Local Time 08:58 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Candidate transformers for Tverter
LadyN
Posted: 07:22pm 07 Feb 2019
Candidate transformers for Tverter (TonyInverter)
Warpspeed, you should really christen the Tverter or TonyInverter or WarpInverter or Warpverter or ...
Please, it will makes things so easy. I am sure naming OzInverter was they key to its success! Everything was just a cakewalk from there.
OK, so for people COMPLETELY unskilled in building transformers from scratch for the Tverter, we need to start somewhere.
This thread will capture the requirements for good candidate transformers for Tverter
To start off:
1. Will toroidal cores do just fine?
2. Why choose an EI over a toroidal core?
3. What changes in design would we have to do to the Tverter if we chose a toroidal core for the guts of the Tverter?
4. What are some good resources to get started with sourcing, building and testing transformers for Tverter?
Posted: 02:57pm 06 Apr 2019
bump
I'll try:
1. yes
2. EI are easier to wind but nothing like as suitable for the higher power parts as toroids
Sorry if I got anything wrong.
Clockmanfr
Posted: 04:13pm 06 Apr 2019
'WarpStepInverter'
2019-04-07_021303_WarpstepInverter1to5.pdf
2019-04-07_021323_WarpStepInverter6.pdf
Warpspeed
Posted: 11:15pm 06 Apr 2019
Exactly as John says, toroidal cores are better electrically, but require vastly more time and physical effort to wind.
My situation is that I had nothing here at all that I could use, either for the large toroidal cores, or wire of appropriate gauges. And I am becoming increasingly lazy in my old age.
And I also have a lifelong friend that runs a transformer winding business nearby.
So my solution was to get him to do the whole thing for me, although it was still a rather expensive exercise just for the cost of the materials.
Cheers,  Tony.
LadyN
Posted: 05:52pm 08 Apr 2019
Are there some comprehensive (toroid) transformer winding videos or guides to follow?
I have never done this before and am scared with the unknowns.
renewableMark
Posted: 09:51pm 08 Apr 2019
  LadyN said   Are there some comprehensive (toroid) transformer winding videos or guides to follow?
Here is something from Oz.
Cheers Caveman Mark
Off grid eastern Melb
LadyN
Posted: 09:57pm 08 Apr 2019
YES MARK! YES!
Looks great! I will be studying this all week! WOOOHOO!
Can you believe it, I'm on that forum and have been going through the many pages but never found this post
THANK YOU!
Warpspeed
Posted: 11:31pm 08 Apr 2019
I missed that one too, its an absolute ripper.............
One technique that has been modified since then, is the now preferred method to straighten the wire.
Every time copper wire is handled it tends to work harden, so the fewer times it is bent and unbent the easier it becomes to work with.
The multiple roller straightening technique certainly works, but a more gentle way is to just stretch the wire.
Anchor one end to an immovable object, and just stretch the wire. Perhaps about six to eight inches for a fifty foot length. You will feel it stretch, and it will not spring back, and all the ripples in the wire will straighten right out.
Cheers,  Tony.
tinyt
Posted: 11:57pm 08 Apr 2019
Did the wire stetch from a post of the back side of the house to a temporary post at the end of the front driveway. I used a chain link fence puller and it works. Just make sure the wire does not rub on the cement surface and scrape it’s enamel. Lost some wires before I realized it.
renewableMark
Posted: 12:24am 09 Apr 2019
even after a stretch it is never totally kink free. I use a wet leather glove and run it along the wire between my fingers and thumb, with them at an agle offsett to each other. That does work harden it a bit but not as bad as rollers.
Cheers Caveman Mark
nickskethisniks
Posted: 09:54am 07 May 2019
Does someone know wich transformers are used in the diehl platinum 2100-4600s grid inverters? If they have the iron silicon steel toroidal transformers I can buy a few to dismantle them...
BenandAmber
Posted: 06:23pm 07 May 2019
LadyN
I have wire stretched out right now in my yard
I tied it to the van my wife crashed and tied the other side to the hitch of her new used van
the wire was a little bit sketchy so I brought 3. 15 Oz cans of wire enamel paint and repainted it also
I stretch the wires one at a time
Then tied them off to anything heavy enough I could find including police car four wheeler milk crate with a bag of sand in it
Anything heavy enough to keep it off the ground so I can paint it
That's my youngest Sun (Zahyia) in that one pic he likes to do anything I'm doing and he is awesome at helping
He has his own toolbox and own tools and he can already take just about anything apart without my helpEdited by BenandAmber 2019-05-09
BenandAmber
Posted: 06:39pm 07 May 2019
Yes for all of you that may be wondering I do have a junk car in my front yard I am from West Virginia what do you expect LOL
