Forum Index : Microcontroller and PC projects : Pi-Cromite 1B PCB...
| flip Senior Member Joined: 18/07/2016 Location: AustraliaPosts: 137 |
Cheers...done... |
Mine arrived today Grogs (12/9). Thanks very much - now to get it going. Greg |
| MikeO Senior Member Joined: 11/09/2011 Location: AustraliaPosts: 275 |
Arrived , Thank you. Mike Codenquilts |
Arrived yesterday ! Thank you for this nice PCB's Grogster. Dietmar |
Mine Arrived today, Thank you Grogster.. Much appreciated Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| astroboy Regular Member Joined: 28/12/2014 Location: AustraliaPosts: 41 |
Mine arrived on Monday. Thanks Grogster. Regards John |
| Bill7300 Senior Member Joined: 05/08/2014 Location: AustraliaPosts: 161 |
Since everybody else is reporting, I maybe should do the same. My pair arrived yesterday, thanks Grogs. Bill Bill |
Thanks for all the confirmations thus far, chums. ![]() I'd better build one myself then, hadn't I?! (rhetorical!) Smoke makes things work. When the smoke gets out, it stops! |
| RonnS Senior Member Joined: 16/07/2015 Location: GermanyPosts: 123 |
I got it yesterday, the PCB looks very good thank you very much Ron |
Help needed, i have ordered a 2.8" inch mit Touchscreen TFT LCD Display ILI9341 Arduino AVR CP11005 attached it to Grogs Backpack, used OPTION lcdpanel ILI9341,L,29,3,13. SPI LCD Poti is mounted also 33R Resistor. Can measure 3,3 an 4,7 Volts. Power upply via the oauter corner USB. Whatever i do, the Display stays dark, no output... Any suggestions, Tips for me? THX Atmega8 |
NO 4k7 Pullups soldered! > option list OPTION COLOURCODE ON OPTION LCDPANEL ILI9341, LANDSCAPE, 29, 31, 13 OPTION WAVETIME 1.222 > gui test lcdpanel > > GUI CHECKBOX #10, "rztrtz", 100, 100, 50, rgb(BLUE) > print mm.ver 5.04 > |
"" 2.8" inch mit Touchscreen TFT LCD Display ILI9341 Arduino AVR CP11005 "" is an parallel driven LCD ! not an SPI ! its not supported by the PiCromite but see here: http://www.thebackshed.com/forum/forum_posts.asp?TID=9771&get=last#109377 |
Ok, seems I have ordered the wrong display..;-((? |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12087 |
This display uses a 16-bit parallel I/F so not really do-able in the Pi and in any event Grogster's board doesn't have any connections for DB8-DB15. |
Peter, what kind of Display are you using in the post from 31. August? Do you have a source where to buy it? THX Dietmar |
I get them off ebay, search for ILI9341 2.8" just make sure the version you buy has the touch controller |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Hi Grogster, my PCB's arrived today - thank you very much! Frank |
My 2 came Friday as well...thanks Grogster. Phil |
| bigfix Senior Member Joined: 20/02/2014 Location: AustriaPosts: 132 |
My PCBs arrived yesterday - thanks ! Guenter |
No lost boards yet - that's good news. Smoke makes things work. When the smoke gets out, it stops! |
