Local Time 08:25 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 8x8 Matrix LED Display Fun
Posted: 09:40pm 07 May 2020
In that "For i = 1 To 6" loop, after the read, put "print i; " "; govenor(i)". I'm uncertain where the DATA settings are that the READ is acting upon.
Turbo46
Posted: 09:46pm 07 May 2020
Canada_Cold, The govener array is DIMed with a size of 6:
Dim chars(900), digi(8), clkcol(8,2), ASCIIptr(150,2), govenor(6)
And there are 6 numbers read into it:
For i = 1 To 6
Read govenor(i)
Next i
Data 19, 16, 12, 8, 4, 0
But dc (the index into it) can be set higher than 6:
dc = 0
For i = 1 To 8
If Mid$(msg$, i,1) <> Mid$(oldtime$,i,1) Then ' what digit changed?
digi(i) = 1
dc = dc + 1
Else
digi(i) = 0 'reset back to 0
Endif
Next i
I would change the DIM of govenor to 8:
Dim chars(900), digi(8), clkcol(8,2), ASCIIptr(150,2), govenor(8)
And add 2 more entries for its data:
For i = 1 To 8
Read govenor(i)
Next i
Data 19, 16, 12, 8, 4, 0, 0, 0
I think that should fix it.
Keep warm.
Posted: 10:06pm 07 May 2020
A simple debug test would be to
PRINT dc
in a line before the error line.
Using OPTION BASE only sets the start of the array.
The maximum remains the same with OPTION BASE 1 and OPTION BASE 0
Canada_Cold
Posted: 10:40pm 07 May 2020
Hi Bill (turbo46),
Thanks, That worked!  I’m not understanding why as yet, but that’s all part of the learning curve.
Have a great day, thanks, Don
Turbo46
Posted: 11:40pm 07 May 2020
An array is a collection of variables or data values. They must be of the same type: integer, floating point numbers or strings.
DIM govenor(6)
Creates an array with 6 different entries, govenor(1), govenor(2) through to govenor(6). They default to floating point numbers because the program does not specify otherwise (eg. AS INTEGER).
If you do not use the command:
OPTION BASE 1
there is also a govenor(0) entry which is often ignored – as it is in this program.
In the program a variable dc is used as an index into that array.
dc=1
PRINT govenor(dc)
will print the first entry in that array. The trouble is that dc is being set to values higher than 6 and so the programs is trying to read values in the array that do not exist and that is why you are getting the ‘index out of bounds’ error. I just suggested that you add two more elements to that array to avoid the error.
I hope that helps.
Justplayin
Posted: 02:44am 08 May 2020
Okay, I setup a test rig and verified the code posted in this forum doesn't work.  The setup for the variable oldtime$ is missing spaces. I think the forum must have reformatted the variable.
In  MAIN change:
oldtime$ = " : : " 'non scrolling part of the clock display
to:
oldtime$ = "HH:MM:SS" 'non scrolling part of the clock display
The array size of 6 is correct since the maximum number of digits which can change is 6. Even though the time displayed can be up to 8 characters long, the colons will never change.
--Curtis
Turbo46
Posted: 03:15am 08 May 2020
  Justplayin said  The array size of 6 is correct since the maximum number of digits which can change is 6. Even though the time displayed can be up to 8 characters long, the colons will never change.
In that case, the sub Show_Time must be changed. The variable dc can become greater than 6 and that is causing the 'index out of bounds' error.
Sub Show_Time
Local i, j, k, m, dc 'do not make k, m Local here
dc = 0
For i = 1 To 8
digi(i) = 1
dc = dc + 1
Else
Endif
Next i
Great program. Thanks for sharing it.
Canada_Cold
Posted: 04:03pm 10 May 2020
Hi All,
Thanks so much for all your input, I really appreciate all the debugging tips and the detailed explanation from Bill.  That's a great help for me in the understanding of the programming on the Mocromite.
I agree, It's a great program, I have it working on a green dot-matrix display on my workbench and it is very cool, thanks again to Curtis for posting it.
Don
Posted: 07:59am 08 Jun 2020
  Justplayin said  I have been playing around with some 8x8 matrix LEDs with MAX7219 driver boards and thought I would share some of the code.
Cheers Curtis.
I needed a clock for my workshop but I couldn't find anything I liked. Was bored yesterday and so I knocked up one on a mite using your code (and the proportional font!) as the basis. Have to say i got rid of the digit change animation... bit distracting.
Credited you in the boot here .
Big Thanks
h
Justplayin
Posted: 04:04am 09 Jun 2020
Glad to know you found the clock code useful and thanks for the boot credit.
--Curtis
