Forum Index : Microcontroller and PC projects : Armmite H7: Full release & documentation
ah! sorry - our posts crossed. a memory leak perhaps? given the consistency of the fail? |
In the meantime... I have converted the pin labels from TassyJims spreadsheet into a block of Consts so the pins on the nucleo board can be programmed using the labels in your code (and the Arduino ones too). You can now program any pin using either the ST terminology, the arduino terminology or the Morpho connector and pin. You'll still need to use eother Jim's spreadsheet for a detailed description of function or the Microcontroller PDF (which is heavier fodder) to decide which pins are best suited to your project. use these just as normal, e.g. SetPin PE2,DIN,PULLUP x=Pin(CN11_46) etc Const PE2=1,D56=1,CN9_14=1,CN11_46=1 Const PE3=2,D60=2,CN9_22=2,CN11_47=2 Const PE4=3,D57=3,CN9_16=3,CN11_48=3 Const PE5=4,D58=4,CN9_18=4,CN11_50=4 Const PE6=5,D59=5,CN9_20=5,CN11_62=5 Const PC13=7,CN11_23=7 Const PC14=8,CN11_25=8 Const PC15=9,CN11_27=9 Const PF0=10,D68=10,CN9_21=10,CN11_53=10 Const PF1=11,D69=11,CN9_19=11,CN11_51=11 Const PF2=12,D70=12,CN9_17=12,CN11_52=12 Const PF3=13,A3=13,CN9_7=13,CN12_58=13 Const PF4=14,A8=14,CN10_11=14,CN12_38=14 Const PF5=15,A4=15,CN9_9=15,CN12_36=15 Const PF6=18,CN11_9=18 Const PF7=19,D62=19,CN9_26=19,CN11_11=19 Const PF8=20,CN11_54=20 Const PF9=21,D63=21,CN9_28=21,CN11_56=21 Const PF10=22,A5=22,CN9_11=22,CN12_42=22 Const PH0=23,CN11_29=23 Const PH1=24,CN11_31=24 Const PC0=26,A1=26,CN9_3=26,CN11_38=26 Const PC1=27,CN11_36=27 Const PC2=28,A7=28,CN10_9=28,CN11_35=28 Const PC3=29,A2=29,CN9_5=29,CN11_37=29 Const PA0=34,D32=34,CN10_29=34,CN11_28=34 Const PA1=35,CN11_30=35 Const PA2=36,CN12_35=36 Const PA3=37,A0=37,CN9_1=37,CN12_37=37 Const PA4=40,D24=40,CN7_17=40,CN11_32=40 Const PA5=41,D13=41,CN7_10=41,CN12_11=41 Const PA6=42,D12=42,CN7_12=42,CN12_13=42 Const PA7=43,D11=43,CN7_14=43,CN12_15=43 Const PC4=44,CN12_34=44 Const PC5=45,CN12_6=45 Const PB0=46,D33=46,CN10_31=46,CN11_34=46 Const PB1=47,A6=47,CN10_7=47,CN12_24=47 Const PB2=48,D27=48,CN10_15=48,CN12_22=48 Const PF11=49,CN12_62=49 Const PF12=50,D8=50,CN7_20=50,CN12_59=50 Const PF13=53,D7=53,CN10_2=53,CN12_57=53 Const PF14=54,D4=54,CN10_8=54,CN12_50=54 Const PF15=55,CN12_60=55 Const PG0=56,CN11_59=56 Const PG1=57,D64=57,CN9_30=57,CN11_58=57 Const PE7=58,D41=58,CN10_20=58,CN12_44=58 Const PE8=59,D42=59,CN10_18=59,CN12_40=59 Const PE9=60,D6=60,CN10_4=60,CN12_52=60 Const PE10=63,D40=63,CN10_24=63,CN12_47=63 Const PE11=64,D5=64,CN10_6=64,CN12_56=64 Const PE12=65,D39=65,CN10_26=65,CN12_49=65 Const PE13=66,D3=66,CN10_12=66,CN12_55=66 Const PE14=67,D38=67,CN10_28=67,CN12_51=67 Const PE15=68,CN12_53=68 Const PB10=69,D36=69,CN10_32=69,CN12_25=69 Const PB11=70,D35=70,CN10_34=70,CN12_18=70 Const PB12=73,D19=73,CN7_7=73,CN12_16=73 Const PB13=74,D18=74,CN7_5=74,CN12_30=74 Const PB14=75,CN12_28=75 Const PB15=76,D17=76,CN7_3=76,CN12_26=76 Const PD8=77,CN12_10=77 Const PD9=78,CN11_69=78 Const PD10=79,CN12_65=79 Const PD11=80,D30=80,CN10_23=80,CN12_45=80 Const PD12=81,D29=81,CN10_21=81,CN12_43=81 Const PD13=82,D28=82,CN10_19=82,CN12_41=82 Const PD14=85,D10=85,CN7_16=85,CN12_46=85 Const PD15=86,D9=86,CN7_18=86,CN12_48=86 Const PG2=87,D49=87,CN8_14=87,CN11_42=87 Const PG3=88,D50=88,CN8_16=88,CN11_44=88 Const PG4=89,CN12_69=89 Const PG5=90,CN12_68=90 Const PG6=91,CN12_70=91 Const PG7=92,CN12_67=92 Const PG8=93,CN12_66=93 Const PC6=96,D16=96,CN7_1=96,CN12_4=96 Const PC7=97,D21=97,CN7_11=97,CN12_19=97 Const PC8=98,D43=98,CN8_2=98,CN12_2=98 Const PC9=99,D44=99,CN8_4=99,CN12_1=99 Const PA8=100,CN12_23=100 Const PA9=101,CN12_21=101 Const PA10=102,CN12_33=102 Const PA11=103,CN12_14=103 Const PA12=104,CN12_12=104 Const PA13=105,CN11_13=105 Const PA14=109,CN11_15=109 Const PA15=110,D20=110,CN7_9=110,CN11_17=110 Const PC10=111,D45=111,CN8_6=111,CN11_1=111 Const PC11=112,D46=112,CN8_8=112,CN11_2=112 Const PC12=113,D47=113,CN8_10=113,CN11_3=113 Const PD0=114,D67=114,CN9_25=114,CN11_57=114 Const PD1=115,D66=115,CN9_27=115,CN11_55=115 Const PD2=116,D48=116,CN8_12=116,CN11_4=116 Const PD3=117,D55=117,CN9_10=117,CN11_40=117 Const PD4=118,D54=118,CN9_8=118,CN11_39=118 Const PD5=119,D53=119,CN9_6=119,CN11_41=119 Const PD6=122,D52=122,CN9_4=122,CN11_43=122 