Local Time 03:51 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Cutting 3mm threads....
disco4now
Posted: 01:06am 09 Mar 2017
I ordered this one to see what they are like.
Could not help myself
Gerry
F4 H7FotSF4xGT
Posted: 01:10am 09 Mar 2017
Please let us know how it goes!
redrok
Posted: 06:02am 09 Mar 2017
Hi All;
palcal;
The thread forming taps should be readily available.
Maybe the name is a bit different down under.
There are self tapping screws.
1. Thread Cutting Screw type for sheet metal.
The end of the screw has a sharp cutting edge
2. Thread Forming Screws look similar to the taps.
Bill7300;
1. The formed treads are similar to rolled threads in they are deformed metal.
2. Generally the thread is work hardened due to metal deformation.
3. The metal in the thread is denser due to compression.
4. Since no cutting is done there aren't stress induced cracks.
disco4now;
That looks like mine.
My machinist friend says that if tapping by hand you might want to
use a slightly larger drill bit than the recommended bit. He uses
his CNC mill which has perfect alignment. When hand tapping the
alignment my not be so accurate. The slightly larger drill bit
allows for less accurate alignment although the resultant threads
will be not as fully formed.
He also says that since switching to thread forming taps he has greatly
reduced the breaking of taps.
Personally, I have never broken any.
redrok AD0TJ
Jak Cuttle
Posted: 03:00am 20 Mar 2017
Hi Grogster,
I have cut many a 3mm thread in Aluminium in my early years and found that like you using a drill press is excellent for getting it straight but I have a small tommy bar 8 inch long (sorry, 200mm)that fits neatly in the chuck key holes and I wind the drill press by hand, usually a third of a turn at a time and back off the same, run it back into the third a couple of times before advancing another third of a turn (dont forget to remove the tommy bar before using the drill!) Kero works well as a lubricant - lots of it!
Hope that helps
Phil23
Posted: 10:24am 20 Mar 2017
Slightly off topic, but I've been meaning to get one of these; instad of borrowing it occasionally.
A lot more things would get assembled better if I had a kit on hand to make treads for stand-offs etc in cases.
Rivet Nuts.
The guy that owns the one I've borrowed says it's a very well used tool in his workshop.
Phil.
Nut Pack.
Tool.
Bill7300
Posted: 12:56pm 20 Mar 2017
I have one Phil, although a different brand and mine came in a kit with steel nuts rather than aluminium for which I really have far greater need. As a result, I have only used mine once in about 15 years. I really must re-equip with aluminium. I note though that the Nut Pack link you quote is somewhat confusing in describing the nut pack as Stainless steel M... aluminium?
Phil23
Posted: 04:14pm 20 Mar 2017
  Bill7300 said  I note though that the Nut Pack link you quote is somewhat confusing in describing the nut pack as Stainless steel M... aluminium?
Yeah,
Just grabbed the first link that listed appropriate sizes, didn't notice that bit of it. Haven't ordered anything, but will watch out for such errors.
Posted: 04:18pm 20 Mar 2017
An interesting idea.
Posted: 03:50am 21 Mar 2017
I have used those rivet nuts a lot in my days when i built camper vans. They work great and small versions could be used for pcb's and enclosures.
Posted: 04:00am 17 May 2017
  disco4now said   I ordered this one to see what they are like.
Gerry
BUMP!
How did you get on with the one you ordered, Gerry?
Did it work?
disco4now
Posted: 04:43pm 17 May 2017
Gerry
BUMP!
Did it work?
Well it took me a while to find it. I tapped a couple or threads in 3mm aluminum and they seem ok. The tap is HSS so that OK, but when I look at the ebay listing what they have sent is not what is shown. They sent me a normal tap not the thread forming one they show. Should have had a closer look when I go it. Could be an honest mistake but not much I can do about it now, even if I noticed at the time with the return postage it would have not been worth trying to get the correct one.
So sadly I cant say how one would have worked. Found a use for and old drill chuck though
Gerry
F4 H7FotSF4xGT
BobD
Posted: 05:24pm 17 May 2017
[quote]They sent me a normal tap not the thread forming one they show.[/quote]
If you used PayPal I think that you get 180 days now to make a complaint (open a dispute) and PP will / may pay the return post.
I'm not able to confirm this right now but I'm sure that you could easily find it on the PP web site. Anyone else able to inform us on this?
Posted: 09:02pm 17 May 2017
Oh, OK.
I will order one then, and see if they send me the correct thing, or just a tap like you got.
Phil23
Posted: 01:17pm 19 May 2017
Hmmm,
Just did a search for 3mm thread forming tap & notice that the Chinese consider most taps to be thread forming.
One listing was clearly a 10mm 3 fluted tap.
"Fluteless tap" and "Thredflo tap" give a few hits, must be a Sutton TM.
A Sutton Thredflo, Pretty Exxy @ $65.00.
Phil.
Posted: 04:20pm 19 May 2017
Yes, I am curious as to what I will receive. If it is NOT a thread-forming tap, I will email the seller.
