. This is really cool. I wonder about using the Asian rotors which ARE metal and with a change out of wire to copper with a well spec'd gauge, what that might produce.
Kamak
Posted: 05:05pm 17 Apr 2021
I have yet to read through every Neodynium magnet conversion/test (the Neo conversion) threads here, but it does seem to be that it kind of faded away into obscurity, either because it's a lot of work/expense and/or little use or practicality to the Wind Turbine usages.
I do want to play around with this design idea.
I see a few issues, from what I've gathered and from what I know.
Magnetic saturation of the stator issues
Magnetic Hysteresis within the stator steel laminations
Spacing between the magnetic switchings NSN, S N S, N  S  N.....etc of the rotor, as a result of the enlarged magnetic flux field around each pole piece.
Coil wire diameter - current load and heat dissipation.
Electromagnet torque - cogging
And not to forget to mention the mechanical difficulty in assembling the rotor onto and off of the stator, due to the extreme increase in magnetic interaction.
Edited 2021-04-18 04:54 by Kamak
Kamak
Posted: 07:02pm 17 Apr 2021
It sure will help everyone that is interested in this conversion idea, if we start with well documented data. The magnetic flux density of the magnets used. The RPM/Voltage curve. RPM/Current curve, The inductance of the coils groups, The resistance of the coil groups, Copper wire diameter, the number of turns per coil, the number of magnets vs the number of coil poles.
Edited 2021-04-19 02:17 by Kamak
Kamak
Posted: 04:27pm 18 Apr 2021
The most important design consideration (the most obvious and undocumented) when rebuilding the rotor with new magnets, is that all the coil/poles within any one phase leg see the exact same magnetic polarity (and transition from/to +-, polarity phase change), at the exact same time. This is where hysteresis, magnet spacing, and speed of rotation should get consideration.
Kamak
Posted: 07:36pm 18 Apr 2021
Stock Samsung P/N: 09CA49132 Stator
900mm ID. Mag ring
75mm W x 35mm L x 5mm Thk mag bricks
12 mag bricks
4 poles per mag brick NSNS
75mm/4 = 18.75mm W magnets
35mm L x 18.75mm W x 5mm Thk per mag pole
48 mag poles @ 7.5deg per pole, 15deg per "like" polarity
Stock mag flux density = approx 1750/1800 Gauss
36 coil poles = 360deg/36 = 10deg per coil pole
3 phase winding XYZ = 30deg per "common" phase winding
15deg per mag pole of "like" magnet polarity
therefore the "like" magnetic pole polarities (and transitions thereof) will always aline with the "common" coil windings throughout rotation, as 15deg is an even common denominator of 30deg.
Edited 2021-04-19 06:08 by Kamak
Kamak
Posted: 10:36pm 18 Apr 2021
https://www.thebackshed.com/forum/ViewTopic.php?FID=2&TID=22
Kamak
Posted: 11:02pm 18 Apr 2021
15deg of arc per mag pole(centerline) of "like" magnet polarity
  3.75deg+     7.5deg     +3.75deg
N              |          S          |             N = 15deg C|C
N|S|N|S @ 30deg of arc per mag brick
Increasing the magnetic strength (N35, N50) of each magnetic pole piece with Neo types and the width of each magnet piece, will increase the flux field width around each pole piece, which will require increasing the spacing between each pole piece. Even if each new magnet was the exact same dimensions (18.75 mm x 35mm x 5mm) it would most likely still require a greater spacing between centerlines. Decreasing the width of each magnet while maintaining a greater flux density could help maintain the stock spacing. This will all require some good ol trial and error bench testing.
5mm cube N40 magnets can be acquired. This will allow for quick and uniformly placed and changed out magnetic pole widths and spacings.
|5|5|
|5|5|
|5|5|
|5|5|   10 x 35
|5|5|
|5|5|
|5|5|
|5|5|5|
|5|5|5|
|5|5|5|
|5|5|5|   15 x 35
|5|5|5|
|5|5|5|
|5|5|5|
Kamak
Posted: 11:26pm 18 Apr 2021
|----------30deg of Arc---------|
|--------------75mm--------------|
|5|5|5|5|5|5|5|5|5|5|5|5|5|5|5|
    N               S                N
|5|5|5|        |5|5|5|        |5|5|5|
|6deg|6deg|6deg|6deg|6deg|
|  3   |6deg|6deg|6deg|  3  |
This scheme does not work
C|C (center to center) of like poles is:
3deg + 6deg + 6deg + 6deg + 3deg = 24deg
The magnetic poles would be misaligned with the common phase winding-core pole
30 deg is not evenly divisible by 24
With the stator core poles @ 30deg C|C the rotor mag poles of the same polarity must be either 15, 30, 60 or 120deg C|C.
