Local Time 11:09 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICO PETSCII
     Page 37 of 38
Bleep
Posted: 07:09pm 04 Dec 2023
Hi Tom,
Thanks for that, I had just come across that problem, presumably there is a problem with a controller, because a qwerty keyboard only gives a single key, until it repeats, where as a controller repeats at the rate it is called.
Anyway, your code fix above subdues my Wii controller very well. Thanks. :-)
Regards, Kevin.
Posted: 02:40pm 05 Dec 2023
Still WIP but here is my latest based upon pet25l:
   pet25l-thwill-1.zip
Differences from pet25l:
- Requires 5.07.08b4
- Several messages titivated.
- Suppressed auto-repeat of user input EXCEPT for movement.
  e.g. to fire multiple times to the right now you would hold down A
       and explicitly press RIGHT multiple-times, not hold RIGHT down.
- Improved UI feedback on map:
  - Beeps when map button is activated.
  - Writes current map mode to message area.
  - Tried to reduce graphical glitch when entering map, there is
    still an issue where the player sprite is briefly shown over
    the map, perhaps someone more familiar with the graphics can fix.
- Initial controller determined by (case-insensitive) setting of
  OPTION PLATFORM:
    "Game*Mite"    => Game*Mite controller
    "PicoGAME VGA" => NES gamepad attached to Port A
    other          => Keyboard only
- This can be overridden irrespective of platform by setting the "controller"
  property in "A:/.spconfig" or "A:/.config", e.g.
    controller = "gamemite"
  or,
    controller = "nes-a"
  or,
    controller = "atari-a"
  Note that enabling "nes-a" or "atari-a" on the Game*Mite will report an
  ERROR because the expected pins are already allocated to the display.
- Game*Mite/NES controls redefined - still a WIP:
  - FIRE A           Acts as START on menu-screen
  - FIRE A + FIRE B  Quit, must be pressed twice within a short period
  - SELECT           Toggles between walk/search/move modes
  - START            Use item
  - UP
  - UP + FIRE A      Fire up
  - UP + FIRE B      Toggles weapons
  - DOWN
  - DOWN + FIRE A    Fire down
  - DOWN + FIRE B    Toggles items
  - LEFT
  - LEFT + FIRE A    Fire left
  - LEFT + FIRE B    Use item
  - RIGHT
  - RIGHT + FIRE A   Fire right
  - RIGHT + FIRE B   Map
TODO:
- Wii Classic gamepad support (referring to Kevin's code).
- SNES gamepad support (not that anyone, including myself has a working one).
- Controller responsiveness on intro menu.
- [Game*Mite only] intro menu return to Game*Mite menu.
- Continue to experiment with Game*Mite/NES button allocation.
- Issue with player frequently moving immediately after moving an object.
May not happen quickly though, I'm not sure how much free time I have for the remainder of the week.
Edited 2023-12-06 00:53 by thwill
Posted: 03:17pm 05 Dec 2023
What is the issue with the SNES controller. If I buy this for development use will it not be OK? The contents should just be a 16-bit shift register?
Edited 2023-12-06 01:18 by matherp
Posted: 03:26pm 05 Dec 2023
They should be fine, Peter. I have a cheap Chinese one here that doesn't appear to be a SNES controller although it looks like one. The buttons are multiplexed and, I suspect, the "black blob" may be a microcontroller and not a shift register. The "proper" ones should be correct.
Posted: 03:27pm 05 Dec 2023
@Tom,
Change
         Select Case map_mode
           Case 0
             FRAMEBUFFER write l:CLS col(5):FRAMEBUFFER write sc$ 'clear layer
             writeplayer(hp,vp,pl_wp)
             WriteComment("Map deactivated")
           Case 1
             WriteComment("Map activated")
             RenderLiveMap()
           Case 2
To
           Case 0
           Case 1
             RenderLiveMap()
           Case 2
Posted: 06:50pm 05 Dec 2023
Noted, I will take a look when I get an opportunity.
MarkF
Posted: 04:49am 06 Dec 2023
Oh. An issue with pet25l.bas version. I'm running RC17.
Looks like line nesPG1=0 has been removed.
That's okay, but...
pet25l.bas no longer works with the NES controller. If I use the keyboard instead the game hangs after the intro, on the [Loading] screen.
Posted: 06:18am 06 Dec 2023
I guess you need picomite 50800b4 how.
MarkF
Posted: 06:32am 06 Dec 2023
Ok Volhout. I will try then let you know.
