Local Time 18:54 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.03 betas - major update
     Page 4 of 4
Posted: 03:27am 30 Dec 2021
Suggestion for a possible extension to:
OPTION COLOUR VGA OFF
To allow the same hardware to be used for both colour and monochrome in any colour would it be possible switch in extra video output pins in mono mode?
eg
OPTION COLOUR VGA OFF, GP18, GP19, GP20 ,GP21
If any/all of the above pins could be selected then the full RGB(1,2,1) range would be available. If no pins are entered the current default would apply. This way there is no need for an emitter follower to get white.
Does anyone think this is worth Peters time and effort?
Posted: 07:55am 30 Dec 2021
  Quote  To allow the same hardware to be used for both colour and monochrome in any colour would it be possible switch in extra video output pins in mono mode?
Not possible. Each pin needs a bit in the framebuffer to drive the PIO routine
Posted: 11:40am 30 Dec 2021
Ok, thanks for looking at it Peter. Plug-in modules will do the job.
mobluse
Posted: 09:00pm 30 Dec 2021
  matherp said  The syntax (manual page 75) is:
BITBANG WS2812 type, pin, nbr, value%[()]
for the Maker Pi Pico use:
BITBANG WS2812 O, GP28, 1, value% or RGB(whatever)
The syntax in the manual page 75 is correct but the description needs amending to mention the case of a single LED
This worked, but the documentation for Maker Pi Pico says it is WS2812 B, and that also works, see page 2 in https://cdn-shop.adafruit.com/product-files/5160/5160_Maker+Pi+Pico+Datasheet.pdf.
I ported an old program I originally wrote for TinyBASIC (32 bit) to PicoMiteVGA MMBasic Version 5.07.03b4: Aritm, a mental calculation trainer:
https://github.com/mobluse/aritmjs/blob/master/aritm-mm.bas. That uses the RGB LED and audio on Maker Pi Pico Rev1.2 by Cytron.
Maker Pi Pico Rev1.2, DuinoMite-Mini, Raspberry Pi 0-4, iCE40HX8K, Arduino Uno, VM111, STK500, ZX81
Posted: 10:34pm 30 Dec 2021
Hi Peter,
Use of argument/wildcard with FILES command appears to have stopped working, I'm 99.99% sure it was working previously:
> ? MM.Info(Device)
PicoMite
> ? MM.Info(Version)
5.070304
> files
A:/
  <DIR>  cmm2-basic-challenge
  <DIR>  cmm2-forth
  <DIR>  cmm2-fun
  <DIR>  kingdom
  <DIR>  mmbasic-polar-snake
  <DIR>  mmbasic-scratch
  <DIR>  saaint-private
  <DIR>  saaint-public
  <DIR>  sptools
  <DIR>  zmim
       64  buzz.bas
     1922  fileview.bas
    40588  kingdom_pico_led.bas
    40335  kingdom_pico_led_2.bas
     3483  spi_led.bas
    12637  tst_mminfo.bas
10 directories, 6 files
> files "*"
A:/
0 directories, 0 files
> files "*.bas"
A:/
> files "buzz.bas"
A:/
Edited 2021-12-31 08:34 by thwill
Posted: 10:51pm 30 Dec 2021
Works in DIR$ never in FILES
Posted: 11:50pm 30 Dec 2021
  matherp said  Works in DIR$ never in FILES
Then what are lines 880-883 of FileIO.c for ?
if(*cmdline)
 p = getCstring(cmdline);
else
 p = "*";
Like I said I'm pretty certain this was working earlier.
Also note the source on GitHub contains two FileIO.c files with different name capitalisations.
     Page 4 of 4