Const PD7=123,D51=123,CN9_2=123,CN11_45=123 Const PG9=124,D0=124,CN10_16=124,CN11_63=124 Const PG10=125,CN11_66=125 Const PG11=126,CN11_70=126 Const PG12=127,CN11_65=127 Const PG13=128,CN11_68=128 Const PG14=129,D1=129,CN10_14=129,CN12_61=129 Const PG15=132,CN11_64=132 Const PB3=133,D23=133,CN7_15=133,CN12_31=133 Const PB4=134,D25=134,CN7_19=134,CN12_27=134 Const PB5=135,D22=135,CN7_13=135,CN12_29=135 Const PB6=136,D26=136,CN10_13=136,CN12_17=136 Const PB7=137,CN11_21=137 Const PB8=139,D15=139,CN7_2=139,CN12_3=139 Const PB9=140,D14=140,CN7_4=140,CN12_5=140 Const PE0=141,D34=141,CN10_33=141,CN12_64=141 Const PE1=142,CN11_61=142 enjoy |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12085 |
I'll include this in the manual if that is OK? |
This should fix the string bug. The interesting thing is that the relevant code was identical to the MM2, MM+, MMX and Pi-cromite. All of the Pi-cromite, MMX and the Armmite have the problem. Common factors are they all have a memory cache and they all use later versions of the GCC compiler than the one used by Geoff - not sure what is causing the problem but a variable updated in one routine was being used incorrectly in another despite declaring it "volatile" which should cause the compiler to avoid optimising access to it. 2018-09-26_021728_Armmite1.3.zip 2018-09-26_022332_Armmite_H7_Manual.pdf |
absolutely |
Thanks Peter, that seems to have sorted it. I left it spinning with a screen scroll-back of 20K lines and waited for it to fill then did the same with the original test prog that is a degree more complex all with no errors. u da bes' |
I have had a couple of hang-ups from the terminal session during testing which I put down to USB problems, dodgy cables getting nudged etc. seen it all before. But tonight I have determined these are actually crashes. I set a test program running and left it and when I came back the console was non-responsive. This time I closed and re-opened and the terminal connected OK which discounted any USB problem (it would have complained about "COMx not available"). So I set the test program to toggle the red LED and after a power cycle set it going, this time if it dropped off I could tell if the program was still running despite the unresponsive console. Sorry to say the LED stops flashing as the terminal goes away so it looks like I am getting a system crash. Oddly, it requires a complete power cycle - The reset button doesn't bring it out of the coma. Even taking GND to the NRST pin on CN11 or direct to pin 25 on the processor doesn't work, only a power cycle. Some corruption that stops a warm boot from working? Any ideas? Anyone else getting this or does it stay up for days for you? regards h EDIT: Forgot to attach the code if anyone else wants to try 2018-09-26_060652_code.zip |
One thing I had noticed is the occasional character being sent to the console gets converted to a backspace. I thought it was just MMEdit but the same random thing happens with teraterm. What you see will depend on how the terminal program handles backspace characters. It appears at random intervals. Haven't tried the latest firmware yet. Jim VK7JH MMedit |
Thank you, that will be a great help to me in these early stages. I'm also having trouble reading the board pins, I searched for a large clear connector pin-out layout but haven't found any as yet, I'm just going to take a photo of the board, enlarge it and print it, seems to be all I can come up with for now. Al least my simple LED flasher and user button interrupt are working correctly with autorun playing along now. Thanks to all. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Is my memory going? I thought pressing the reset button used to display the MM.BASIC copyright notices? NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
It does. If everything is working OK. EDIT: [Quote=CaptainBoing]I have converted the pin labels from TassyJims spreadsheet into a block of Consts so the pins on the nucleo board can be programmed using the labels in your code (and the Arduino ones too). You can now program any pin using either the ST terminology, the arduino terminology or the Morpho connector and pin. You'll still need to use eother Jim's spreadsheet for a detailed description of function or the Microcontroller PDF (which is heavier fodder) to decide which pins are best suited to your project.[/Quote] Marvellous. Thanks. You've just saved me a heap of work, as I was about to do something similar so I could find the correct pins for things. Smoke makes things work. When the smoke gets out, it stops! |
