Local Time 01:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic RP2350 V6.01.00EXP with user-defined structures
     Page 4 of 7
Posted: 08:15am 31 Dec 2025
I love the fact that, at least so far, changes to MMBasic are additions that rarely mess up programs that you have already written for earlier versions. You can also carry on programming in the way you prefer, if you wish, without *having* to learn new things. The stuff is there should you choose to though. :)
I still bemoan the loss of Flash Slots though, but I suppose that's just me. lol I'm slowly getting used to drive A:.  :)
As a New Year's Resolution I intend to finally print an up to date copy of the manual. Sometime within the New Year anyway. 5.07.03 is a bit dated.   ;)
Posted: 09:49am 31 Dec 2025
V6.01.00EXP4
PicoMiteV6.01.00EXP4.zip
MMBasic_Structures_Manual.pdf
StructTest.zip
New commands as per Jim's request - see manual and tests 77-84
STRUCT EXTRACT and STRUCT INSERT
Edited 2025-12-31 19:49 by matherp
Posted: 10:24am 31 Dec 2025
Thank you and happy new year!
karlelch
Posted: 10:47am 31 Dec 2025
Thank you, Peter - These new additions are very useful!
Happy New Year from Switzerland
Posted: 10:52am 31 Dec 2025
Forgot to mention, the release also supports the new RV3028 RTC. This is EXPENSIVE but in theory, even more accurate than the DS3231.
Just use RTC SETTIME, RTC GETTIME and OPTION RTC AUTO ENABLE as for the DS3231
Edited 2025-12-31 20:53 by matherp
toml_12953
Posted: 11:58am 31 Dec 2025
  matherp said  V6.01.00EXP4
StructTest.zip
I get a "Display not configured" in Test 76. I'm running the plain EXP4 version (no VGA, no HDMI) If I comment out the following line, all the other tests pass.
 BOX boxes(i%).x, boxes(i%).y, boxes(i%).w, boxes(i%).h
Once again, mea culpa. I forgot to add the LCDPANEL option back in after nuking the flash.
Edited 2025-12-31 22:11 by toml_12953
bfwolf
Posted: 06:33pm 31 Dec 2025
StructTest.zip
Thank you so much for the new features from me!
And thank you for the additional explanations in the manual regarding alignment and padding! It will surely help many people understand!
I just tested something:
Type TPerson
 phone As integer
 surname As string Length 8
 name As string Length 7
 padding As string Length 6 'alignment to uint64_t
End Type
Dim people(2) As TPerson
people(1).phone = 1234
people(1).surname = "Marther"
people(1).name = "Peter"
people(2).phone = 5678
people(2).surname = "Graham"
people(2).name = "Geoff"
Dim i As integer
Dim o As integer
Print "SIZEOF(TPerson)="; Struct(SIZEOF, "TPerson")
' WORKS, TOO !!! :)
' A "workaround" to replace Struct(OFFSETOF, "type,member")
o = Peek(VARADDR people(1).name) - Peek(VARADDR people(1))
Print "OFFSETOF(TPerson,name)="; O; " =0x"; Hex$(o)
' WORKS !!! :)
Print "VARADDR(people(1))=0x"; Hex$(Peek(VARADDR people(1)))
Print "VARADDR(people(2))=0x"; Hex$(Peek(VARADDR people(2)))
' WORKS, TOO !!! :)
' Could make Struct(SIZE, typeArray() [, dimension]) obsolete !!!
Print Bound(people(),1)
End
Nevertheless, I would be very happy if you could add `Struct(OFFSETOF, "type,member")`! I'm almost certain that the information is already stored internally, since you need the offset when accessing the struct member.
And as shown above:
`Struct(SIZE, typeArray() [, dimension])` could be omitted, since `Bound(typeArray() [, dimension])` fortunately also works!
I wish you, Peter, and also you, Geoff, and everyone else here a happy new year! Stay healthy and well!
Posted: 08:35pm 31 Dec 2025
wots records? sums my experience. it's not basic anymore
Posted: 09:00pm 31 Dec 2025
Records are mentioned in the MMBasic manual. SD Card Support section, Random Access Files.
A Record is a string, which may contain several pieces of data packed into it. It is accessed by its "record number".
I first used them in Disk BASIC on the Tandy Model 1 so they are definitely in BASIC. :)
Posted: 09:17pm 31 Dec 2025
sorry I feel not worthy of mmbasic as I'm too dum.. to dim. thanks again matherp/peter. turtle graphics rings a bell for school kids in the '80's
Posted: 09:42pm 31 Dec 2025
Oh, don't bother about that. I doubt if I'll ever use a lot of it. The MATH stuff and regular expressions in particular mangle my brain cells. :)  BBC BASIC supported Turtle graphics so you'll have probably seen mention of it in relation to that.
