Local Time 09:34 25 Oct 2026 Privacy Policy
Forum Index : Electronics : MAD/OZ AC/DC Charge Controller
     Page 9 of 9
Posted: 05:46am 26 Apr 2019
Working on some updates for the code, been busy recently but now have some time available. One update I need to get done is the current limiting, Mark has been waiting patiently for a long time for that.
Mark has also had buzzing problems when the regulator is at 50% or less. Inserting the following line
"TCCR0B = TCCR0B & B11111000 | B00000010; // for PWM frequency of 7812.50 Hz"
After void setup as per below.
void setup() {
This will multiply the PWM frequency by 8 from the present 976.56 Hz.
@noneyabussiness I never got to the bottom of why the 2 channels linked together caused the MOSFETs to short but separating them has worked flawlessly since December 2017 so I have not wasted any more time on it. I am reluctant to link the 2 channels together in the GTI as that is how it was in the regulator.
If have 1 working and 2 fualty Aroura's they have an internal problem that causes it to show low resistance to ground error. If you have a fix for it I am all ears.
     Page 9 of 9
