Local Time 16:44 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Would SomeBody Try ........
     Page 4 of 4
hitsware2
Posted: 12:28am 09 Mar 2023
  JohnS said  Connected to the Pi4 you have the Pico (via USB) and what is connected as your Pi terminal/console? What's displaying the bad stuff you see & how is it connected?
RPi 400 ...... USB ........ Pico ...... VGA monitor ( known good )
RPi 400 ...... ( keyboard with built in RPi 4 B ) ..... HDMI .......HDMI monitor
HDMI monitor shows faulty editor
my site
Posted: 03:16am 09 Mar 2023
It seems the manual is out of date and OPTION DISPLAY no longer works at all, even after OPTION LCDPANEL NOCONSOLE.
OPTION LCDPANEL CONSOLE 2 may be more readable on the VGA screen, but don't know if it will make your terminal any better.
hitsware2
Posted: 03:33am 09 Mar 2023
  phil99 said  It seems the manual is out of date and OPTION DISPLAY no longer works at all, even after OPTION LCDPANEL NOCONSOLE.
I do not understand why the console screen
must use the same format as the display screen ....
( But there are many things I do not understand )
I will wait for a uPython VGA scheme or perhaps BBCBasic ?
Evidently something with the RPi decludes the simplicity
I want .
my site
Posted: 07:23am 09 Mar 2023
  matherp said  The VGA version can only support the character width and height that matches the VGA screen. Hence OPTION DISPLAY is disabled. It sends to the serial terminal commands to configure the terminal to the correct format. If you terminal program does not accept those commands you will have a problem. Teraterm and Putty on Windows both accept the commands.
hi peter,
   is there any reason why the editor on the VGA screen can not accept OPTION DISPLAY height, width provided height and width are both equal to or less than the dimensions supported on the VGA screen? if either value were less than, the editor would just need to use a smaller area of the screen. ie, for a 24-line setting the editor would only use lines 9 to 32 on the VGA screen; for a 64-column setting the editor would only use columns 9 to 72 on the VGA screen. no matter what, the editor would still always use from the top left corner on the serial terminal.
rob   :-)
Edited 2023-03-09 17:25 by robert.rozee
Posted: 08:00am 09 Mar 2023
I'm now away but may be able to try it next week - snow allowing.
My feeling is it will be to do with the TERM or X settings for your Pi console (the one shown on the HDMI). That is, I think it's nothing to do with the Pico or putty (or screen) but rather your console (terminal window).
I use konsole & TERM=xterm or xterm-256color and then all just works.
Edited 2023-03-09 18:02 by JohnS
Posted: 08:39am 09 Mar 2023
Hi Hitsware,
Is it so hard to set the editor screen on the Pi4 to 80x40 (the terminal) ? When using Putty, the serial terminal automatically adjusts to size required.
I feel you are trying to make sure the VGA screen and the terminal on the Pi4 show an identical picture. That will only happen when the terminal screen is adjusted to match the VGA screen.
Posted: 11:22am 09 Mar 2023
If I have understood @hitsware2 the VGA screen won't be used for console or editor, just graphic display.
If OPTION DISPLAY preceded by OPTION LCDPANEL NOCONSOLE worked as described in the manual it would probably do the job.
Posted: 11:29am 09 Mar 2023
I will change the firmware so that AFTER you have set OPTION DISPLAY NOCONSOLE you can then set OPTION DISPLAY
Posted: 11:53am 09 Mar 2023
Thank you, I think he and perhaps others would appreciate that.
hitsware2
Posted: 04:06pm 09 Mar 2023
! N O !
I want to use the screen on the Pi4 to program what appears on the VGA screen .
my site
Posted: 05:19pm 09 Mar 2023
You can write the PicoMite program on the RPi but you can't see its VGA output on the RPi. That has to go to a VGA-compatible display.
