Forum Index : Microcontroller and PC projects : Micromite 5.1 Firmware Update
| Lightrock Newbie Joined: 19/05/2014 Location: AustraliaPosts: 26 |
@Geoffg Document correction to the bottom of page 18 of the Micromite Plus Manual. CircuitGizmos has confirmed that pin 30 is used for Card Detect for the CGMICROBOARD2. Also the link in the same paragraph has changed to http://circuitgizmos.com/documentation/hardware-datasheets/cgmicroboard2-technical-information/ |
Thanks WhiteWizard, jwaldha and Lightrock. I will make the appropriate changes to the manual and source. Geoff Geoff Graham - http://geoffg.net |
Anyone out there running 5.1 on the SnadPIC 470 100 pin board? Any special notes or gotchas? I would appreciate any comments or advice. I hope to receive my SnadPIC in the next few days and am looking forward to firing it up with 5.1. Thanks, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| drkl Senior Member Joined: 18/10/2015 Location: HungaryPosts: 102 |
Dear Geoff, Here is bug report: http://www.thebackshed.com/forum/forum_posts.asp?TID=8694&PN=1 drkl |