Posted: 07:43am 06 Dec 2023
Mark are you using pet25l.bas from the beta thread or pet25l-thwill-1.bas from this thread?
MarkF
Posted: 08:53am 06 Dec 2023
Hi Tom. I am using "pet25l.bas" with PicoGame VGA and SNES controller.
I will upgrade the firmware to "50800b4" as Volhout suggested and try again.
Posted: 10:22am 06 Dec 2023
Hi Mark,
  MarkF said  Hi Tom. I am using "pet25l.bas" with PicoGame VGA and SNES controller.
Out of curiosity an original SNES controller or a modern cheap Chinese clone ?
  MarkF said  I will upgrade the firmware to "50800b4" as Volhout suggested and try again.
Depending on what version you were running I'm not sure that's going to matter, I think we will need more information to diagnose the hang.
  MarkF said  Looks like line nesPG1=0 has been removed ...
Yes, unfortunately the mainline got some of my changes before they were properly cooked.
For the moment I suggest "hacking it" by replacing line 13:
Const CTRL_DRIVER$ = init_controller$()
with:
' Const CTRL_DRIVER$ = "ctrl_none$" ' Uncomment for no controller
' Const CTRL_DRIVER$ = "ctrl_gamemite$" ' Uncomment for Game*Mite
Const CTRL_DRIVER$ = "ctrl_nes_a$" ' Uncomment for NES controller on
                                   ' PicoGAME VGA port A
If Call(CTRL_DRIVER$, 1) <> "" Then Error
and:
Function read_input$()
 read_input$ = read_inkey$()
 If Len(read_input$) Then Exit Function
 read_input$ = Call(CTRL_DRIVER$)
End Function
with:
 Static last$
 ' Suppress auto-repeat except for movement.
 If last$ = read_input$ Then
   If Not InStr("up,down,left,right", last$) Then
     read_input$ = ""
     Exit Function
 Else
   last$ = read_input$
End Function
@Volhout you might want to pull these changes into the mainline even if you don't adopt the rest of my work yet.
In future should I email you my changes so that this thread can lapse and all activity go into the beta thread ?
Edited 2023-12-06 20:26 by thwill
Posted: 04:01pm 06 Dec 2023
I am currently sick, and hope ypu will put these needed changes in mainstream petscii. Just create a pet25m.bas, for all to use with 50800b4 firmware.
In a few days when fever is gone, I'll take over again.
Edited 2023-12-07 02:02 by Volhout
MarkF
Posted: 01:20am 07 Dec 2023
Sorry to hear you are unwell Volhout. Get better soon.
MarkF
Posted: 01:21am 07 Dec 2023
ALL NEW POSTS TO NEW BETA THREAD:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16465
Edited 2023-12-07 11:27 by MarkF
Martin H.
Posted: 05:07pm 07 Dec 2023
  MarkF said  ALL NEW POSTS TO NEW BETA THREAD:
No
Things can be tried out here; in the topic you link, inconsistencies in the program flow are looked for compared to the existing versions.It's about beta testing, which Volhout and I can't do alone
Edited 2023-12-08 03:09 by Martin H.
'no comment
Bleep
Posted: 06:33pm 07 Dec 2023
Hi Harm & Martin,
I've made a small optimisation to writeworld, it only saves about 1.5mS but it all helps. :-)
Sub writeworld_n(xm,ym)
 For xn=-xm To xm
   xsn=xs+xn*24:xpn=xp+xn+1+lva
   For yn=-ym To ym
     'load tile from world map
     spn=Peek(byte(yp+yn)*129+xpn)
     Blit memory tile_index(spn),xsn,ys+yn*24
   Next
 Next
Regards, Kevin.
Posted: 07:39pm 07 Dec 2023
Hi Kevin,
Adopted in pet25n.bas, see main thread.
Posted: 08:00am 08 Dec 2023
Just a small observation...
When you "crunch" the program in MMEdit (take out all formatting and comments) you gain 10ms in the loop, and the program is only 40kb in size (from 70kb).
Not going there, but nice to know.
Posted: 08:27am 08 Dec 2023
There are a couple of places in the code where you aren't using INC where you could and a couple where CHOICE is faster than IF THEN ELSE. Don't know if they are in code that would make any difference.
One thing that could help is that string variables less than or equal to 9 characters could be specified with a length
e.g.
DIM s$ length 8
This saves 256 bytes of general memory and uses no extra variable memory.
You can safely use length for simple string variables > 9 characters but it has no impact they still take 256 bytes of general memory
     Page 37 of 38
