Local Time 21:32 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Manual Errata
     Page 5 of 6
Posted: 03:39am 09 Aug 2020
Thanks guys, I will make the changes.
I have heard for and against arguments regarding merging commands and functions with most preferring it the way that it is.  I guess that it depends on how your head is wired!
I don't distribute the source to the manual because I don't want hacked versions of it floating around.  That would just cause havoc.  I can send you the source to the manual (in Word format) for your own use.  Send me an email to projects@geoffg.net.
Chopperp
Posted: 04:51am 09 Aug 2020
  Geoffg said  I have heard for and against arguments regarding merging commands and functions with most preferring it the way that it is.  I guess that it depends on how your head is wired!
I've always wondered why they are separated. Thought that there must be a valid reason for it.
I would preferred them all in one list. That's how my head is wired (although some may say that my head is not wired at all)
Can get confusing at times trying to decide if something is a command or a function.
Brian
ChopperP
capsikin
Posted: 10:40am 22 Aug 2020
Manual for 5.05.04:
  Quote  SPRITE(X, [#]n) Returns the X-coordinate of sprite n. This function is only active when the sprite is currently displayed (active). Returns 10000 otherwise.
Looks like it returns -1 for sprite numbers that are not active now, so it would be:
  Quote  SPRITE(X, [#]n) Returns the X-coordinate of sprite n. This function is only active when the sprite is currently displayed (active). Returns -1 otherwise.
Same for Y:
SPRITE(Y, [#]n) Returns the Y-coordinate of sprite n. This function is only active when the sprite is currently displayed (active). Returns -1 otherwise.
Also it wasn't previously specified for L, but it would be good to add:
SPRITE(L, [#]n) Returns the layer number of active sprites number n. Returns -1 if the sprite is not active.
Andrew_G
Posted: 07:19am 13 Sep 2020
Geoff,
I hope this isn't too old a thread but I have two suggestions re the manuals for your consideration and adjudication:
1. is it possible to not use "Page" on the footers (but say "P" or "Pg" etc) so that searching on "PAGE" is more meaningful?
2. this one is harder and you may consider it too time consuming or better left until changes slow down a little more - with people now printing hard-copies of the manuals is it possible to use track changes or list the pages that need to be replaced because of minor changes? For major new releases we'd need to do a full re-print but some corrections could be hand done (like a marine chart) or loose-leaf pages replaced.
Many thanks,
Andrew
vegipete
Posted: 08:23am 13 Sep 2020
  capsikin said  Manual for 5.05.04:
If it returns -1 when a sprite is NOT active then that might be a bug, as I believe -1 is a valid sprite coordinate.
Posted: 09:04am 13 Sep 2020
The manual is correct for the sprite(x)and sprite(Y) functions. The code is wrong. Will fix in the next beta. I seem to remember changing it to -1 to be consistent but vegipete is correct that -1 is a valid value.
capsikin
Posted: 10:06am 13 Sep 2020
  matherp said  The manual is correct for the sprite(x)and sprite(Y) functions. The code is wrong. Will fix in the next beta. I seem to remember changing it to -1 to be consistent but vegipete is correct that -1 is a valid value.
Okay.
It wasn't too bad how it was, as I checked SPRITE(L, [#]n) to see if the sprite is active. I think that will still work after you fix it.
Chopperp
Posted: 01:26pm 13 Sep 2020
  Andrew_G said  Geoff,
Many thanks,
Andrew
A YES PLEASE vote from me on this
Brian
ChopperP
Posted: 01:52pm 13 Sep 2020
  Andrew_G said  1. is it possible to not use "Page" on the footers (but say "P" or "Pg" etc) so that searching on "PAGE" is more meaningful?
Not sure on that one.  You do know that the PDF is indexed?  It makes it easy to locate the command that you are looking for.
  Andrew_G said  2. this one is harder and you may consider it too time consuming or better left until changes slow down a little more - with people now printing hard-copies of the manuals is it possible to use track changes or list the pages that need to be replaced because of minor changes? For major new releases we'd need to do a full re-print but some corrections could be hand done (like a marine chart) or loose-leaf pages replaced.
In part this is the responsibility of the change log (ie, to alert users to changes which are also recorded in the manual).  However I will have a crack at implementing change bars in the margins, at least while there is rapid change.
capsikin
Posted: 12:53am 20 Sep 2020
Not an error exactly, just missing information.
The command entry for PAGE SCROLL doesn't say what direction it scrolls. It's the same as SPRITE SCROLL.
  Quote  'x' pixels to the right and 'y' pixels up
I found it confusing until I checked the other command, because it's moves to a larger x but a smaller y.
Womble
Posted: 01:21am 20 Sep 2020
I'm not sure how fast the manual keeps up with Peters rapid fire beta updates but ...
In the download for V5.05.06b9 the manual is specified for "MMBasic Ver 5.05.05" on page 1.
Also, MODE command listing on page 73 makes no mention of MODE 11 or MODE 12
And the "release_notes" text file is "V5.05.05_release_notes.txt" but only mentions changes up to V5.05.04
I assume this is due to the "beta" nature of the download, and the rapid changes
Many Thanks Peter, Geoff and the team for all your good work.
Womble
EDIT: CMM2_Current_Bug_List.txt seems to be obsolete too
Edited 2020-09-20 11:23 by Womble
Posted: 02:06am 20 Sep 2020
readme.txt has the changes found in the beta versions.
The manual etc are only updated once the firmware goes out of beta.
Womble
Posted: 05:16am 20 Sep 2020
  TassyJim said  readme.txt has the changes found in the beta versions.
Thanks Jim, I thought that might be the case, but posted just in case
vegipete
Posted: 10:11pm 27 Jan 2021
A few things:
(most recent CMM2 manual as of Jan 27,2021, as far as I can tell.)