? Stopped after the latest release was loaded from a few post back, and now no mm.basic copyright info. I'll go back and do a verify and see it something happened, otherwise I'll reload it and try again. I can't get out to get the required headers to connect anything up, I'll have to wait for my wife to get them tomorrow - sigh! NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Found the problem - try turning autorun on and pressing reset, in mine NO info is returned, turn autorun off and info returns when reset is pressed. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Problem fixed in V5.04.31 @keepIS If you have autorun set, you wouldn't want the opening credits to be displayed. It would likely get in the way of any program output. Jim VK7JH MMedit |
I'm used to the MM-Plus displaying that info when reset or power on is actioned, with or without autorun enabled, I have a CLS command at the start of every program for that. I'm quite happy to not see it with autorun enabled, just something I noticed. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
Hi TassyJim Can you know why MMedit stop download after 767 blocks (and micromite stop also) with armite?? I have 67% free memory (I have not tested with other card, because program is too big for them) thank! |
I easily downloaded an image file with 1801 blocks to my armite SDcard. I haven't tried loading a big program file direct into memory. Can you give me a copy of the file you are having trouble with and I will have a look. Jim VK7JH MMedit |
I have done some testing. I loaded a file "lunar_eclipse" as it was the largest I had. It is 2000 lines or ~600 blocks. It loaded with "load and run" successfully. I then added 2000 comments to the file bringing it up to 132k or 1052 blocks. With "load and run", it loaded fully the gave an error All Done! Saving program Error: Not enough memory for Cfunction I tried loading using AUTOSAVE and the same error occurred at the conclusion of the load. I then transferred the file to the SD card (using XMODEM) and tried load "test.bas" The same error: > NEW > load "temp.bas" Error: Not enough memory for Cfunction > memory Flash: 128K (49%) Program (3737 lines) 128K (51%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 498K (100%) Free > There are no CFUNCTIONS in the code I was loading. The file has 3993 lines but it has been truncated to 3737 lines. It looks like 128k is the maximum size program, not 512k. Jim VK7JH MMedit |
Check the manual for OPTION FLASHPAGES The manual for the Nucleo has good diagrams. You need "UM1974 - User manual STM32-144 boards" I thought this was what all Micromites did - I remember it being discussed on the forum some time ago. I can change it to display the notice if required - views? This probably all relates to the bug fixed in 5.04.31. Geoff included an optimisation recently that massively speeded up MMBasic when strings were used in code. I'd included this in the MMX, Pi-cromite and Armmite but for reasons unknown (compiler issue or cacheing artifact) it doesn't work on these processors (they all use the same compiler, latest version of GCC). Basically every time the code used a temporary string it took a slot out of 1024 available. Once these were used up it crashed. I've replaced Geoff's optimisation with a different one that does work. I've just run CaptainBoing's test code which hammers string handling all night and all was still working fine this morning. Note, if you use an external 5V supply to the Nucleo (details in the manual) you can disconnect the ST-link USB connector and it will keep runnning. You can then also connect a USB/UART to the console pins (PD8,PD9) and communicate with the board like a normal Micromite. |
Yes, that explains it. I will have to wait to see if that was the original problem. In the mean-time, I will read the manual. Jim VK7JH MMedit |
