Local Time 18:49 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with LORA modules
srnet
Posted: 01:59pm 15 Sep 2017
What LoRa settings were you using ?
OA47
Posted: 02:55pm 15 Sep 2017
Srnet:
Here is the config screen. The only change I have made is the output power which was set at 20dbm out of the packet.
Posted: 03:08pm 15 Sep 2017
Cool, keep us updated!
You would probably increase reliability and range if you drop the "AirRate". It does depend on how many bytes you are sending though.
I eagerly await my 915MHz units to test.
srnet
Posted: 08:55pm 15 Sep 2017
Ah IC.
That effectivly just defines a baud rate, I would have an idea of the potential range if I knew the bandwidth, spreading factor and code rates in use.
davematt
Posted: 10:49pm 16 Sep 2017
Update...
With a 1/4 wave whip transmiiting from 3 metres up I could receive at ground level 3.5 km away, using a small yagi. This was not line of sight, but across open country with just small patches of bush intervening.
I am confident this could be improved, but I ran out of paddock
Message was a short sentence at 2400 baud, seemingly 100% reliable.
Pretty chuffed!
OA47
Posted: 11:19pm 16 Sep 2017
  Quote  With a 1/4 wave whip transmiiting from 3 metres up I could receive at ground level 3.5 km away, using a small yagi. This was not line of sight, but across open country with just small patches of bush intervening.
Pretty chuffed!
Dave, are you using the 433Mhz units? Your transmission distance is very encouraging.
Posted: 02:01pm 17 Sep 2017
Also, what output power? 10dBm? 20dBm?
Can I assume that you guys are running the modules at 3v3?
Still waiting on my ones to arrive.... *drool*
davematt
Posted: 05:39pm 17 Sep 2017
@Grogster, I'm using 20dBm, haven't investigated power consumption yet. I'm running from 3.3V, but thinking about it, runnning the radio direct from 1 lithium would make more sense. Thoughts anyone?
Bill7300
Posted: 09:50pm 17 Sep 2017
@Grogster, do you have a link to your source of the 915MHz modules?
Posted: 12:03am 18 Sep 2017
Sure, here you go:
915MHz version of module
Bill7300
Posted: 12:37pm 18 Sep 2017
Thanks. Interesting looking devices.
Posted: 11:08pm 18 Sep 2017
sort of related
https://www.sciencedaily.com/releases/2017/09/170913193030.htm
Posted: 01:33am 27 Sep 2017
My 915MHz modules have arrived. That's not bad - ten days or so airmail.
They even included two little USB-serial adaptors, which were not in the auction listing - nice touch, and I will use them around the workshop.
I hope to setup a test link with them in the next couple of days, and I also want to put one on the spectrum analyser to see what it's output it like.
OA47
Posted: 06:33am 27 Nov 2017
I need some help with my LoRa network. As discussed earlier I have set up an in field unit that has the SDI-12 probe interrogated by a Micromite and the information passed back to base over a virtual serial port using the LoRa radio link. This set up has worked flawlessly for some weeks sending back data requests every 10 minutes when polled by the base Visual Basic software.
The Micromite software has the console serial port connected to the radio (my original thoughts were that I could remotely access or modify the MMBasic software via this port) and the software is waiting at an INPUT prompt looking for the ID code of the unit and ignore if not the right one.
The problem I now have is that the network crashes if I have more than one remote unit listening and responding to the ID call. I first thought that I had issues with the power peaks required to transmit back and as mentioned by another poster, I put a 1000UF cap across the power leads of the LoRa units. This did not help so I decided to put a delay in the return transmission (up to 500mS) again no improvement.
I decided to have a play with the settings on the radios firstly dropping the power to the lowest possible and fiddled with other areas that I really don't have a good understanding of, mainly due to the very small amount of explanation in the handbook.
Any suggestions from shedders very welcome.
Graeme
OA47
Posted: 07:21am 27 Nov 2017
Had another thought that may lead to a solution. Something simple as usual. The non-ID units will be returning the ? prompt and clashing with real data. Was a good idea at the time
srnet
Posted: 08:06am 27 Nov 2017
  OA47 said  I decided to have a play with the settings on the radios firstly dropping the power to the lowest possible and fiddled with other areas that I really don't have a good understanding of, mainly due to the very small amount of explanation in the handbook.
I wrote a short introduction to LoRa and how the settings affect range here;
Long Distance Tracking and Monitoring with LoRa - Introduction
See 'What is LoRa?' on page 5
