Local Time 23:14 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WeAct Pico2350B 48-pin Module
ville56
Posted: 07:22pm 18 Feb 2026
you may consult the Picomite user manual, there are descriptions of use-cases for PSRAM with pros and cons.
73 de OE1HGA, Gerald
Posted: 07:45pm 18 Feb 2026
It all depends, as do a lot of things. :)
PSRAM gives you a very big RAM area but any programs you write that use it will, of course, only run on platforms that have it. If you want to run software written for the Pico or Pico 2 then you don't need PSRAM as neither of those platforms has it.
As it's RAM it's main use is probably when you need lots of of temporary data storage. Your maximum program size isn't increased.
This is why I'm not over concerned about problems I'm having with it on GAP1. That's designed for playing games and unless someone starts to write games that need PSRAM then it's merely a "nice to have".
Posted: 08:19pm 18 Feb 2026
I'm expecting only to run on RP2350. Heap has been my issue so far. PicoDB will run with LCD on a Pico2, Pico2-Zero, Pico2 clone, and WeAct RP2350B module, but on Peter's Pico2 HDMI board, I've had to cut way back on some array sizes, and also move from 800x600 to 640x480 in resolution.
If speed doesn't become a issue (and I think it doesn't look like it will be), then if PSRAM can be used for heap, then largish (for microcontrollers) databases will be possible.
darthvader
Posted: 12:45pm 21 Feb 2026
I finally get the psram from aliexpress and they are working with this board ,
i dont have solder the 10k pullup resistor , as checking the schematics and see that
they have already a 10k resistor soldered on the top of the pcb for the psram
Aliexpress
Cheers.
ville56
Posted: 08:24pm 21 Feb 2026
Mine definitely didn't have pullups. Measured it before attaching one. Seems to be different production runs.
Posted: 12:36pm 22 Feb 2026
If they'd used that odd bit of space at the end to extend the connectors by an extra row on each side, or even just one, we could have had D+ and D- brought out. It might have added 0.5mm to the board and increased the unit price by 0.0001p  :(
No free shipping or price reduction available on them now either, even for three.
Edited 2026-02-22 22:46 by Mixtel90
darthvader
Posted: 01:46pm 22 Feb 2026
  ville56 said  Mine definitely didn't have pullups. Measured it before attaching one. Seems to be different production runs.
After reding this, i become suspicious
I tested on another board with no psram soldered and get 9.97k ...
So , it's definitely soldered on my batch
Cheers.
Pluto
Posted: 03:06pm 22 Feb 2026
I have 3 board w/o PSRAM. All have 10k pull-up to 3.3V. From different ordering batches. Older with A2 and newer with A4 chips.
Pluto
v.lenzer
Posted: 06:13pm 04 Mar 2026
My PSRAMs arrived today. Five for a few euros. I soldered one on immediately and 6 MB were recognized right away :)
On my WeAct boards, there's a 10k-ohm resistor between pin 1 and 3.3V.
Best wishes! Joachim
Posted: 01:02pm 06 Mar 2026
I've just got  an A4 stepping version and it definitely has a 10K pullup in place for the PSRAM. I know 'cos I just measured it. :)
Posted: 08:17pm 14 Mar 2026
Just to test everyone's soldering skills, the two tiny pads alongside the PSRAM chip are supposed to have a 100nF capacitor on them. It's marked on the schematic as not fitted, along with the PSRAM chip. It might work without, who can say? It's between pin 8 of the PSRAM and GND. I managed to get a 0805 on there with some difficulty (and without the header pins fitted), but I'd nothing physically smaller.
Posted: 08:47pm 14 Mar 2026
  Mixtel90 said  two tiny pads alongside the PSRAM chip are supposed to have a 100nF capacitor on them
In my limited testing, it has worked without the capacitor.
Posted: 09:28am 15 Mar 2026
I only fitted it because I wanted to see if I could and I just happened to have some caps. :)  I do like a soldering challenge sometimes, and I've just got a new illuminated magnifying glass to test. lol
Caps in that position (close to the chip) come into their own on fast write accesses, where the current is usually higher. It reduces negative spikes on the supply rail during the current burst. The further away from the pin the less effective they are.
Posted: 07:03pm 17 Mar 2026
WeAct RP2350B with DVI on Mick's PCB
