Local Time 09:10 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Linux Mint
palcal
Posted: 08:38am 21 Apr 2025
Thanks Jim,
I  tried connecting to my PicoMite, it is on USB 5, in control centre when I click to
add the usb port a list comes up and it only goes to usb3. I can't change it to usb5.
Posted: 08:43am 21 Apr 2025
  TassyJim said  MMEdit is not the same as MMEdit
hmm ?
Posted: 10:11am 21 Apr 2025
  palcal said  Thanks Jim,
Sorry about that, You are the first to reach the limit.
I will add a few more and upload an update but it might be later tomorrow.
There is a way around it but easier to wait until I fix it.
This is one of the differences between Windows and Linux versions.
MMCC.zip
Why wait.
I had to put it into a ZIP for the forum and tar to keep the permissions.
Just extract the one file and replace the old MMCC
Edited 2025-04-21 20:25 by TassyJim
Xian
Posted: 04:58pm 21 Apr 2025
@pascal
if you are still struggeling with getting MMEdit running on Linux Mint 22 - i can try to guide you through. Having the same OS intalled on my PCs and got it working directly.
Linux is somewhat different from Windoze 11 - and sometimes it helps to use the command line.
I am not on WhatsApp but Signal messenger - i'm located in Germany, so quite some time zone distance..
best regards,
Christian
palcal
Posted: 07:43pm 21 Apr 2025
Jim,   I changed to a different port it's on the back of the box so I used an extension cable, sorry for the trouble.
Christian, I have it running OK but now having trouble connecting to usb, I have joined the dialout group and tried Putty, GFXterm and MMEdit but cant connect to any.
I ran 'lsusb' in the terminal and this is the result.
Maybe I am using the wrong syntax.
Edited 2025-04-22 05:45 by palcal
Posted: 09:12pm 21 Apr 2025
You are making life difficult for yourself.
plug your device in.
Then enter the command dmesg
towards the end there will be something similar to this:
[   62.793408] usb 1-2: new full-speed USB device number 3 using xhci_hcd
[   63.067335] usb 1-2: New USB device found, idVendor=2e8a, idProduct=000a, bcdDevice= 1.00
[   63.067338] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   63.067340] usb 1-2: Product: Pico
[   63.067342] usb 1-2: Manufacturer: Raspberry Pi
[   63.067343] usb 1-2: SerialNumber: E6605838833E9738
[   63.101089] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
[   63.103423] usbcore: registered new interface driver cdc_acm
[   63.103424] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
The important line is
Depending on the device it will appear as either a ttyUSBx or a ttyACMx
They will start at zero and work their way up.
My experience is, if you unplug and reinsert (or do a reset etc) it will get the next number available but if you take a few seconds to reinsert, the old number will clear and you might get the old number back again.
There are ways to make the device receive the same number (probably)
Welcome to Linux.
Edit: As well as GFXterm, Rob has had success with detecting USB devices when they are plugged in. His program will be well worth trying.
Edited 2025-04-22 09:01 by TassyJim
palcal
Posted: 12:46am 22 Apr 2025
I will try that, thanks Jim. One day, no hurry, would it be possible to make the windows at the top of MMCC for Device, Port and Baud rate a little wider as it is it cuts off the end characters.
palcal
Posted: 05:20am 22 Apr 2025
Well I have it working, transferred a file from my Pico to MMEdit so all is good.
GFXterm also working.
Now to get rid of the password, seems everytime I do anything it wants a password.
Should be optional, I am the only person who ever enters my workshop let alone use the computer. After that I think I'm done and I'll be a happy Linux user.
Thanks to every one who helped me through this mess.
Edited 2025-04-22 15:21 by palcal
Posted: 07:10am 22 Apr 2025
There will be a setting for booting up logged in.
I don't know where it it on Mint, sorry.
There may be another setting to not auto log out after a time of non-use.
Edited 2025-04-22 17:11 by JohnS
Posted: 07:29am 22 Apr 2025
AFAIK some system management tasks will always ask for a password. It's one of those little things that makes Linux infuriating for the casual naughty hacker and malware. :)
Bryan1
Posted: 08:55am 22 Apr 2025
Yes one can imagine what damage could occur if logged in as superuser with no password in place, one wrong thing in the wrong place and bang everything is screwed so yes passwords on linux is needed
Posted: 09:16am 22 Apr 2025
Set it to boot logged into a user that's not root.
(I'm guessing Mint can do that as it's fine for Linux generally - if you want that.)_
pwillard
Posted: 11:48am 22 Apr 2025
Linux Mint 22.1 Cinnamon -  So yeah, there is no 'Qt5-default'
But with the correct libraries... it works fine.
I didn't encounter any other issues... connected to my picomite just fine at 115200 in MMCC.
Edited 2025-04-22 21:50 by pwillard
palcal
Posted: 12:16am 02 Jun 2025
Hi all, well I stuck with it and glad I did. After the initial teething problems it is all working well. MMEdit and all other apps working great.
Thanks to all who helped me through.
palcal
Posted: 09:15pm 09 Jun 2025
Is there anything like Microsoft Onedrive for Linux, I now have two machines on Linux and very happy but, the computers are in different locations and it would be nice to sync the two. Especially when using MMedit, on windows I could move from one machine to the other and the file I was working on was available.
panky
Posted: 11:44pm 09 Jun 2025
  palcal said  Is there anything like Microsoft Onedrive for Linux, I now have two machines on Linux and very happy but, the computers are in different locations and it would be nice to sync the two. Especially when using MMedit, on windows I could move from one machine to the other and the file I was working on was available.
A couple of options to consider - Dropbox works a treat and has more than enough free storage. Another option is networking and sharing a folder so multiple machines can 'look' at the same file.
Doug.
PS. Files saved into Dropbox on one machine automatically sync up to all other of 'your' Dropbox machines. It can also be used with Windows as a simple file sharing mechanism. I have spent many fruitless and frustrating hours trying to network Linux and Windows machines. As soon as you actually get it working, updates on either system seem to kill the networking between the two platforms and you then start over.
D.
Edited 2025-06-10 09:48 by panky
palcal
Posted: 12:54am 10 Jun 2025
I'll try Dropbox, so I just connect both machines to the same Dropbox account ?
palcal
Posted: 02:03am 10 Jun 2025
Got it working but, I uploaded my Picomite folder with Software, Firmware and some text files and only the .bas files uploaded. Is that correct, it's all I need really.    Also when I uploaded the folder it disappeared from my computer, can I have the files on my computer and also in Dropbox.
Did it again and all the files transferred so I tried another folder and it didnt appear on the other computer at all. I'll have to check further.
Seems I have problems with everything I do.
....OK all seems to be working now
Thanks Doug.
Edited 2025-06-10 13:22 by palcal
