Forum Index : Microcontroller and PC projects : MMBasic for DOS. Ver 5.04 Beta
| flip Senior Member Joined: 18/07/2016 Location: AustraliaPosts: 137 |
Hi Geoff, Just finding a stopper for me with LOAD command from within a program, it seems to generate File not found. I have made it work occasionally, but can't seem to figure out the magic sequence. The LOAD command seems to always work in command mode. In the Micromite this may happen as well(not tested), but this failure to LOAD and RUN within a program may be preferred behaviour, as it could easily be possible to write a program that recursively loads and runs the same program, thus destroying your chip pretty quickly. So if this is deliberate behaviour for the PIC, could the rule be relaxed for the DOS version? (That is assuming this issue is confirmed to be an issue) Also as a side issue, the ON ERROR SKIP doesn't seem to work when placed before the LOAD command in a program Another strange one (this is not too bad) is where the INPUT command is supplied 2 parameters, 1) if the first is a string literal - fine works like the book 2) if the first is a string expression, it looks weird, but the user input goes into the variable (second parameter) OK 3) if the first is a variable, it puts the data into the first variable and nothing into the second, which I can see now thinking about it is expected behaviour - designed especially for when there are a list of input values provided. So there's probably not much can be done about this one, and it's not a problem when combined with PRINT command (so not requiring use of the prompt string at all)...just that case 2 looks weird and seems inconsistent with 3 until you really think about it. Attached is a test file I have written for these things.. 2017-07-20_104705_test1.bas.zip Really enjoying this stuff.. Regards, Phil |
Hi all, This would have been nice, but running this gives C:\>mmbasic If anyone knows a work-around it may be handy...I suspect it may need to be recompiled as a 16-bit app, in any case for myself I wouldn't be using MM with DOSBox at this stage (though it is a great little program)This is a Windows NT character-mode executable Regards, Phil |
If you get that message then it means that it is a Windows program (opens its own window), not a DOS program. Maybe call it MMBasic for Windows? :) Microblocks. Build with logic. |
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
It seems I have to load a program twice before MMBASIC for DOS accepts it. > load "chebyshev_planet.bas" Error: No such file or directory > load "chebyshev_planet.bas" > |
I believe that I have found the cause of both the difficulty in using LOAD and the issue with OPTION ERROR SKIP before LOAD or RUN. Attached is Beta 6 which works in all my tests: 2017-07-23_091214_DOS_MMBasic_5.04.05_Beta_6.zip As a side comment: The command OPTION ERROR (which only worked for file errors) is superfluous so I have removed it - ON ERROR, which works much better, should be used in its place. With the next version of the Micromite Plus I will place it on the obsolete list for eventual removal. The prompt string, if specified, is the first parameter and it must be a quoted string constant (ie, "prompt") not a variable or an expression - so the command is OK and trying to do what it should. I will edit the manual to make it clear that only a string constant is allowed. I believe that the INPUT command harks back to the days when John Kemeny and Tom Kurtz designed the first elements of the language 50 years ago. They must have got up out of the wrong side of the bed that day. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff !! All fixed and more!! (and so quickly)...This has now proved to me that we can pretty much build entirely in MM environment(s) if we want to Dare I suggest connectivity with the real uMite?...rhetorical...I might try making a bit of middleware glue to join MM DOS with putty... Also for anyone interested I have attached a demo program with some small improvements..unzip to its own directory and have a play. 2017-07-23_124117_DosTestsDemos.zip Regards, Phil |
Thanks Geoff |
the system command still starts in the wrong directory when a basic file is dropped onto the mmbasic.exe icon. it incorrectly starts in "C:\Documents and Settings\admin" rather than the current directory from which mmbasic was launched. > system "cd" C:\Documents and Settings\admin > did you have any luck with the win32 console functions located here: https://docs.microsoft.com/en-us/windows/console/console-functions i did look up the watcom compiler, and it looks like you can gain access to them simply by including wincon.h, see the example here: https://cboard.cprogramming.com/c-programming/113081-moving-console-cursor-printing-color.html i still recon a simple gotoXY(x, y) and colour(attribute) would keep many folks happy. cheers, rob :-) |
