Local Time 22:53 24 Oct 2026 Privacy Policy
Forum Index : Windmills : VAWT, F&P, analog MPPT project
     Page 4 of 6
govertical
Posted: 11:29am 24 Aug 2012
http://www.thebackshed.com/windmill/FPRewire.asp
Hi, connected the coils to form two 6 per phase three phase star. I connected them in parallel, center to center and output to output. With no load the PMA spins with no gogging, there is some drag. When I connect the PMA to a load there is a lot of cogging and I can not measure any voltge at the output.
I noticed on the reference page that there are two diagrams one showing the centers connected and one showing no connection of the centers. Is there a reason for this?
Edited by govertical 2012-08-25
govertical
Posted: 04:34pm 24 Aug 2012
Hi,I was able to fix the problem and I made a quick manual test of the modified F&P. Lower voltage with more current at the input. Should be a better match for buck converter project I am working on. The input voltage should not exceed the circuit voltage max limit.
Edited by govertical 2012-08-26
govertical
Posted: 04:23am 25 Aug 2012
http://www.circuitstoday.com/scr-applications
Greetings, I have found a possible solution for the over voltage protection circuit. The circuit located at number 4 uses the AC to trigger the circuit. I could duplicate the circuit 3 times, one for each phase. When the SCR’s are triggered the added resistive load would brake the turbine to lower the input AC voltage and the buck converter would continue to lower the voltage at the input capacitor of the buck converter on the DC side. I am not sure of the values required. D5 could be two 200 volt zeners in series for a 400 volt trigger. Comments welcome.
govertical
Posted: 09:30am 25 Aug 2012
Hi, If I can get circuit working for single phase AC, this maybe a possible solution for a 3 phase configuration. Comments welcome.
govertical
Posted: 08:52pm 28 Aug 2012
Hi, I tried to test the modified F&P with the OVP circuit. Because I modified the F&P stator I could not charge a capacitor to 400 volts to test to see if the OVP would trigger. I do have my moments. RPM was about 600 and max voltage at the capacitor was about 350 volts with no load.
Even if I add a 1:7 belt drive to the modified F&P I should be safe to road test with the buck converters.
I removed one of zener diodes from the OVP test causing the trigger voltage to be 200 volts. The OVP circuit triggered at about 200 volts and as I increased the RPM’s the voltage at the capacitor remained at 210 volts. The load resistor was only rated at 1 watt and became very hot but the circuit still functions. I have to increase the wattage rating of the load resistor.
It looks like the circuit will work for my application, if used with a wind turbine and the buck converters, the turbine will brake because a resistive load is added when the OVP is triggered and the input voltage at the input of the buck converters will remain at a save value at higher RPM’s.
govertical
Posted: 02:55am 01 Sep 2012
Hi, this is the style blade I can fabricate. The C shape will have end caps.
The big question is what style will have better performance at average wind speeds? Please cast your vote, A, B, or C.
It is a election year.
govertical
Posted: 06:27am 13 Sep 2012
Hi, making progress. Yes you guessed correct, no wind. 3 more blade to go.
http://www.youtube.com/watch?v=cwfujuhw9ZU&feature=youtu.be
govertical
Posted: 12:54pm 14 Sep 2012
http://youtu.be/NJ9XS6IQKzc
http://youtu.be/wfN7aOOSg3g
Edited by govertical 2012-09-15
govertical
Posted: 03:34pm 03 Nov 2012
Hi, completely assembled F&P with belt drive. I counted the ratio and it is 1:4, I am going to tighten the belts and run it with the drill press for a few hours.
I ordered a intronics solar MPPT25, it has a battery charging algorithm. The only problem is the max input voltage is 80 VDC. I will have to add a OVP circuit that will trigger just under 80 volts and configure the F&P as four 3phase with 3 coils per phase connected in parallel. I was communicating with one their engineers and he said it should not be a problem as long as the OVP triggers. I plan to continue working on my circuit.
Edited by govertical 2012-11-05
govertical
Posted: 06:35am 14 Nov 2012
Hi, completed belt drive for F&P PMA. It would be nice to find a supplier for the pulleys. The pulleys are DIY V wall. The belt drive ratio is 1 to 4.25
govertical
Posted: 02:08pm 01 Dec 2012
Hi, after observing the VAWT RPM and measuring the VOC in low wind conditions, I decided to mount a stock F&P stator on the 1 to 4 belt drive. I used a DIY 4 inch ID bearing so I could mount the PMA between the two blade rotors. Waiting for wind.
govertical
Posted: 12:47am 21 Jan 2013
VAWT crash, RIP. 19 MPH wind speed, 3 amps @ 12 volts. Manual operation with hand crank, 5 amps @ 12 volts. Stock F&P with 1 to 2.5 belt drive transmission and MPPT data logger.
Conclusion, even when testing the mast mount needs to be very secure. I need a faster blade design. Without the MPPT circuit output would be very, very low….
Posted: 11:18am 21 Jan 2013
Oh that is very bad after so much work.
Perhaps electrically loading up the turbine to limit the voltage may not be the best approach with this.
Braking the rotor electrically will massively increase the wind loading on the whole machine.
Would it be possible to furl the blades by spilling air once the machine reaches some maximum speed and output voltage ?
If the blades could close right up against each other, the wind would then effectively blow around a smooth cylinder with no turning at all.