Posted: 05:42pm 09 Mar 2023
I don't think any of us really understand what you are trying to achieve. The PicoMiteVGA is basically intended as a stand-alone device with a local keyboard and screen. However, it does also support a remote serial terminal. In this case it expects the terminal to be the same same character resolution as the screen and tries to help with this by sending the terminal the escape sequence that resizes it to match. If they don't match then editing on one or the other will go badly wrong (lines wrapping differently etc.)
If you simply want to edit on a remote computer and use the Pico as an intelligent VGA display then if you wait for the next beta this will be easier.
  Quote  I will change the firmware so that AFTER you have set OPTION DISPLAY NOCONSOLE you can then set OPTION DISPLAY
Setting NOCONSOLE means that command line I/O and edits and PRINT statements won't appear on the VGA display but all graphics commands (including TEXT) will. After disabling the console you will then, in the next beta, be able to set the terminal size to anything you want with OPTION DISPLAY.
hitsware2
Posted: 08:28pm 09 Mar 2023
Simply to use a VGA monitor in the same way
as a LCD display is used with the non-VGA version .
I . E .....
circle x , y , r
On the PC ...... using the editor ( PC HDMI screen )
( with same characteristics as non-VGA editor )
draws a circle on the VGA screen ...
my site
Posted: 10:35pm 09 Mar 2023
From power-up:
If your terminal is set up correctly you should be seeing the ">" prompt on both your terminal and on the VGA screen. The terminal is seeing the console output, the VGA screen is seeing the Mode 1 graphics screen in command mode.
If you now give a simple graphics command like BOX 5,5,30,30 a box will appear on the VGA screen but not on the terminal as that isn't a graphics device.
The terminal is sending keystrokes to the PicoMite which is decoding them and treating them in a similar (not identical) way to an attached PS/2 keyboard. The PicoMite does not send any graphics data back to the console.
If you press F4 to enter the editor you will get the editor screen on both monitors. If you have OPTION COLOURCODE ON then command words appearing on the VGA monitor only will be in colour.
hitsware2
Posted: 11:21pm 09 Mar 2023
  Mixtel90 said  From power-up:
Thank You ....
I will wait for the next version and hope the terminal
works with it's default settings ( as it does now with the non - VGA version )
Sort of like using only 1 resistor ..... Call me a Purist
my site
Posted: 08:12am 10 Mar 2023
You can use a PicoMite VGA as its designed to be used, of course. It doesn't need a console terminal at all, just a VGA monitor and a PS/2 keyboard. If you happen to have a console with keyboard (a Raspberry Pi running terminal emulator software for example) connected then you can ignore that display as everything important will happen on the VGA display. The keyboard will act more or less as if it's connected directly to the PicoMite. Basically, it doesn't matter in the least what the console terminal displays, it's irrelevant. I say "more or less" as the terminal keyboard is slower than the PS/2 one.
You can't get more pure than leaving the Raspberry Pi out of the loop and using a PS/2 keyboard. :)
If you want to program using MMEdit then that's different. It runs on a computer that's connected to the PicoMite and is actually a terminal IDE in its own right. It effectively replaces the editor.
Of course, if you wanted to be pure as the driven snow (which we had rather a lot of last night) then Design #3 would be nice, with surplus video resistors omitted if you insist. ;)  I am completely unbiased, of course. :)
Edited 2023-03-10 19:37 by Mixtel90
Posted: 12:03pm 10 Mar 2023
I . E .....
circle x , y , r
That works OK for me. I have no idea why it doesn't work OK for you :(
Well, I sort of do - it pretty much has to be what I posted before: some setting you have on the Pi4 that's out of step with what you need.
Are you running your terminal emulator (putty?) from a "konsole"?
What's your TERM setting when you do?
Edited 2023-03-10 22:03 by JohnS
hitsware2
Posted: 04:03pm 10 Mar 2023
On a RPi 4 ?
SCREEN , but the result is the same with putty
24 x 80 ( default ) ..... font 16
my site
     Page 4 of 4
