Local Time 15:38 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Any interest in MMBasic for Windows with full Graphics?
     Page 5 of 5
Posted: 07:42pm 23 Jan 2022
Very nice, Peter. :)
LeoNicolas
Posted: 09:17pm 23 Jan 2022
Will it run on Linux?
Posted: 09:38pm 23 Jan 2022
  LeoNicolas said  Will it run on Linux?
As per the title, Peter is coding for Windows.
I assume that it might run under Wine etc.
Provided all the strange extensions being requested are left out and the code kept relatively 'normal', there is a chance the it may be possible to compile it for other platforms.
Posted: 10:56pm 23 Jan 2022
More progress
Posted: 09:00am 24 Jan 2022
Peter gave details of the cross-platform tool he's picked...
Posted: 09:59am 24 Jan 2022
  matherp said  More progress
What did you do ?
The current 5.05.01 DOS version runs 123570 grains on a i9 (absolutely not the slowest machine). 3x more performance. WAUW...
Posted: 10:04am 24 Jan 2022
  Quote  What did you do ?
As they say in the song "It's a kind of magic"
Another performance data point - Solar Eclipse calculation
MM+ @ 100MHz 121.75 seconds
PicoMite @ 252 MHz 35 seconds
CMM2 7 seconds
MMB4W 0.4 seconds
Edited 2022-01-24 20:42 by matherp
flasherror
Posted: 03:43pm 24 Jan 2022
What is the screen resolution? User configurable?
Tinine
Posted: 03:59pm 24 Jan 2022
Heck....Game changer for me....possibly.
Posted: 04:42pm 24 Jan 2022
  Quote   What is the screen resolution? User configurable?
Will be - just got that working without even needing to restart
Can't decide whether to mimic CMM2 resolutions up to and including 1080p or to give complete flexibility. In all cases colour depth will be ARGB8888 and I think I'll set it up with two pages and transparency so you can do things like have a graph moving over a fixed grid.
flasherror
Posted: 12:10am 25 Jan 2022
I wonder about the overhead of doing graphics at high resolution, especially with sprites. Also, since the interpreter is doing font stuff in software will there be a bottleneck somewhere? Maybe this will not be an issue since running on a PC looks much faster than any other MMBasic platform.
(after 2 minute read of olcPixelGameEngine wiki: interesting, "decals" are GPU accelerated sprites but with some restrictions - see https://github.com/OneLoneCoder/olcPixelGameEngine/wiki/TUTORIAL---Decals )
(after 5 minutes thinking): what about using decals as the font char primitives ("A", "B", "C" etc) to draw text to screen? If I understand it correctly decals have highest priority over the background (i.e. stuff drawn by CPU) so you can't use sprites etc on top of decals, but would be fast though. Hardware accelerated cursor LOL?
Edited 2022-01-25 10:29 by flasherror
Posted: 11:14am 25 Jan 2022
Coming together nicely
Graphics demo
Mode change is also now implemented, all CMM2 modes + completely free resolution
MODE n ' select a CMM2 mode but in full ARGB888
mode width%, height%, pixelsize% 'specify the width and height and the size of a MMBasic pixel in screen pixels
The latter syntax allows you to have a huge window but with say 320x240 resolution from MMbasic's perspective
flasherror
Posted: 12:36pm 25 Jan 2022
Does it make sense to have an additional high precision timer other than the 1 mS base timer? Since PC is fast, using 1mS base timer to try to measure code execution time might not give the precision required (i.e. a lot of code could probably execute in 1mS?). On the other hand, if the speed is so fast maybe you wouldn't need to measure/optimize code execution a lot...
Posted: 12:53pm 25 Jan 2022
Not bad at all, Peter. Do you think it might need speeding up a bit?
Posted: 02:02pm 25 Jan 2022
  Quote  Do you think it might need speeding up a bit?
Yes, I haven't start tuning it yet
Posted: 02:49pm 25 Jan 2022
MauroXavier
Posted: 04:29pm 25 Jan 2022
  matherp said  Coming together nicely
Graphics demo
Only waiting for this to be ready to port the Into The Darkness to a full 60 FPS raycast engine... Unfortunately, the CMM2 struggles to keep 15 FPS in this game thanks to my lack of ability to optimize it more.
Posted: 06:30pm 25 Jan 2022
Graphics demo
Impressive demo....
I understand the choice for the mode command, but I hope there are additional options in the future. Most screens on PC's are 1920x1080 nowadays (16:9) and the CMM2 modes do not scale nicely on that resolution.
1024x768: no scaling, uses approc 1/3 of the screen
800x600: when scaling 2x, exceeds screen dimensions: no scaling possible 1/4'th of screen
640x480: scaling 2x => 1280x960, uses around 2/3 screen, that is not to bad
        scaling 3x => exceeds vertical size.
I hope some better matching video mode van be found. Otherwise 640x480 gives best result.
Posted: 06:53pm 25 Jan 2022
Mode 16?
Posted: 07:54am 26 Jan 2022
Yip
Mode 16 was not available on my Gen-1.
But Mode 12 with double pixels is just as fine. Matches exactly. Might have been designed for that ..;)
     Page 5 of 5