I'm not 1000% sure about this right now.
Edited 2021-04-19 11:22 by Kamak
Kamak
Posted: 01:38am 19 Apr 2021
|----------30deg of Arc----------|
|--------------75mm--------------|--------------75mm--------------|
|5|5|5|5|5|5|5|5|5|5|5|5|5|5|5|5|5|5|
    N                  S                     N
|6deg|  6deg  |6deg |   6deg| 6deg|
Edited 2021-04-19 11:43 by Kamak
Kamak
Posted: 02:01am 19 Apr 2021
https://www.thebackshed.com/forum/ViewTopic.php?FID=2&TID=328
brucedownunder2
Posted: 02:24am 19 Apr 2021
Hi Kamak.
 Maybe I'm not rearing all your posting ,,  but you say the outside diameter of your rotor is 900 mm ??
Am I wrong ?.
I thought they (Fisher and Paykel ) rotors are around 240 mm or a bit larger.  (I would have to dig one out from my F&P box of tricks).
I've ,many years ago , fitted Neo"s to the rotors , fairly easy, lots of small 25mm X 5mm X 3mm (I think). made a big difference. Can"t remember the figures now ,as most of us have gone SOLAR .  I've still got heaps of F&P stuff ,one day I might drag it out and hoist a mill om my tower. (sort of gone solar , now days. had lots of fun years ago , but I'm a Museum old fart nowadays, so playing with towers and winches is sort of ,,, memories !!.
I wish you fun
Bruce
Bushboy
Kamak
Posted: 02:43am 19 Apr 2021
Yeah, My bad! this is a Samsung rotor. The diameter that I am referring to is the inner circumference of the rotor where the magnets are glued to, 900mm in this case. Sorry about that. I sure wish I could go back in these threads and make corrections. Seems that you can only make corrections to the last post as long as no one else has posted after you. No biggy, I will correct when and where I can, and with follow-ups.
Kamak
Posted: 03:06am 19 Apr 2021
900mm [Internal Circumference]. Mag ring
12 mag bricks
Mod (experimant)
|-----------30deg of Arc---------|
|-------------75mm---------------|-------------75mm-------------|
|5|5|5|5|5|5|5|5|5|5|5|5|5|5|5|    5mm = 2deg arc
   N                  S                     N
|6deg |  9deg |6deg|  9deg   |
Edited 2021-04-19 13:19 by Kamak
Kamak
Posted: 03:34am 19 Apr 2021
Kamak
Posted: 03:49am 19 Apr 2021
Stock magnet B = 1800 Gauss (as measured with Gaussmeter)
Vs
Material: Sintered NdFeB. Grade N42
Gauss Rating B: 13,200 Gauss (Not measured, but listed strength)
5mmx5mmx5mm (used = 35mm x 10mm x 5mm, N=7 x 2 x 1=14 magnets)
13,200/1800 = 7.3x increase
Does anyone here remember what the Neo Mag strength that is/was used on a successfully rebuilt F&P gen that actually produced as a wind turbine? Spacing, dimensions....etc
Edited 2021-04-20 00:51 by Kamak
Kamak
Posted: 06:15pm 03 May 2021
I would love to go through all the Windmill threads and find all the best related posts referring to Neo conversions, and the end results from them. The ones I've found so far, all seem to fade away with not much follow-up on success, and/or the succession of results between related threads don't seem to build off one another, in any concise way. It seems that the conversion might be a great power output inhancer, yet not suitable for successful wind turbine production. I have yet to find any conversions related to the other Asian-built washing machine DD BLDC motors, ie Samsung, LG...The ones that have drawn pressed metal rotors.
From 2008,
http://www.thebackshed.com/forum/ViewTopic.php?FID=2&TID=920
http://www.thebackshed.com/forum/ViewTopic.php?FID=2&TID=1038#7926
http://www.thebackshed.com/forum/ViewTopic.php?TID=1367
Edited 2021-05-05 08:35 by Kamak
Kamak
Posted: 03:48am 06 May 2021
Custom made Neo magnets from China
