Local Time 23:39 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : how do setup picomite hdmiusb ??
Martin H.
Posted: 09:18am 01 Mar 2026
  tenij000 said  > option list
PicoMiteHDMI MMBasic RP2350A Edition V6.02.00
That's sadly still not the USB HDMI version.
'no comment
Posted: 10:43am 01 Mar 2026
If you are able to connect to the Pico using the Prog microUSB socket (USB5) to install MMBasic then the connections to the Pico have to be ok. The Pico's USB socket is wired directly to that one via the pads underneath.
The same connections feed the on-board USB hub vie CN4 links 1-2 and 3-4 so, if they are in place, then the USB hub must be connected.
Install the PicoMiteHDMIUSB firmware via the microUSB socket.
Unplug it - you don't want that lead now.
Use a USB-C lead to connect USB2 to the PC and switch the Pico on.
Start Tera Term
In the Tera Term text window go to Setup/Serial Port and make sure the baud rate is set to 115200 baud.
You should be able to find a serial COM port to connect to the Pico via the CH340C
You should then be in console mode
It might be a black screen so press Enter a couple of times
Enter OPTION RESET HDMIUSB and everything should set up automatically
You should be able to use a USB keyboard and HDMI monitor from this point
Edited 2026-03-01 20:51 by Mixtel90
Posted: 10:49am 01 Mar 2026
  Quote  if re try to put solder into hole under the usb hub chip tingy whill that connect maby a gpio pin
I think putting solder in that hole is to provide heatsinking for that chip.
  Mixtel90 said  Did you solder the TP pads under the Pico?
The 3 pads he is reffering to have holes and can be seen in this pic. Two are at the top of the Pico footprint and one a little further down.
https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=4#228486
You need to solder through those holes to connect to the USB pads on the bottom of the Pico.
Then you can load the HDMIUSB firmware again to see if it works properly.
Posted: 10:55am 01 Mar 2026
If *any* firmware can be loaded via the microUSB socket then the pads must be ok. They are simply point to point wired. Pins 1 and 3 of CN4 are on the same connections.
You take the CN4 links off while programming anf put them back to connect the USB hub to the Pico. That microUSB isn't used for anything other than installing MMBasic.
tenij000
Posted: 07:59am 02 Mar 2026
now here also 1 red light is on r59 active
disco4now
Posted: 08:37am 02 Mar 2026
So what happened next?
F4 H7FotSF4xGT
tenij000
Posted: 08:41am 02 Mar 2026
it works now      problem was the led bihind the battery holder was rong way around
disco4now
Posted: 09:20am 02 Mar 2026
Are all the boards the same, or just the first unlucky one?
F4 H7FotSF4xGT
Posted: 09:36am 02 Mar 2026
That's an interesting fault. /PWREN was unable to turn the power on to the USB sockets. Well spotted. :)
