Local Time 09:09 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New version of MMBasic (ver 4.3)
Posted: 10:01pm 30 Jan 2013
  ratall said   Hi Geoff
Sorry to bug you.
But I think I've found a small bug
Agghh, another bug! At least they are getting more obscure.
Thanks, it will be fixed in the next version.
ratall
Posted: 07:27pm 02 Feb 2013
Hi Geoff
Sorry to bug you again.
But I think I may have found another bug.
Option base 1
LabelCount = 1
If LabelCount>0 then Dim Labels$(LabelCount)
Gives an error of
Error: Invalid array dimension
I don't know about anybody else but I do have the annoying habit of counting stuff then creating an array to keep it in (not too big, not too small. Just right ) and occasionally there is only one.
I do have a work round so again not urgent.
The program I'm working on currently uses "option base 1" so my work round is to change it to "option base 0", add 1 to all array sizes at the dim and carry on as though I am still using "option base 1". Ignoring element 0 of the the array.
R.
ajkw
Posted: 07:53pm 02 Feb 2013
from the mmbasic manual
DIM. Specifies variables that have more than one element in a single
dimension, i.e., arrayed variables.
edit/add:
so the behavior of getting an error when trying to dimension an array of 1 element is correct as things stand. However I can see that with your idea of dynamically dimensioning arrays that when you have a count of 1 you have a problem.
It would generally speaking be unusual to need to declare an array of 1 element, perhaps Geoff would explain for you if this is a convention (to only be able to dimension arrays with 2 or more elements) or if there is a technical obstruction to declaring an 1 element array.
Cheers,
Anthony.Edited by ajkw 2013-02-04
ratall
Posted: 09:39pm 02 Feb 2013
  ajkw said   from the mmbasic manual
Thanks for pointing that out I missed it. I am afraid I made an assumption based what some other basics let me get away with.
May be I should treat arrays as self contained objects and store the length in element zero. Or may be a terminator in the last element in case of string arrays. Waste not want not.
Sorry for wasting time.
Thanks for your help.
R.
ajkw
Posted: 10:33pm 02 Feb 2013
  Quote  store the length in element zero
Would be handy spot to store the number of elements
ratall
Posted: 10:50pm 02 Feb 2013
And it has the added bonus that when you erase the array it goes too.
panky
Posted: 10:30pm 05 Feb 2013
Hi ratal,
Have a look at my recent post on stack, queue's and lists - these may prove usefull to you if you need multiple pidgeon holes for small strings rather than arrays and has the advantage of being able to pass to subroutines.
Cheers, Doug.
Posted: 06:39am 06 Feb 2013
There are a few functions in other basic that can be usefull with arrays.
REDIM with optional preserve to make arrays smaller or bigger.
LBOUND and UBOUND to get the lower and upper bound of an array.
I am not sure if these were only in newer basic versions.
James_From_Canb
Posted: 01:51pm 18 Feb 2013
  James_From_Canb said   David,
Print "Goto 100" will have problems. Good pickup. Thanks.
Maybe I can treat text within double quotes like a remark - trim it out while I process everything else, then put it back together again. I'll think about it.
James
It took a little work to handle text within double quotes and lines resizing when different length linenumbers were inserted, but I think it's finally debugged.
I'll start a new thread so I don't clutter up the 4.3 thread.
James