One thing I always liked on the BBC was Mode 7 teletext graphics. I always liked the teletext pictures. :)
bfwolf
Posted: 09:51pm 31 Dec 2025
  stanleyella said  wots records? sums my experience. it's not basic anymore
Hey Stan,
"RECORDS" are data that belong together — either stored on a storage medium (floppy disk, hard disk, USB stick) in a file system — or in RAM in variables. This doesn't initially have anything to do with the programming language. In Pascal, however, there's a data type called "RECORD" that can represent this well. In C, it's called a 'struct'(ure) — and in QBasic and Visual Basic, it's always been, and in MMBasic it will be in future 'Type...End Type'. Nothing special about it.
As I've said several times already: Don't worry about it — everything will continue to work without "structs." You can use them in the future, but you don't have to. No reason to cry.
Do you also cry when your car comes with a radio "for free", even though you don't need it? You can still drive even if the radio isn't on.
Happy new year!
Posted: 10:42pm 31 Dec 2025
Happy new year! and I got a 12v car radio 4 speakers, and cd, usb and ssd slot which I used for domestic home sound  but thought the display was small and how you drive a car pissin with the display and not crash. I use a a pc for watching films or music and 2 Wharfdale speakers . all films care of pirate proxy. I'm too old to care.
make this simple code structured, it does run
'option autorun on
OPTION BASE 0        ' 0 based arrays
option DEFAULT INTEGER
OPTION EXPLICIT
mode 2
dim dx(15),dy(15),spx(15),spy(15)
dim cannon(119),missile(15),oldspx(15),oldspy(15)
dim ptr,hiscore,spw,spht,temp,frame,frame_count,spdata,sp1
hiscore=0
'colour shortcuts
const WH =RGB(255,  255,  255) 'WHITE
const YE =RGB(255,  255,    0) 'YELLOW
const LI =RGB(255,  128,  255) 'LILAC
const BR =RGB(255,  128,    0) 'BROWN
const FU =RGB(255,  64,   255) 'FUCHSIA
const RU =RGB(255,  64,     0) 'RUST
const MA =RGB(255,  0,    255) 'MAGENTA
const RE =RGB(255,  0,      0) 'RED
const CY =RGB(0,    255,  255) 'CYAN
const GR =RGB(0,    255,    0) 'GREEN
const CE =RGB(0,    128,  255) 'CERULEAN
const MI =RGB(0,    128,    0) 'MIDGREEN
const CO =RGB(0,    64,   255) 'COBALT
const MY =RGB(0,    64,     0) 'MYRTLE
const BL =RGB(0,    0,    255) 'BLUE
const Bk =RGB(0,    0,      0) 'BLACK
const Gy =RGB(128,  128,  128) 'GREY
const Lg =RGB(210,  210,  210) 'LITEGREY
const Og =RGB(255,  165,    0) 'ORANGE
const PK =RGB(255,  160,  171) 'PINK
const Gd =RGB(255,  215,    0) 'GOLD
const SA =RGB(250,  128,  114) 'SALMON
const BE =RGB(245,  245,  220) 'BEIGE
restore
cls
udg1 'draws sprite1 on screen at 10,10
blit READ 1,10,10,16,16 'reads sprite1 from screen to blit buffer1
udg1 'draws sprite2 on screen at 10,10
blit read 2,10,10,16,16 'reads sprite2 from screen to blit buffer2
cls
blit read 3,10,10,16,16 'reads 16x16 background to blit buffer3
for temp=0 to 15 'set up start sprite positions and directions
do
 dx(temp)=(int(rnd*4)+1)-(int(rnd*8)+1)
loop until dx(temp)<>0
do
 dy(temp)=(int(rnd*4)+1)-(int(rnd*8)+1)
loop until dy(temp)<>0
 spx(temp)=104+((rnd*64)+1)
 spy(temp)=144+((rnd*64)+1)
next temp
FRAMEBUFFER CREATE F
FRAMEBUFFER WRITE f
do 'demo moving sprite
cls
   for temp=0 to 15
'        if sprite_status(temp)=1 then 'is sprite active
           if spx(temp)> 300 then 'check right edge
             dx(temp)= 0-dx(temp)
           elseif spx(temp)<8 then 'check left edge
           end if
           if spy(temp)>220 then 'check bottom edge
             dy(temp)= 0-dy(temp)
           elseif spy(temp)<8 then 'check top edge
           end if
           'oldspx(temp)=spx(temp):oldspy(temp)=spy(temp) 'get last position for erase
           spx(temp)=spx(temp)+dx(temp):spy(temp)=spy(temp)+dy(temp) 'get new position for draw
               if frame=0 then'which sprite to draw
                 'box oldspx(temp),oldspy(temp),16,16,0,bk,1 'erase sprite at last position
                 'BLIT WRITE 3,oldspx(temp),oldspy(temp), 16, 16 'erase sprite at last position
                 blit WRITE 1,spx(temp),spy(temp) 'draw sprite1 at new position
               else
                 blit WRITE 2,spx(temp),spy(temp) 'draw sprite2 at new position
               end if
   next temp
FRAMEBUFFER COPY f,N
   frame_count=frame_count+1 'when to change sprite
   if frame_count=10 then
     frame=not frame
     frame_count=0
   end if
   pause 20
loop
sub udg1 'draws 16x16 data for blit to copy
 for spht=0 to 15
   for spw=0 to 15
     read sp1
     pixel spw+10,spht+10,sp1
   next spw
 next spht
end sub
'sprite1
data wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh
data bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk
data bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk
data bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk
data bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk
data bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk
data bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk
data bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk
data ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye
data ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye
data bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk
'sprite2
data bl,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,bl
data bk,bk,bl,wh,wh,re,bl,bk,bk,bl,re,wh,wh,bl,bk,bk
data bk,bk,bk,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,bk,bk,bk
data bk,bk,bk,bk,bk,ye,ye,bk,bk,ye,ye,bk,bk,bk,bk,bk
data bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk
data bk,bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk,bk
data bk,bk,bk,ye,ye,bk,bk,bk,bk,bk,bk,ye,ye,bk,bk,bk
data bk,bk,bk,bk,bk,ye,bk,bk,bk,bk,ye,bk,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bk,ye,bk,bk,ye,bk,bk,bk,bk,bk,bk
bfwolf
Posted: 12:02am 01 Jan 2026
  stanleyella said  Do you also cry when your car comes with a radio "for free", even though you don't need it? You can still drive even if the radio isn't on.