The starting directory is set by the operating system. On mine it is set to the location of the file being dropped. Yes thanks, I have got access to the win32 console functions and it opens up a whole new world of things that can be done. I'm still working through the list and the next beta should have something like gotoXY(x, y) and colour(attribute) plus others. Geoff Geoff Graham - http://geoffg.net |
Geoff, Can we get MM.CMDLINE$ implemented to give the full command line that was used to invoke MMBasic. That would allow more flexibility when starting MMBasic from batch files etc. Jim VK7JH MMedit |
| damos Regular Member Joined: 15/04/2016 Location: AustraliaPosts: 81 |
Thanks Geoff, this is really awesome. Is there any chance that we could have a plugin system to create device emulators? I don't really want to write in C, and would prefer C#/.Net, so rather than using DLLs as the interface we could use named pipes or even web sockets which would allow the emulator to not even be on the computer. The idea is we can write the code so that it is exactly the same as the Micromite version in Windows, so we need I2C, SPI and pin emulators. We need to option to add multiple devices to the same pin. Maybe setup a command like: OPTION I2C Pipename or OPTION SPI 127.0.0.1:1234 The idea is that emulators could be created for LCD displays, touchscreens, signal sources, protocol analysers, logic analysers etc. A could of other ideas: A MMEdit plugin that you can just parse single lines of command to and get a response. With modern programming environments, I almost never get compile errors because they are detected by squiggly underlines as I type the code. Visual Studio does this by actually running the code through the compiler which finds the errors that it would have picked up in a compile. It is a bit different with interpreted languages, but a feature like this in MMEdit would be a big help. Dan |
by joves, you're right, looks like a bug in (at least) XP. the workaround is to use GetModuleFileName and chop off the .exe name to get the correct working directory. but you'd also want to check the case of when mmbasic was launched through a (.bas) file association, in which case you may NOT want to change the current directory. SetLength(buffer, 1024); I:=GetModuleFileName(0, pchar(buffer), length(buffer)); SetLength(buffer, I); writeln('GetModuleFileName = ',buffer); cheers, rob :-) |
For the moment that is going a bit overboard. Especially from within a 32-bit DOS box. One important point - I never intended this to be an emulator for a Micromite (ie, emulating I/O, I2C, graphics, etc). It would be impossible to get a good emulation and why bother when it is so easy to use a real Micromite with real I/O? Also, I don't plan on turning this into a fully blown Windows development system (ie, with multiple windows, fonts, etc). There are plenty of good implementations of this type of environment already available (but at a cost). This is just a simple and fast program for executing BASIC code. Use it for learning BASIC, testing program constructs, simple tasks and playing ancient computer games like Hamurabi. Geoff Geoff Graham - http://geoffg.net |
not to forget, you (geoff) may find the win32 version a more convenient platform for testing out new ideas for changes in the interpreter - with far more control over the running environment that on a PIC32. i've done a little more testing and the CD bug in XP et al only kicks in with a dropped file, not with a file extension association. but then it occurred to me that the simplest solution is to just apply the following rule: if mmbasic.exe is started with a .bas filename as the parameter, and that parameter contains a path, then always set the current directory to that path contained in the parameter. i believe this should work transparently with all versions of windows. cheers, rob :-) |
For me the main problem is accessibility. There are lots of times when I want to work on the Micromite projects and I just can't bring the hardware with me. With the emulator I can do the whole thing with just a laptop. Examples in include air travel, and lots of times I spend waiting, or even on the couch in front of the TV with the family, rather than being locked away in the workshop. The Win32 environment also lends itself to better debugging tools because it is significantly more powerful. A line by line debugger with variable inspection/modify capabilities is wonderful. I even get that with a text editor/Chrome for web development. These features don't need to be part of MMBasic, we just need to be able to hook into it. I prefer MMBasic to be very simple but code-compatible. An alternative is on-device debugging like when I run through Android Studio. It all runs on the device, but I get all the benefits of breakpoints, line by line debugging and variable inspection. This doesn't solve the accessibility issues like the emulator though. Dan |
You are right, the edit/compile/test cycle is very fast. I'm planning to implement Jim's idea of MM.CMDLINE$ and that will make the full command line (including the path of the BASIC file) available to the BASIC programmer. Geoff Geoff Graham - http://geoffg.net |
