Local Time 04:47 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Progess photos
     Page 5 of 5
Posted: 03:12pm 18 Apr 2010
  GWatPE said   Hi Bob,
I think I put Jim onto the WattsUp meter. I got mine years ago, online from the manufacturer in the US. Around $50- . Probably more, better spec units available now.
These are used by modellers testing electric motors in cars, planes etc.
Gordon.
I did a google search on that meter a while ago. Apparently its no longer available. If anybody finds a suitable substitute I would be interested too.
Greenbelt
Posted: 05:17pm 18 Apr 2010
TINKER,
From the info in the posts above This model WU 100-B seems to be close to what I'm reading, If not, there are a few more to chose from.
Watts Up WU 100
VK4AYQ
Posted: 05:22am 19 Apr 2010
Hi Greenbelt and Jimbo
I found the site it has no specs on the 100-b but it looks good.
Thanks a lot
All the best
Bob
Foolin Around
Greenbelt
Posted: 07:10am 19 Apr 2010
VK4AYQ,
From the Link in the post above, Select Item of interest, When page opens, Scroll down to far bottom for a description.
GIZMO;
If this page Item copy is in violation of PP or advertising rules, please delete;
Thanks.
Product Description
"\ This is the RC Electronics Watts Up Watt Meter with Onyx Colored Case. FEATURES: Works with any electric airplane, helicopter, car or boat model High resolution on all measurement ranges to accurately check battery battery pack cell balance and measure single cell packs Connects like jumper cables and troubleshoots poor performance, crashes, charging problems, battery capacity, ruined batteries, erratic receiver and servo operation and many other common electric model problems Readings are easily reset, even without removing power, by adding an external pushbutton connected to the reset signal of the meter's auxilliary connector, The full user manual (v1.7) at the RC electronics has details on this function. Sets cutoff currents and voltages, compares components and detects wear prior to component's failure Measures eight essential electrical values; Captures Peak Amps, Peak Watts and Minimum Volts events as short as a fraction of a second Current: 0-100A, 50A Continuous, .01A Resolution Charge: 0-65535mAh, 1mAh resolution Power: 0-6500 Watts, .1W Resolution Voltage: 4-60V, .01 Resolution (0V min. using auxiliary receiver battery Energy: 0-6500 Watt Hours, .1WH resolution Powered by circuit-no battery to change 16 character, 2 row LCD display 8 MIPS microprocessor and DSP firmware for highest performance One year warranty INCLUDES: RC Electronics Watts Up Watt Meter, four 3.8"" (96mm) length 14 gauge stranded silicone source and load wires without connectors
VK4AYQ
Posted: 09:46am 19 Apr 2010
Thanks Greenbelt
It looks like a handy tool to plug in and check things with better than a heap of multimeter s wires and sparks smoke and the exiting actions.
All the best
Bob
Foolin Around
KarlJ
Posted: 03:27pm 27 Apr 2010
Sorry for the slow reply
top work Jimbo!
looks to me like 1/2 the axial flux mill is already there, just glue on some magnets to that hub, start winding coils, another "hub" for the other side and some more magnets and you're away....
JimBo911
Posted: 03:07am 28 Apr 2010
KarlJ
Wish the AX/FX was that easy.
Getting warm here now, summer is on it's way, time to go back to work and make some $$$$
The AX/FX will have to wait for awhile or until Gordon or Phill decide to give away some of there drawings and or specs?
Thanks for your response.
MacGyver
Posted: 04:06am 28 Apr 2010
JimBo911
I'm building an ax-fx from scratch. Just follow my lead and let me make all the mistakes.
I've started a thread in Windmills called "New Ax-Fx Design" and it started out as a reply to John Tulloch (Oxtules) showing him a little sketch I'd made. I wanted to throw it into a PM reply, but the system wouldn't allow any pictures, so . . .
Right now, I'm working on manufacturing my own lightweight blades from coroflute plastic (it's like plastic cardboard more or less). Everyone has told me they'll explode; they're probably right, but I'm building them anyway. I just like building stuff from scratch and if it works or not is part of the fun for me.
So, like I said, hide and watch; learn by my mistakes and before you know it, you'll have your own "working" ax-fx flying above your home.
. . . . . Mac
Copeville, Texas
JimBo911
Posted: 01:36pm 28 Apr 2010
Hello Mac
Yes I have been following your AX/FX posting.
Sure' go ahead and make the blades the way you like if they don't work then make ones that will work. If the alternator works then I am sure you will come up with some blades that work as well. You may want to reinforce the lower or root section of the blades just to be on the safe side.
Mistakes hummmmmm you can show me what not to do.
Best of luck.
     Page 5 of 5
