Local Time 09:11 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA/WebMite V5.07.07 release candidates
     Page 8 of 13
Posted: 06:02pm 25 Apr 2023
  matherp said  I've updated the download - no version change
Great, that works, and thanks for fixing the other niggles too.
I'll see if I can find you some more later / in the morning.
Have a good evening,
Posted: 07:49pm 25 Apr 2023
Here is a nice MEMORY COPY bug:
Option Base 0
Option Default None
Option Explicit On
Const BASE% = 0
Dim counter% = 0
test_copy_given_overlap()
Sub test_copy_given_overlap()
 Local buf%(array.new%(4)) ' 32-bytes
 Local pbuf% = Peek(VarAddr buf%())
 buf%(BASE%)     = &h0
 buf%(BASE% + 1) = &hFF01020304050607
 buf%(BASE% + 2) = &h08090A0B0C0D0E0F
 buf%(BASE% + 3) = &h0
 assert_hex_equals(0, Peek(Integer pbuf%))
 assert_hex_equals(&hFF01020304050607, Peek(Integer pbuf% + 8))
 assert_hex_equals(&h08090A0B0C0D0E0F, Peek(Integer pbuf% + 16))
 assert_hex_equals(0, Peek(Integer pbuf% + 24))
 ' Copy onto itself.
 Memory Copy pbuf%, pbuf%, 32
 buf%(BASE%)     = &h0
 ' Copy where pdst < psrc.
 Memory Copy pbuf% + 8, pbuf% + 5, 16
 assert_hex_equals(&h0506070000000000, Peek(Integer pbuf%))
 assert_hex_equals(&h0D0E0FFF01020304, Peek(Integer pbuf% + 8))
 assert_hex_equals(&h08090A08090A0B0C, Peek(Integer pbuf% + 16))
 assert_hex_equals(&h0,                Peek(Integer pbuf% + 24))
 buf%(BASE%)     = &h0
 If Mm.Device$ = "MMB4L" Then
   ' Copy where pdst > psrc.
   ' Colour Maximite 2 doesn't handle this correctly.
   Memory Copy pbuf% + 8, pbuf% + 11, 16
   assert_hex_equals(&h0,                Peek(Integer pbuf%))
   assert_hex_equals(&h0304050607050607, Peek(Integer pbuf% + 8))
   assert_hex_equals(&h0B0C0D0E0FFF0102, Peek(Integer pbuf% + 16))
   assert_hex_equals(&h000000000008090A, Peek(Integer pbuf% + 24))
Function array.new%(capacity%)
 array.new% = capacity% + Mm.Info(Option Base) - 1
End Function
Sub assert_hex_equals(expected%, actual%, chars%)
 Inc counter%
 Print "[" + Str$(counter%) + "] ";
 If expected% <> actual% Then
   Local s$
   Cat s$, "Assert equals failed, expected &h"
   Cat s$, Hex$(expected%, chars%)
   Cat s$, " but actually &h"
   Cat s$, Hex$(actual%, chars%)
   Print s$
 Else
   Print "OK"
Which currently outputs:
[1] OK
[2] OK
[3] OK
[4] OK
[5] OK
[6] OK
[7] OK
[8] OK
[9] Assert equals failed, expected &h506070000000000 but actually &h90A080000000000
[10] Assert equals failed, expected &hD0E0FFF01020304 but actually &hA08090A08090A08
[11] Assert equals failed, expected &h8090A08090A0B0C but actually &h8090A08090A0809
[12] OK
The problems is where pdst < psrc. The CMM2, MMB4W and MMB4L all get this correct.
For *bonus points* get pdst > psrc working too, it doesn't on the CMM2 (not sure about MMB4W). I haven't looked at the C code but *may* be as simple as taking the slight performance hit and using memmove() instead of memcpy().
Posted: 09:22pm 25 Apr 2023
  Quote  Here is a nice MEMORY COPY bug:
Fixed including tests 13-16. Will include in next RC
Posted: 09:58am 26 Apr 2023
It looks like there is a fragment of debug code in Mm.Info(FileSize file$) for drive B:
> drive "a:"
> ? Mm.Info(FileSize "bootcount")
4
> drive "b:"
> ? Mm.Info(FileSize "tst_inc.bas")
/tst_inc.bas    <===== *** This should not be here ***
605
Posted: 10:21am 26 Apr 2023
I *think/hope* this (on A: and B:) may be the last of it for the PicoMite:
Option Base 0
Option Default None
Option Explicit On
' Setup a test file.
Dim f$ = "test_file.txt"
Open f$ For Output As #1
Print #1, "Hello World";
Close #1
Open f$ For Append As #1
If Eof(#1) <> 1 Then ? "[1] FAIL" Else ? "[1] OK"
? Loc(#1)
' Should start with r/w pointer one past the end.
If Loc(#1) <> 12 Then ? "[2] FAIL" Else ? "[2] OK"
Close #1
Open f$ For Random As #1
If Eof(#1) <> 1 Then ? "[3] FAIL" Else ? "[3] OK"
If Loc(#1) <> 12 Then ? "[4] FAIL" Else ? "[4] OK"
Close #1
Assuming you are happy to make these changes then I'd appreciate a new RC (8?) for a final smoke test on the PicoMite and what I assume will be a non-event of testing on the PicoMiteVGA.