when launched with a .bas filename as a parameter via extension association or dropped file, does watcom C provide the full (expanded) path to the C program? setting the current directory to this would save folks having to do any checks or manipulation of the current directory themselves, removing quite a bit of potential confusion. now just an idea... what if setpin and pin()= were allowed in the win32 version, but performing the function of outputting a message to a nominated comm port? for instance, the following code: A=4 B=1 pin(A)=B might cause the string "pin(4)=1" to be sent to com1: that an attached (real) micromite could then process as a direct command. reading a pin could be handled thus: C=5 I=pin(C) causes the string "? pin(5)" to be sent to com1: with the response read back (with a suitable timeout) by the win32 mmbasic interpreter stored into I. it may be possible to extend the above idea to work with a great many of the pic32 specific commands and functions. an attached micromite sitting at the command prompt could then be 'remotely controlled' by an mmbasic program running on a PC. the basic program on the PC may be considerably larger or more complicated than what could run on the micromite. note: this is just an idea that occurred to me. it may not be a good idea, or may be far too complicated to implement. but is perhaps worthy of kicking around to see if it has any merit or usefulness cheers, rob :-) |
From my experiments MM.CMDLINE$ only provides the basic file name, without the path, so I guess that it will not address your issue - but I really don't want to include a hack for XP!!!! Can you use CHDIR in your programs? On your idea of simulating I/O pins... It is just not feasible, I/O pins are dynamic and that is hard to realistically simulate. And what about SPI, I2C, etc? The reality is that it is not possible to practically simulate a Micromite in all its glory. Especially when an E28 hanging off the end of a USB cable can do it much better. (but I do admire your tenacity!) By the way Rob, we gave been seeing a lot about the floods in Christchurch on the news. Does it affect you? Your city has certainly been in the wars what with earthquakes, floods, etc. Have you considered moving to Perth? We could then argue these issues face to face! And Grogster, if you are reading this, Dunedin (another delightful city by the way) has also been flooded - are you OK? Does the flooding affect you? Geoff Geoff Graham - http://geoffg.net |
Windows has always done strange things with directories. W10 tries to be helpful and remember the last one you used for a particular program to the extent of ignoring your requested folder next time. With MMEdit, I call MMBasic.exe with "ShellExecuteExA" and it has an option to pass the starting folder. I set the starting folder as the one with the BAS file in it. This method seems to work reliably (for now). With Rob's cursor program, I hard coded the path to cursor.exe and then the working folder doesn't matter. Jim VK7JH MMedit |
it certainly does seem to not just be an XP thing. there are a great many confused fragments of discussion on the web: bottom line is it is complicated, and can depend upon not only the windows version but also how users are set up on your computer. this is the clearest comment: https://stackoverflow.com/questions/882850/dragging-files-to-an-exe-sets-different-working-directory while here is the most complete, but also the most complicated: https://stackoverflow.com/questions/42057121/current-working-directory-in-a-vbscript-invoked-by-a-drag-drop-operation a discussion about different users producing different results is here: https://stackoverflow.com/questions/31622469/run-as-administrator-changes-batch-file-current-directory-sometimes (it talks about the "user account control" settings for each user having an effect). note: on almost every machine i set up, there is just one single user called 'admin' that is an Administrator and has no password. i hate passwords or multiple users on machines that can not be logged into remotely. i still maintain that IF the first parameter refers to a .bas file AND that first parameter contains a fully qualified path THEN the current directory should be set to that path. this should be done universally, no matter what version of windows mmbasic.exe is running under. thankfully i've not been affected by the flooding, even though i'm currently house/cat-sitting at a place that is 50m from the heathcote river. the earthquakes are another thing... have been battling with EQC for nearly 7 years now, trying to get them to release the claim for my home to my private insurer for settlement. another 6 months and i'll lose cover for the 2010/11 events due to the statute of limitations on making an insurance claim. said home will then become a financial write-off. while it would be great to visit perth for a chat, i don't know if i'd survive the hot weather in australia for any length of time - an over-active thyroid limits me to cooler climates! cheers, rob :-) |
