Local Time 10:19 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 2 new Picos announced!
     Page 6 of 6
Justplayin
Posted: 08:05pm 23 Aug 2024
I ordered up a Pimoroni Pico Plus 2 and regular Pico2. Now I have to wait to see how long it takes to ship to the United States.🧐
--Curtis
Posted: 08:39pm 23 Aug 2024
Some advice please. When pico2 arrives if I want vga, glcd, usb vga or usb glcd do I just use existing 2040 firmware and will the pico2 board be pin compatible with pico 2040?
The new terminology is like when pio programming started on 2040 , over my head.
It's all very interesting though. Great work developers are doing.
Posted: 08:46pm 23 Aug 2024
The Pico 2 is pin-compatible with the Pico.
It *isn't* firmware compatible, so the same version of MMBasic won't run (or even load) on it.
You can run the same MMBasic programs though, providing you run the correct version of the firmware, of course. You can't have VGA and GLCD on the same Pico 2 at the same time, just as you couldn't on the original.
Posted: 09:14pm 23 Aug 2024
  Mixtel90 said  The Pico 2 is pin-compatible with the Pico.
You can run the same MMBasic programs though, providing you run the correct version of the firmware, of course. You can't have VGA and GLCD on the same Pico 2 at the same time, just as you couldn't on the original.[/QUOT E]
Does that mean mmbasic will not run on pico2? From reading others posts I got the impression vga worked. I think I've misread others wishes as reality .
What do I do with the pico2 boards when they arrive.. after soldering header pins?
Posted: 09:41pm 23 Aug 2024
Stan,
The original UF2 files for the pico work on the pico but not the pico2
The new collection of UF2 files for the pico2 will not work on the pico.
Peter has provided MMBasic in all it's versions for pico and a second set for pico2.
Just select the one you want making sure that you select from the pico2 collection for programming the pico2 and all will run as normal.
Edited 2024-08-24 07:42 by TassyJim
Posted: 10:19pm 23 Aug 2024
  TassyJim said  Stan,
ah yes in 2350 hardware thread.
electricat
Posted: 09:31am 24 Aug 2024
Just ordered few of RP2350
Still on sale, if anybody interested:
https://botland.store/modules-and-kits-for-raspberry-pi-pico-2/25311-raspberry-pi-pico-2-rp2350-arm-cortex-m33-5056561803951.html
My MMBasic 'sand box'
Posted: 10:31am 26 Aug 2024
Maybe a warning for people looking for the cheapest solution....
The RP2350 has a core voltage regulator (switching regulator) inside the chip.
This is a challenge, high current electronics inside a small geometry device.
In the RP2350 datasheet (6.3.8.3) there is a list of critical issues with this core voltage regulator. One of them is that you need a specific layout, and a special inductor(*). Otherwise the core voltage regulator is not stable.
For experience I can see cheap chineese clones arriving with alternative inductors.
These may work, but may not be as stable as RP's own boards.
Until the dust settles, I personally would not blindly buy the cheapest clones...
Your milage may vary....
(*) the winding of the inductor (magnetic field direction) is important, hence the inductors are marked with a dot. This is rare, and definitley not common among vendors.
Edited 2024-08-26 20:33 by Volhout
Posted: 10:49am 26 Aug 2024
I'm intending to use an external 1.25V linear regulator for the core supply once the chips are available at JLC
Posted: 11:38am 26 Aug 2024
That's almost certainly what the clones will do anyway It's cheaper. It just happens to be the band gap voltage too so you can get it by connecting the ADJ pin of a LM317 directly to ground. :)
Posted: 02:16pm 26 Aug 2024
Peter,
Don't use a SOT23 regulator for it.
The switchmode regulator is designed to deliver 200mA from 1.1V for the cores alone.
(resulting in 66mA from 3.3V). If you use a linear, and the cores would consume 200mA, you need to dissipate (3.3-1.2)*0.2 = 0.42 watt.
In our custom to overclock (315 / 378MHz), the 200mA at 1.1V may be a reality.
     Page 6 of 6