Posted: 11:27am 26 Apr 2023
The problem is that this is what littlefs returns. If you actually write to the files when appended or random you will see that the new write goes on the end. i.e. the open command is correct
Posted: 11:35am 26 Apr 2023
  matherp said  Tom
Hi Peter,
Given that nothing else can be manipulating these files other than the interpreter it should (for the sake of consistency) be possible to workaround littlefs' idiosyncrasies (assuming it is littlefs that is idiosyncratic and not the library used for the other 'mites and drive B:)
So, if I were the one doing this, that is what I would do. HOWEVER they are edge conditions and I'm not the one doing this, so if you want to say "No" then I'll just special-case these assertions in my test-suite on the PicoMite.
Posted: 11:47am 26 Apr 2023
The problem is that littlefs doesn't set the file write pointer until after a write so on open it just points to the beginning of the file regardless of the opening mode. It also doesn't have a EOF function so I simulate EOF by comparing the write pointer with the filelength
Posted: 11:50am 26 Apr 2023
You can try this but you need to check it doesn't b....r anything else
PicoMite.zip
Posted: 12:00pm 26 Apr 2023
  matherp said  You can try this but you need to check it doesn't b....r anything else
PicoMite.zip
Right, so no pressure then ;-) ... what happens if you automatically perform a seek(file_length + 1) as part of opening for RANDOM or APPEND ?
Edited 2023-04-26 22:02 by thwill
Posted: 01:00pm 26 Apr 2023
that's what I have done + a flush
Posted: 01:07pm 26 Apr 2023
  matherp said  that's what I have done + a flush
OK, I will give it a thrash, but it will have to be tomorrow.
Thanks,
Posted: 10:23am 27 Apr 2023
Slowly going potty:
PicoMite MMBasic Version 5.07.07RC7
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
> ? Mm.Info(Drive)
A:
> ? Mm.Info(Exists Dir "B:")
1
> ? Mm.Info(Drive)
B:    <==== WTF!!!
Also:
> ? Mm.Info(Drive)
A:
> ? Mm.Info(Exists Dir ".")
1
> ? Mm.Info(Exists Dir "..")
1
> ? Mm.Info(Exists Dir "")
1
> ? Mm.Info(Exists File ".")
0
> ? Mm.Info(Exists File "..")
0
> ? Mm.Info(Exists File "")
0
> Drive "B:"
0    <==== WRONG
0    <==== WRONG
1
0
0
Posted: 10:41am 27 Apr 2023
Does "Drive" still work from the command line or was it taken out?
What happens if you change to drive B using "B:"?
Edited 2023-04-27 20:42 by Mixtel90
Posted: 10:46am 27 Apr 2023
  Mixtel90 said  Does "Drive" still work from the command line or was it taken out?
Both work fine, that's not what either of these bug reports is about:
1. Mm.Info(Exists Dir "B:") actually changes the Drive to B !!!
2. On Drive B, Mm.Info(Exists Dir ".") and Mm.Info(Exists Dir "..") do not return 1
Amnesie
Posted: 11:26am 27 Apr 2023
Hello Tom,
I am following your bug reports quite a while and I'm impressed and curious how you can spott so many of them. Have you written some "test-sequence" or do you work on a program for basic, which involves this extensive testing? In any case this work is hugely apprechiated!
Greetings
Daniel
Posted: 11:29am 27 Apr 2023
  Quote  <==== WTF!!!
That's what happens when I implement special cases to get round differences between LittleFS and FatFS - forgot to restore the current filesystem. And the second report also needs yet more special cases
disco4now
Posted: 11:44am 27 Apr 2023
  thwill said
  matherp said  Which version - which method of loading?
[3295] Sub test_comment_if()
Error : Too many subroutines and functions
At which point it hangs.
And when you reset it, it just gets to the same point again (because that "invalid" program is in flash) and hangs again.
I have seen this one some time ago, but for 'too many labels'
On the PicoMite the labels are hashed with the SUBs and FUNCTIONS, but after them so I think there is still a path after RC8 to get into this hang situation if number of SUBs and FUNCTIONs are OK but the labels take it over the maximum of 224.
Also is there any room to increase the number for the Picomite as it also includes the labels, but on PicomiteVGA and WebMite labels are not hashed.
#define MAXSUBFUN           224               // each entry takes up 4 bytes
Gerry
F4 H7FotSF4xGT
Posted: 12:06pm 27 Apr 2023
Since a "proper" program doesn't have any labels then counting them makes no difference to the subroutine number.
In any case I am not making changes to memory layout now. Just bug fixes before 5.07.07 goes live
Posted: 12:22pm 27 Apr 2023
  Amnesie said  I am following your bug reports quite a while and I'm impressed and curious how you can spott so many of them. Have you written some "test-sequence" or do you work on a program for basic, which involves this extensive testing? In any case this work is hugely apprechiated!
Hi Daniel,
I'm not doing it manually if that's what you are wondering about. I have ~20,000 lines of MMBasic solely written to test actual behaviour (of both low-level MMBasic and the programs I write in it) against expected behaviour. All I need to do is type one command and it rattles off and some time later (quite a lot of time later on the PicoMite) it reports what is behaving as expected and what is not ... of course it is far from comprehensive and occasional manual intervention is required.
See more (and ask any followup questions) here: https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15846
     Page 8 of 13
