Local Time 19:31 24 Oct 2026 Privacy Policy
     Page 45 of 52
flyingfishfinger
Posted: 11:18pm 31 May 2023
  Solar Mike said  I would use a Schottky rectifier, as the lower forward voltage drop means less heat. STPS60SM200CW
Ooh that looks like a nice part - sadly it's out of stock everywhere. This looks like an acceptable substitute, APT30S20BCTG
Will order up a couple and see what happens!
soudirector
Posted: 10:02am 01 Jun 2023
  flyingfishfinger said  Well, here's a fun one. I blew up some diodes! My mistake actually, I feel silly.
The MPPT has been running great for a year on 2 panels (OC something like 90V) but I really want 3 panels in series (-> 130V). I had upsized the switching transistors to FDH055N15A as planned (150V).... but I forgot to swap out the "diode" transistors and stuck with HY5110 (100V)
Attached 3 panels, at the 60 second mark the thing quite spectacularly exploded.
Sadly I think there is more damage than just this transistor, there is some charring around the FOD3182's output pins as well, but the 12V output of the isolated regulator is still present. Will have to debug further when I have some time.
Question for the group: What transistor would you recommend as a diode that will handle 150V properly? Should I just use two FDH055N15A? EDIT: Looked through the thread and saw suggestions for Vishay VS-60EPU02-N3 or ST STTH6002C.
Cheers,
R
I prefer using IRFP260N Mosfet 200v, 50A, DS(on) = 0.04Ω
how times flies
Ziki_the
Posted: 12:05pm 01 Jun 2023
Question?
For current sensor is it posible to use lem ltsp 25-np?
This is current output hall, not voltage out. I have few of them.
Pozdrav iz Srbije
poida
Posted: 12:15am 02 Jun 2023
I think you can use these but you might have to mount it
in a way that permits you to fit a resistor across
M and ref
the pcb is designed for the 3 pin voltage output type so it's not ready
for the 4 pin current output version.
One of my mppt has the LEM sensors mounted upside down, with the pins pointing UP
and I have 3 wires leading from pins to the pcb.
It's not pretty but it works fine.
Ziki_the
Posted: 08:25pm 23 Jun 2023
So i have done a little work on one board.
Pro mini clone is used for display board.
For current sensors, do i need to put one more wire in the midle hole?
Just this work for now.
Pozdrav iz Srbije
flyingfishfinger
Posted: 08:32pm 11 Jul 2023
Ok, I rebuilt the blown parts. Turns out the exploded diodes took 2 out of my 3 FETs with them... now it's back to working.
But I have a question about calibration. When I put the firmware in "cal" mode, the display freezes. Is that the intended behaviour (to lock it at the exact current that is being used at that moment) or is there something I'm not doing correctly?
R
Edited 2023-07-12 06:32 by flyingfishfinger
poida
Posted: 10:08pm 11 Jul 2023
putting it in cal mode is not mandatory.
it was more of a test for me to see if there is much change in the calibration
of the 4 values when running or not.
The display must freeze when in cal mode since it disables the 20kHz interrupt
which contains code that sends out data to the LCD.
I should have made this clear to people that cal mode is not much use and does not
need to be used. Sorry if it caused any issues.
flyingfishfinger
Posted: 10:21pm 11 Jul 2023
No problem, just wondering how best to calibrate the thing. Any suggestions?
All I've got is a shunt ammeter (actually just current setting on DMM) that will go to 10A, heh.
R
poida
Posted: 10:23pm 11 Jul 2023
Zikki,
I think you have it connected up OK.
The 5V and Ground are lined up and soldered in, the "O" and "Ref" need
a resistor.
If it works then no need to do anything else.
(for those who might be wondering)
the 4 pin LEM sensor schematic is
and the 3 pin sensor is
Edited 2023-07-12 08:26 by poida
flyingfishfinger
Posted: 06:45pm 25 Jul 2023
Progress report: Fixed up my unit and it runs at 1000W with no issues so far - the higher input voltage (130V) is also handled nicely with the new diodes.