In the command
LINE INPUT #nbr,string-variable$
the pound sign (#) appears to be mandatory, not optional. Perhaps that fact could be highlighted better in the text?
Could the pages available table on the bottom of page 81 include the resolution, maybe in brackets after the mode number? Ie: 1 (800x600)  2 (640x400) etc.
Some commands/functions are missing from the bookmark list:
GUI commands, HELP, PIXEL(), CONTROLLER, DRAW3D (although no details in manual yet anyways)
The bookmarks for IMAGE ... are a bit munged too.
SPRITE(V,...) appears twice
MOUSE and OPTION MOUSE are completely absent
MATH( - simple statistics -)  descriptions are misaligned
There are so many awesome (new) features in CMM2Basic but the peanut upon my shoulders cannot remember them all so the manual has to be as good as possible to compensate. The manual is pretty dang good, but the peanut is worse.
Posted: 12:56am 28 Jan 2021
Thanks Pete, the manual is updated with each new stable release so expect these to be folded in then.
Turbo46
Posted: 04:29am 06 Feb 2021
Under CONTROLLER MOUSE ... (Page 63)
  Quote  CONTROLLER MOUSE CLOSE will close the Nunchuk port 'n'. If the
parameter is omitted channel 2 is closed.
Nunchuk should read Mouse.
vegipete
Posted: 08:14pm 22 Mar 2021
Is there a complete list of recognized named colours?
Page 29 of the manual lists:
white, black, blue, green, cyan, red, magenta, yellow, brown and grey, plus NOTBLACK.
But 'orange' works also. Are there any others? Could we have 'purple' too? (Approx #99)
Edited 2021-03-23 06:17 by vegipete
Posted: 08:50pm 22 Mar 2021
  vegipete said  Is there a complete list of recognized named colours?
   #define BLACK               RGB(0,    0,      0, 0)
   #define BLUE                RGB(0,    0,      255, 15)
   #define GREEN               RGB(0,    255,    0, 15)
   #define CYAN                RGB(0,    255,    255, 15)
   #define RED                 RGB(255,  0,      0, 15)
   #define MAGENTA             RGB(255,  0,      192, 15)
   #define YELLOW              RGB(255,  255,    0, 15)
   #define BROWN               RGB(0xA5, 0x2a, 0x2a, 15)
   #define GRAY                RGB(64,   64,     64, 15)
   #define LITEGRAY            RGB(128,   128,     128, 15)
   #define WHITE               RGB(255,  255,    255, 15)
   #define ORANGE              RGB(0xff,  0xA5,   0, 15)
   #define PINK                RGB(0xFF,  0xA0,   0xAB,   15)
   #define GOLD                RGB(0xFF,  0xD7,   0x00,   15)
   #define SALMON              RGB(0xFA,  0x80,   0x72,   15)
   #define BEIGE               RGB(0xF5,  0xF5,   0xDC,   15)
   #define NOTBLACK            (VideoColour==8? RGB(0,32, 0,15): (VideoColour==12? RGB(16,16,16,15): RGB(0,4,0,15)))
vegipete
Posted: 10:53pm 22 Mar 2021
Fascinating. You've taken the table from source code, by the looks of it. But not for a CMM2?
'LITEGRAY' is unknown on my CMM2. Instead, 'LIGHTGRAY' works.
And BEIGE goes into memory as colour number 255, even though RGB(BEIGE) <> RGB(WHITE).
Short program to show colours:
' Quicky to show 8 bit mode palette colours, along with named colours.
cls
addr = MM.INFO(PAGE ADDRESS 0)
pixel 0,0,rgb(BLACK    ) : ? "BLACK    " peek(byte addr)
pixel 0,0,rgb(NOTBLACK ) : ? "NOTBLACK " peek(byte addr)
pixel 0,0,rgb(BLUE     ) : ? "BLUE     " peek(byte addr)
pixel 0,0,rgb(GREEN    ) : ? "GREEN    " peek(byte addr)
pixel 0,0,rgb(CYAN     ) : ? "CYAN     " peek(byte addr)
pixel 0,0,rgb(RED      ) : ? "RED      " peek(byte addr)
pixel 0,0,rgb(MAGENTA  ) : ? "MAGENTA  " peek(byte addr)
pixel 0,0,rgb(YELLOW   ) : ? "YELLOW   " peek(byte addr)
pixel 0,0,rgb(BROWN    ) : ? "BROWN    " peek(byte addr)
pixel 0,0,rgb(GRAY     ) : ? "GRAY     " peek(byte addr)
pixel 0,0,rgb(LIGHTGRAY) : ? "LIGHTGRAY" peek(byte addr)
pixel 0,0,rgb(WHITE    ) : ? "WHITE    " peek(byte addr)
pixel 0,0,rgb(ORANGE   ) : ? "ORANGE   " peek(byte addr)
pixel 0,0,rgb(PINK     ) : ? "PINK     " peek(byte addr)
pixel 0,0,rgb(GOLD     ) : ? "GOLD     " peek(byte addr)
pixel 0,0,rgb(SALMON   ) : ? "SALMON   " peek(byte addr)
pixel 0,0,rgb(BEIGE    ) : ? "BEIGE    " peek(byte addr)
for y = 0 to 15
 for x = 0 to 15
   box  120+x*40,y*35,40,35,1,,map(y*16+x)
   text 122+x*40,2+y*35,str$(y*16+x)
 next x
next y
Posted: 11:19pm 22 Mar 2021
  vegipete said  Fascinating. You've taken the table from source code, by the looks of it. But not for a CMM2?
Taken from CMM2 V5.06
Perhaps Peter has fixed the spelling of LITEGRAY in V5.7beta
     Page 5 of 6