No need to go that far, but it should be possible to limit the maximum speed by controlling airflow.
Perhaps some centrifugal weights and springs could be arranged to tilt the blades to reduce the open area caught by the wind on the up wind side.
I would think the pitch of all the blades would need to be linked together, to prevent the whole thing wobbling or going out of aerodynamic balance, and to prevent cyclic blade flutter.
Another way might be a small dc motor with a very large reduction gearbox to mechanically adjust the pitch of all the blades together.
The output voltage could probably then be kept reasonably constant, or at least limited to some safe maximum.
A small scale model may be a simple way of trying a few different ideas.
Something you could hold outside the window of a car driven at various speeds.
govertical
Posted: 01:09pm 21 Jan 2013
hi, the MPPT brakes the turbine at 200 volts. The failure was cause by poor foundation construction. The turbine RPM never exceeded 60. Max wind speed recorded was 19 MPH. I should up and running in a few days. Thanks for the suggestions.
govertical
Posted: 10:41am 23 Jan 2013
Hi, I had some free time so I fixed the VAWT, strengthen the foundation, removed the springs from the belt drive to prevent the belt from jumping, and it is operational again. To cold to take to take pictures. After reviewing the test results, I am increasing the belt drive ratio a small amount. That should make the output about right for this size VAWT. Waiting for wind…..
fillm
Posted: 12:00pm 24 Jan 2013
  govertical said   I am increasing the belt drive ratio a small amount. That should make the output about right for this size VAWT.
Curious to know, what is the right output for a VAWT of your size ?
What do you caculate size on , is it blade surface area , then what surface area is your VAWT?
  govertical said  VAWT 19 MPH wind speed, 3 amps @ 12 volts. Manual operation with hand crank, 5 amps @ 12 volts. Stock F&P with 1 to 2.5 belt drive transmission and MPPT data logger.
I need a faster blade design. Without the MPPT circuit output would be very, very low….[/quote]
With 36W in 19 Mph (8.5M/S, 30klm) , I am not sure you can get much lower , I don't want to rain on your parade but "output for effort" put into this project does not seem to be there....
I can only hope it is all for fun the pleasure of building another piece of "Kenetic Art".
I am not a big fan of VAWTs and too date have not heard or seen any thing out there that performs as stated by its builders and most of the time the videos posted are of the machine running unloaded .
Edited by fillm 2013-01-25
govertical
Posted: 12:34pm 24 Jan 2013
Vawt power
CalTec Study
10x
Hi, I have been using the above calculator as a guide. 6’x4’ approximately 3 to 5 amps at 10 MPH. I think I should be getting twice the output. After reviewing my test results and finding the above study, my new approach for this project is to make multiple small low cost VAWTs and run them in parallel using a MPPT type circuit. Trying make one big VAWT no longer make any sense. It will take awhile to make more VAWTs and I will post results when available.
Edited by govertical 2013-01-25
govertical
Posted: 04:16pm 24 Jan 2013
Hi, it is a learning project. I had springs on the pulley shaft, that was a bad idea, it allowed the belt to jump the cogs. I remover the springs. I am waiting for wind to see if the problem is fixed.
It was working for a day and a half. I am hooked, if it takes another five years I will get the project working.
I like Kinetic Art,
fillm
Posted: 10:37pm 25 Jan 2013
Hi Vert,
Well all good then if you are a total VAWT believer / builder / artist .
The US VAWT output caculator, there is a foot note regarding alternator matching and this is more what I was trying to point out with the F&P , you need something with no iron drag/ cogging otherwise you will be looking at power under the 20%eff figures.
Apart from that I did a comparison in surface are with my latest turbine that has a swept area of 10.17sq/mtr which is a 3.6mtr Dia Blade set , to get 10 sq/mtr with a VAWT it needs to be 5mtrs tall x 2mtrs wide, that then equates to 15.7 cubic mts or if you cut the cylinder and lay it flat is 31.4 sqmtrs of surface area, with the 40% finely tuned machine output figures are still under what my output figures, up to 35klm W/S @ 2kw when the furling starts to limit output.
Basicly a VAWT needs to have 3 times more surface area to equal HAWT surface area output , which then also requires significant engineering with mounting such structures.
The point is , it is very hard to get performance from a VAWT and is pretty well in the league of well funded organizations like Cal Tec etc , funny enough I have supplied them with GOE222 blades , where as a lot easier for the home builder with a HAWT to get meaningful output.
Anyway , I like your work but still think if you put some time into knocking up some coil formers and slapping some magnets on a couple of steel plates you will be well rewarded with a alt that would not need gearing / belts and iorn losses.
Edited by fillm 2013-01-27
govertical
Posted: 11:52pm 25 Jan 2013
Hi, I totally agree with you. One on one a HAWT wins hands down.
I do not have the skills to fabricate a HAWT. I can fabricate a VAWT. I am using the F&P’s for experimentation. It dramatically illustrates the benefits of using a power conversion circuit like a MPPT circuit. Without a MPPT circuit the VAWT would not even spin at low wind speeds because most of power produced is lost as heat at the stator.
A nice thing about the F&P is it is low cost and it is all ready fabricated. I removed the springs from the belt drive and I should have some wind today for testing, I will post results when available. After I finish the testing with the F&P I will try a axial flux, thanks for the suggestions.
     Page 4 of 6