Question: I'm still having the issue where the current sensor reports incorrect values when there's no charging (anywhere between 0.1 and 0.6A instead of zero) despite zeroing the current beforehand. My theory is that running it at high currents breaks the calibration after some time due to temperature or something.
I wonder if an improvement would be to call the "zero" function each time the device is in night mode? That way it should in theory fix itself after each day. I'll try this next time I go up to my site but that won't be for about 2 months.
Cheers,
R
poida
Posted: 06:33am 26 Jul 2023
the current sensors to take a "set", in other words
their zero current output value can represent + or - a bit of current.
OR
zero current will produce an output with a bit + or - from zero position.
I have found this hysteresis is stable, so long as you do not change direction
of current. In the mppt design, current direction does not change.
This permits us to let the hysteresis to accumulate and we keep
calibrating the zero point and gain.
Things tend to settle down after a couple of good power use periods and recalibrations.
Also, calibrating at 10A is fine. No need to get it perfect, we just need reasonable
values for the mppt program to work.
poida
Posted: 06:35am 26 Jul 2023
I could make a version of the code to measure both current sensors after a few hours of "NIGHT" and then store that as their new zero current settings.
You like that? I need to be at work to do this, I have a lot of spare time
when I am at work. (lucky, eh?)
flyingfishfinger
Posted: 07:44pm 26 Jul 2023
  poida said  I could make a version of the code to measure both current sensors after a few hours of "NIGHT" and then store that as their new zero current settings.
Oh, I figure it won't be hard to add myself - but if you're offering I won't say no :) Do keep in mind I use the I2C version!
My main issue is that since I'm away most of the time and use no power, the batteries spend their time in absorb / float with maybe a bit of bulk in the morning. Thus generally small amounts of current are measured, which increases the error on the total capacity charged significantly more than when higher currents are being used.
Also, I think I mentioned the negative current readings at night causing the accumulated capacity to DECREASE by morning, maybe the zeroing would help with that as well. Maybe we zero once an hour at night? Probably overkill but might be more accurate no?
R
Edited 2023-07-27 05:45 by flyingfishfinger
soudirector
Posted: 05:11pm 02 Aug 2023
I tired to program my nano using the code with I2C. i got error
exit status 1
Compilation error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int)'
Why the I2C file is present in the folder with the ino file. What could be the problem?
how times flies
soudirector
Posted: 05:28pm 02 Aug 2023
  soudirector said  I tired to program my nano using the code with I2C. i got error
exit status 1
this was highlighted when the error occurred
LiquidCrystal_I2C lcd(0x27); // set the LCD address to 0x27 for a 16 chars and 2 line display
how times flies
pd--
Posted: 10:46pm 02 Aug 2023
Do you have " #include <LiquidCrystal_I2C.h> "  at the start of your code.
There are multiple LiquidCrystal_I2C libraries you may be using the wrong one
i haven't tried it but give this one a go
https://www.arduino.cc/reference/en/libraries/liquidcrystal-i2c/
soudirector
Posted: 10:33am 03 Aug 2023
  pd-- said  Do you have " #include <LiquidCrystal_I2C.h> "  at the start of your code.
Yes, i do have that. But i have fix the problem. Thanks
how times flies
soudirector
Posted: 11:36am 03 Aug 2023
  Bryan1 said  G'Day Guy's,
            Well the choke is wound
got 10.5 turns using new 6x3mm enameled wire and I do have another length so I can do a join and solder it so I can get those few more turns if needed.
I live in the Adelaide Hills so for SA guy's a drive up the hill will save postage, those M4 connectors haven't even left to get on the slow boat so still no ETA.
Wiseguy if you want I do have some 6mm, 14mm, 20mm and 25mm rolls so you can have one of each and 2 off 20mm if you like.
Cheers Bryan
I was wondering if this can work without issues.
how times flies
Ziki_the
Posted: 04:12pm 03 Aug 2023
Look like ATX choke.
Maybe 5pcs stocked and some thing like 15-17turns with multply coper wire, litz..
My sugestion..
Pozdrav iz Srbije
soudirector
Posted: 09:41am 09 Aug 2023
  Ziki_the said  Look like ATX choke.
My sugestion..
this inductor is for mppt not ATX choke
how times flies
     Page 45 of 52
