Forum Index : Microcontroller and PC projects : Waveshare Pico Toys
Correct set up for this display is: OPTION SDCARD GP22 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13 OPTION TOUCH GP16,GP17 GUI CALIBRATE 0, 3946, 211, -1287, 853 Works perfectly on V5.07.01. For all displays with multiple things on the SPI bus you MUST enable all of them |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6204 |
I looked at the waveshare pico toys, and stumbled upon this "beauty". https://www.waveshare.com/pico-relay-b.htm Bad thing, it has no inputs, only outputs, but more important: There is a design fault in this box. There is an isolated powersupply (5V 1watt) that powers the relays. But these consume 0.36W each. So if you switch on more that 3 relays you will run out of power. Edited 2021-12-09 00:48 by Volhout PicomiteVGA PETSCII ROBOTS |
| darthvader Senior Member Joined: 31/01/2020 Location: FrancePosts: 101 |
To be able to use SDCard i was to be more specific on the option OPTION SDCARD GP22, GP5, GP18, GP19 Cheers. Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
| Kabron Regular Member Joined: 30/11/2017 Location: GermanyPosts: 65 |
To be able to use SDCard i was to be more specific on the option OPTION SDCARD GP22, GP5, GP18, GP19 Cheers. Only in case if you change JUMPERS H1-H6 to position B SDIO. Default settings A SPI. |
Something wrong happened with SDCARD on my Picomites with WaveShare 3.5 touch board. As could be seen from the logic capture, at least 2 strange things observed: 1. Clock begins far before CS 2. Clock frequency is 25 kHz 3. No MOSI activity All works fine before. Now the same problem on two Picomites, regardless FW version. LCD and TOUCH works fine. ![]() ![]() Edited 2022-01-01 00:24 by Kabron |
Try cpu speed 126Mhz. PicomiteVGA PETSCII ROBOTS |
2. Clock frequency is 25 kHz 3. No MOSI activity This is completely correct STATUS disk_initialize ( BYTE pdrv /* Physical drive nmuber (0) */ ) { BYTE n, cmd, ty, ocr[4]; if (pdrv != 0) return STA_NOINIT; /* Supports only single drive */ SD_SPI_SPEED=SD_SLOW_SPI_SPEED; SPISpeedSet(SDSLOW); deselect(); /* Initialize memory card interface */ for (n = 10; n; n--) xchg_byte(0xFF); /* 80 dummy clocks */ ty = 0; if (send_cmd(CMD0, 0) == 1) { /* Enter Idle state */ Timer1 = 1000; /* Initialization timeout of 1000 msec */ if (send_cmd(CMD8, 0x1AA) == 1) { /* SDv2? */ for (n = 0; n < 4; n++) ocr[n] = xchg_byte(0xFF); /* Get trailing return value of R7 resp */ if (ocr[2] == 0x01 && ocr[3] == 0xAA) { /* The card can work at vdd range of 2.7-3.6V */ while (Timer1 && send_cmd(ACMD41, 0x40000000)); /* Wait for leaving idle state (ACMD41 with HCS bit) */ if (Timer1 && send_cmd(CMD58, 0) == 0) { /* Check CCS bit in the OCR */ for (n = 0; n < 4; n++) ocr[n] = xchg_byte(0xFF); ty = (ocr[0] & 0x40) ? CT_SD2|CT_BLOCK : CT_SD2; /* SDv2 */ } } } else { /* SDv1 or MMCv3 */ if (send_cmd(ACMD41, 0) <= 1) { ty = CT_SD1; cmd = ACMD41; /* SDv1 */ } else { ty = CT_MMC; cmd = CMD1; /* MMCv3 */ } while (Timer1 && send_cmd(cmd, 0)); /* Wait for leaving idle state */ if (!Timer1 || send_cmd(CMD16, 512) != 0) /* Set read/write block length to 512 */ ty = 0; } } CardType = ty; deselect(); if (ty) { /* Function succeded */ SDCardStat &= ~STA_NOINIT; /* Clear STA_NOINIT */ SD_SPI_SPEED=Option.SDspeed*1000000; SPISpeedSet(SDFAST); } return SDCardStat; } Edited 2022-01-01 04:42 by matherp |
Is this a problem with all SD cards or just one? One of mine responds with "SD card not found" the first time you type FILES but works perfectly thereafter. Is an iffy plug/solder connection a possibility? |
This is completely correct Too complicate for my simple mind. You mean that is the goal reached? |
Ofcourse I tryed. |
Is an iffy plug/solder connection a possibility? No matter. |
And if why SD card not found? |
Not sure what we can suggest. You state All works fine before. Now the same problem on two Picomites, regardless FW version. The key is that it no longer works with any firmware. Are you using the same Waveshare board for your tests? Perhaps there is a dry joint or the SD card socket contacts are damaged |
Same issue here. Everything works but the SDCARD on the PICO-RESTOUCH-LCD 3.5 SD Card not found I thought I read the options right... OPTION SYSTEM SPI GP10,GP11,GP12 OPTION SYSTEM I2C GP6,GP7 OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13 OPTION TOUCH GP16,GP17 GUI CALIBRATE 0, 3985, 275, -1278, 881 OPTION SDCARD GP22, GP5, GP18, GP19 |
| BishopXXL Regular Member Joined: 13/01/2019 Location: GermanyPosts: 42 |
Hi pwillard, this work´ for me..... -------- Waveshare 3.5 Touch Display + SDCARD OPTION SYSTEM SPI GP10,GP11,GP12 OPTION COLOURCODE ON OPTION DISPLAY 40, 140 OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13 OPTION TOUCH GP16,GP17 GUI CALIBRATE 0, 3993, 232, -1275, 848 OPTION SDCARD GP22 BishopXXL |
Try to play with series resistors in SD signals paths. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9260 |
Tried a new SD card? (Don't be tempted to use a high capacity one - MMBasic has sensible limits! And be wary of very cheap cards on ebay as you might end up with 256k having paid for 16GB) Handy note - but max size for MMBasic is 32GB When you format a card be careful. Windows 10 will, by default, format cards bigger than 32GB as exFAT, which is a Microsoft special and is no good for some things. You have to either format from command line or use an external program to force a format to extended FAT32. I usually use rufus, but there are others. Mick Zilog Inside! nascom.info for Nascom & Gemini |
AFAIK extended FAT32 works by increasing the block size from 512bytes. This is not supported by the PicoMite firmware/FatFS so the maximum card size supported by the PicoMite is 32GB in standard FAT32 Edited 2022-06-23 18:17 by matherp |
Will try a smaller card. Was using 16GB though. and... 4GB Fat32... "Error: SD Card not found" :( FYI: I use a PUTTY terminal variant called PUTTY-ND that understands that USB COM PORTS can go away and come back. It says "fatal error" when the pico resets... then says "trying to restart session" and then... without you doing anything else... you hit the ENTER key and you are back on the PICO command prompt. It can save some steps... when using PUTTY. The new TERATERM version 5 alpha handles this ok as well. So, Update your terminal software... :) And then... for reasons unknown... it just started working. I can see files. Edited 2022-06-23 21:50 by pwillard |
dang it. It's always something. I finally started to mess with screen brightness on the waveshare pico-res-touch-3.5 and I am using the setting: But issuing a OH GEEZE! Nevermind... it matters *WHERE* in your code you issue the BACKLIGHT command. Edited 2022-08-25 00:37 by pwillard |
