Forum Index : Microcontroller and PC projects : PicoMite/VGA/WEB V5.07.08 release candidates
I was afraid you were going to say that, could you try this: FRAMEBUFFER Create FRAMEBUFFER Write F For i% = 0 To 309 Step 10 For j% = 0 To 229 Step 10 Box i%, j%, 10, 10,,RGB(Red) Next Next Do FRAMEBUFFER Copy F, N, B Pause 100 Loop I'm using RC4: OPTION CPUSPEED (KHz) 252000 OPTION LCDPANEL ILI9341, RLANDSCAPE,GP2,GP1,GP0 Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Is some "are you alive" signal being regularly sent to the SD card (same SPI channel) and ending up on the display? It only seems to happen if the SD card is inserted, and only after the first SD card operation. Tom Edited 2023-09-28 21:46 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| TheMonkeys Regular Member Joined: 15/12/2022 Location: AustraliaPosts: 59 |
Hi all, 35 minutes and 43 seconds. This is the consistent time between each watchdog restart and the subsequent freeze. The last version that worked without doing this for me was V5.07.08B11. V5.07.08B15, V5.07.08RC1, V5.07.08RC3 and V5.07.08RC4 subsequently installed and all display this symptom. No significant changes to my code in that time apart from trying: option udp server port 0 which made no difference. Just in case there was a tokenization issue I have re-transferred the basic source file several times.🥴 What have I missed? 🥴 Cheers, Chris. |
Duplicate post deleted. Edited 2023-09-28 21:46 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Yes. That will be it, I did say I hadn't put any sort of interlocks on and had forgotten that the SD card polls in order to see if the card has been removed. Will think about it |
Speaking about the SD card: for the Waveshare 320x240 TFT (ST7789) display, I cannot get the SD card working anymore. Not sure from which beta on it stopped working. With the newest release candidate, I get this: > update firmware WebMite MMBasic Version 5.07.08RC4 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > OPTION SYSTEM SPI GP10,GP11,GP12 WebMite MMBasic Version 5.07.08RC4 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > OPTION SDCARD GP22 WebMite MMBasic Version 5.07.08RC4 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > b: > files Error : SD Card not found > I did a clear flash before uploading the new firmware and the SD card seems fine; it reads correctly in a Windows PC and did work as B: before. Thanks Thomas |
Have you set up the touch controller? If not the SDcard won't work |
Ups ... That was is. I stopped setting it because I wanted to minimize the number of options to find out, why the firmware crashes from time to time (related to aforementioned WebMite stability issues). Never thought that would be needed for the SD card ... Thanks! |
MISO is shared by all devices on the bus. If the touch controller isn't initialized it holds MISO low blocking other inputs. Adding a pullup resistor to T_CS might prevent this. I will try it out later. Edit. Tried OPTION TOUCH DISABLE on ILI9341 but it made no difference. SD card and BLIT still work without a pullup on T_CS. Disconnect / reconnect power and it all still works. Perhaps the result of a floating T_CS pin is a lottery. Someone who has the problem will need to try this. Edit 2. Found a panel where OPTION TOUCH DISABLE does affect things. Adding a 10k from 3.3V to T_CS restores normal operation. Leaving it in place when OPTION TOUCH is restored does not affect the operation of touch. So install one and you won't need to worry about what options are set. Edited 2023-09-29 10:51 by phil99 |
This should fix the SDcard/backgound copy issue PicoMite.zip |
That does seem to have fixed the problem. Thank you Peter. Have you had time to ponder @vegipete's suggestion for rolling BLIT COMPRESSED into BLIT MEMORY and instead encoding whether the sprite is compressed or not at the start of the sprite data ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Try this - completely untested In theory if you set the top bit in the w/h word then the following data will be treated as compressed in BLIT MEMORY. BLIT COMPRESSED is still there and should still work PicoMite.zip |
Weight/Height Ratio ? EDIT: D'Oh width/height Edited 2023-09-29 23:24 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
width height. the first word in each sprite |
Thanks Peter, I haven't had a chance to test yet but will strive to do so over the weekend. I don't suppose there is any possibility of you providing me with early access to these last two changes either by pushing them up to GitHub or out-of-band so that this weekend I can build a PETSCII Robots compatible version of the Game*Mite firmware for @Martin H and others ? Best wishes, Tom Edited 2023-09-30 01:42 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
G'day all, Is there a list of the functions and commands that the WebMite cannot do compared with the PicoMite. It would be handy if it were near the beginning of both manuals? For completeness the converse might be handy but that is a fairly long list. My understanding is that it is the GUI commands in the 'Advance Graphics' section of the PicoMite manual. Some GUI commands are still available, eg for TOUCH calibration etc. Are all 'normal' graphics commands still available? Cheers, Andrew |
Picomite error when starting program Error: Invalid address - resetting A subsequent restart runs OK. It appears to be caused by trying to write to the framebuffer f. If I include "Framebuffer write n" in the shutdown sequence, there are no errors. This only happens on a program that is trying to use all available RAM. RC4 but I didn't try earlier versions. Jim VK7JH MMedit |
| carlschneider Senior Member Joined: 04/08/2023 Location: South AfricaPosts: 158 |
In contemplating improving graphing stability and moving away from WEB TCP to WEB UDP I'm trying the UDP side of the Webmite. Curious occurrence where the WEB UDP SEND just stopped working. No errors, no indications other than the UDP packets just stopped. I have Wireshark running and confirmed that the UDP and TCP stopped working. Wireshark shows No. Time Source Destination Protocol Length Info 16721 2023-09-30 09:37:15.069096 172.16.1.79 172.16.1.70 UDP 131 62417 → 81 Len=89 16742 2023-09-30 09:37:25.107070 172.16.1.79 172.16.1.70 UDP 131 62418 → 81 Len=89 16743 2023-09-30 09:37:35.037925 172.16.1.79 172.16.1.70 UDP 131 62419 → 81 Len=89 16744 2023-09-30 09:37:35.038079 172.16.1.70 172.16.1.79 ICMP 70 Destination unreachable (Port unreachable) 18377 2023-09-30 09:37:45.002892 172.16.1.79 172.16.1.70 UDP 131 62420 → 81 Len=89 18378 2023-09-30 09:37:45.003054 172.16.1.70 172.16.1.79 ICMP 70 Destination unreachable (Port unreachable) Looks like the WiFI module has fallen over given the ICMP destination unreachable packets. Did a Ctrl C and Option List and then F2 but still no UDP or TCP packets, on Wireshark. Then did a hard reset and now the UDP and TCP packets are flowing again, on Wireshark. The 60s interval Curl is being served by the WEB TCP Server and the WEB UDP SEND is on a 10s cycle. Maybe this helps your stability investigation Peter. Edited 2023-10-01 01:55 by carlschneider Cheers Carl Retirement is tough on Hobbies without a day job |
Bug in WebMite V5.07.08RC4? In File: MMtcpserver.c Line 578: SocketOut[SocketOutPointer++]=10; -> 13 CR SocketOut[SocketOutPointer++]=13; -> 10 LF SocketOut[SocketOutPointer++]=10; -> 13 CR SocketOut[SocketOutPointer++]=13; -> 10 LF SocketOut[SocketOutPointer]=0; led Edited 2023-10-01 10:39 by led-bloon Miss you George |
Hi Peter, It looks like PLAY MODFILE f$ will repeatedly play the .mod file ? and does not support the optional 'interrupt' parameter of PLAY WAV or PLAY FLAC so you can't manually stop it when it completes ? Could this be addressed ? Thanks, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
