Local Time 23:53 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.02.01 betas
     Page 5 of 8
Posted: 04:24pm 23 Feb 2026
Normal service is resumed
PicoMiteV6.02.01b5.zip
In addition this build includes mm.info(PWM SLICE gpno)
This returns the PWM slice for a given pin allowing:
setpin gp2,pwm
pwm mm.info(pwm slice gp2),1000,50
Of course this doesn't solve the channel issue and:
setpin gp3,pwm
pwm mm.info(pwm slice gp3),1000,50
will still error because it has to be:
setpin gp3,pwm
pwm mm.info(pwm slice gp2),1000,,50
Posted: 10:21pm 23 Feb 2026
Can anyone confirm if the ‘PicoMiteHDMIUSBV6.02.01b5.uf2’ file in Peter’s post above gives an HDMI output when loaded onto Peter’s ‘Pico Computer 2B’.
I ask as I have gone through all the various resolutions available and none of them are giving me an image.
The monitor and lead are working fine when connected to other HDMI sources - there is just no image when connected to the Pico 2B.
I do not have another HDMI monitor at hand to try, hence this post asking for confirmation!
Thanks….
EDIT: just to clarify, MMBASIC works just fine as I’ve got it connected to laptop in TeraTerm
Edited 2026-02-24 08:24 by WhiteWizzard
Posted: 10:51pm 23 Feb 2026
Works fine. Have you set up the relevant options?
Posted: 12:10am 24 Feb 2026
Hi Peter - yep, all options set (with OPTION RESET HDMIUSBI2S).
Even though I don’t have any other HDMI monitors at hand, I do have a box of other PICO 2B PCBs so went and grabbed a handful and the next one I tried worked just fine.
Looks like it was a duff JLC unit OR I somehow messed it up when soldering in the PSRAM (although that does all work!).
I will put it down to a bad unit on the HDMI side of things.
Wanting to play with the new Ray Casting features you’ve recently implemented. As always, great work you keep putting out and as others have said, it is much appreciated.
Briano
Posted: 04:42pm 25 Feb 2026
I might have found a bug related to the new FRAME feature. I'm using 6.02.01Beta 5 for PicoCalc.
According to the FRAME Command User Manual on page 15...
  Quote  The frame buffer is automatically cleaned up by "CloseAllFiles", which is called when:
- A program ends normally
- "RUN" is issued
- An error occurs and control returns to the command prompt
This means you do not need to explicitly call "FRAME CLOSE" at the end of a program,
though you may call it if you need to release the memory during program execution.
In my testing, I found this cleanup doesn't happen. I confirmed with Ernst on the PicoCalc forums this is not related to his changes for the PicoCalc.
Thank you for your long hours on PicoMite!......Brian
Posted: 05:40pm 25 Feb 2026
Please list your program as I can't replicate. Run definitely makes a call to a function closeframe(). How are you exiting the previous run before you see the error?
Briano
Posted: 07:24pm 25 Feb 2026
  matherp said  Please list your program as I can't replicate. Run definitely makes a call to a function closeframe(). How are you exiting the previous run before you see the error?
Hummm. I must be doing something wrong.
When I run this program, it draws the boxes and text. Press a key and it exits.
When I immediately run the program again (run "frametst) I get "Error : Frame ready exists".
I doing this from the SD Card.
' Frame Example Test
FRAME CREATE
' Create a main frame layout
FRAME BOX 0, 0, 38, 21, 2, 1
Frame Print 1,"Press  any   key   to exit",, WRAP
FRAME PRINT 2, "Main Panel 2"
FRAME WRITE
k$ = FRAME(INKEY)
 DO WHILE k$ = ""
 k$ = FRAME(INKEY)
LOOP
END
Posted: 07:38pm 25 Feb 2026
Thanks for the example and explanation. I'll have a proper look at it tomorrow - dinner time now
toml_12953
Posted: 10:17pm 25 Feb 2026
FRAME CREATE
FRAME WRITE
k$ = FRAME(INKEY)
 DO WHILE k$ = ""
 k$ = FRAME(INKEY)
LOOP
END
I copied and pasted your program and I can run it again and again with no error. I tried both run"frametst" over and over and and also pressing F2 over and over. Neither one causes an error on my system.
Briano
Posted: 03:13am 26 Feb 2026
I just realized I should have mentioned I'm using a Pico 2W.. I think I'll try the Pico 2 version on my device.
Thanks for trying....Brian
Briano
Posted: 03:24am 26 Feb 2026
  Briano said  I just realized I should have mentioned I'm using a Pico 2W.. I think I'll try the Pico 2 version on my device.
When I loaded 6.02.01Beta5 for Pico2, my test program runs clean each time.
When I loaded 6.02.01Beta5 for Pico 2W, the error appears.
....Brian
Posted: 07:57am 26 Feb 2026
  Quote  When I loaded 6.02.01Beta5 for Pico2, my test program runs clean each time.
That was the information we needed. Will fix.
Briano
Posted: 04:34pm 26 Feb 2026
Thank you! It works as documented now on Pico2W.....Brian
Bleep
Posted: 06:29pm 26 Feb 2026
As far as I can see, Peter hasn't changed anything yet? Last release was 23rd Feb.
ville56
Posted: 09:08am 27 Feb 2026
Does anyone know a way to pass the pin-name to
   PORT(GPxx, nbr-pins) = n
as a variable? I would like to skip the GND pins but this only works if GPxx is directly coded into the PORT statement.
Second question: I try to permanently disable heartbeat on a Pico-W 2 but the option is not permanent. Both OPTION HEARTBEAT OFF and HEARTBEAT DISABLE do stop the blinking but after restart or power cycle it is on again.
73 de OE1HGA, Gerald
BarryH
Posted: 09:39am 27 Feb 2026
the info in this link may be what you require
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=18535&LastEntry=Y#249488#249310
Footnote added 2026-02-27 19:57 by BarryH
also from 6.02.01 beta0
https://www.thebackshed.com/forum/ViewTopic.php?TID=18627&PID=250525#250525#250525
allows string literals and string variables for GP pin numbers
BarryH
Posted: 09:48am 27 Feb 2026
  ville56 said  Does anyone know a way to pass the pin-name to
That may be a feature Peter added very recently (in a beta), but if not use
EXECUTE
It'll need to be something like
EXECUTE "PORT(" + gp$ + "," + str$(nbrpins) + ") = " + str$(n)
ville56
Posted: 10:05am 27 Feb 2026
thanks for the answers. I did use the loop approach to solve it but the EXECUTE tip is also good. Didn't think of it in the first place even though I use execute from time to time giving me elegant solutions.
Posted: 10:06am 27 Feb 2026
Heartbeat on the Webmite isn't fully handled by MMBasic, it's a function of the WiFi chip. See the manual.
Posted: 10:42am 27 Feb 2026
@Ville56 an example program using Execute for input and output ports.
https://www.thebackshed.com/forum/ViewTopic.php?TID=18525&PID=248927#248927#248927
     Page 5 of 8