That was simply a hypothetical example of how something can have features you don't necessarily need, but which can be useful if you have a particular desire for them. If you don't need them, they don't (necessarily) hurt either.
I didn't mean to imply that you don't enjoy listening to music in your car, and even with a good sound system.
For example, I dread the day when all cars have keyless entry because it's easy for thieves to hack, and therefore many cars with keyless entry are stolen. That's one reason why I'm still driving my almost 20-year-old Fiat Panda... "Primitive technology, but it works."  Another reason: There still isn't a truly cheap small electric car.
  stanleyella said  make this simple code structured, it does run
'option autorun on
OPTION EXPLICIT
mode 2
hiscore=0
I don't see what there is to criticize about this program.
It's already "structured programming" because it doesn't use a "GOTO" command, but instead uses "IF... THEN... ELSE... ENDIF" and "FOR... NEXT" loops.
I've already tried to explain that "structured programming" has nothing to do with "data structures", or at least doesn't require the use of "data structures". If the programming language supports "data structures", it "makes life easier" — that's what I mean.
In that sense: You're welcome to continue programming everything the way you have been!
Greetings!
Addendum:
I don't know if the comedy "Dinner for One" is as popular in the UK as it is in Germany? I once heard from a colleague in the UK that it's "rather unknown" there, even though it was made by well-known British comedians.
Anyway, at the end of the party for her deceased friends, the 90-year-old "Miss Sophie" says to her butler (who had to represent all her friends and drink for them): "I think I'll retire now..."  - that's what I'll do now too..
Edited 2026-01-01 10:12 by bfwolf
Posted: 03:22am 01 Jan 2026
"STRUCT EXTRACT" works well and makes the code simpler and more readable. There was a very slight performance drop but well worth it.
Testing on RP2040
Posted: 08:33am 01 Jan 2026
V6.01.00EXP5
PicoMiteRP2040V6.01.00EXP5.zip
PicoMiteRP2350V6.01.00EXP5.zip
StructTest.zip
Removes STRUCT(SIZE as BOUND works
Adds STRUCT(OFFSET
In addition changes the syntax of all struct functions to match other MMbasic functions so:
STRUCT(SUBFUNCTION parameters) NOT STRUCT(SUBFUNCTION,parameters)
See manual for details
Assuming no further bugs reported or sensible and generally useful enhancements requested this will be the last experimental version before 6.02.00RC0
Note: one user is reporting issues with XMODEM, can anyone confirm any problems? I can't replicate.
Edited 2026-01-01 18:55 by matherp
Posted: 08:56am 01 Jan 2026
@bfwolf
Yay!!! I *love* "Dinner for One" and have seen it many times. :)  No, it's not as popular here as it is in Germany where, I believe, it's close to being required viewing every year!
Happy New Year everyone. :)
Posted: 08:59am 01 Jan 2026
  Quote  Note: one user is reporting issues with XMODEM, can anyone confirm any problems? I can't replicate.
I don't see any problems with XMODEM or YMODEM.
I have been testing YMODEM on MMCC and have done a lot of testing.
karlelch
Posted: 10:24am 01 Jan 2026
  matherp said  Note: one user is reporting issues with XMODEM, can anyone confirm any problems? I can't replicate.
I had reported a XMODEM problem but it had turned out to be some nuking/exchanging firmware effect. In any case, after clearing everything and using the latest experimental version, XMODEM worked.
Happy New Year!
Best
Thomas
Posted: 10:38am 01 Jan 2026
  matherp said  V6.01.00EXP5
StructTest.zip
Adds STRUCT(OFFSET
Peter,
Unless I am mistaken the RP2040 non VGA, non USB version is missing from the ZIP (and the WEBMITE 2350 is double).
     Page 4 of 7
