Local Time 18:11 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Final PicoMite Release - V6.00.01
     Page 3 of 4
zeitfest
Posted: 07:23pm 08 Jan 2025
> list
Dim a As integer : a = 0
Print "a="; a
Add1(a)
Print "a="; a
Add1((a))
Print "a="; a
End
Sub Add1(x As integer)
 x = x+1
 Print "x="; x
> run
a= 0
x= 1
a= 1
x= 2
a= 1
I think that is a bug (?)
Posted: 08:11pm 08 Jan 2025
Why do you think that (a) should be the same as a?
In MMBasic DOS:
a=0
add1((a))
Print "main: ",a,b
End
Sub add1(b)
b=b+1
Print "sub: ",a,b
Return
sub:     0       1
main:    0       0
Posted: 08:22pm 08 Jan 2025
It's meant (*) to be that way.
It's useful to know that it is!
Easy to work around if it troubles you - use the extra parens or just don't modify things passed in as parameters.
(*) let's not get into language debates...
Posted: 08:26pm 08 Jan 2025
By putting 'a' in brackets '(a)', the interpreter is treating (a) as a formula
A normal variable is passed by reference.
When you use a formula as a parameter for a SUB, it is not passed by reference.
Posted: 10:06pm 08 Jan 2025
  WhiteWizzard said  Do I need some form of clearing/nuking this particular old firmware?
Clear_flash_2040.zip
twofingers
Posted: 10:33pm 08 Jan 2025
@Lizby
I think you mean this?
a=0
add1((a))
Print "main: (a)",a,b
a=0
add1(a)
Print "main:  a ",a,b
End
Sub add1(b)
Inc b
Print "sub: ",,,a,b
sub:             0       1
main: (a)        0       0
sub:             1       1
main:  a         1       0
Kind regards
Michael
Posted: 10:41pm 08 Jan 2025
I like the way you've added b to the print in main!
Posted: 06:51am 09 Jan 2025
Hi Jim,
I didn't know this. Wow, that opens a whole new universe. I know I struggled with this in several programs, always assuming the ByRef was the only way to pass data to a sub.
But you need to be sharp in how to format everything. Without brackets also seems to work.
mysub a     'ByRef
mysub (a)     'ByRef
mysub ((a))   'ByVal
mysub(a)      'function call ByRef
mysub((a))    'function call ByVal (have not checked, but I assume)
Edited 2025-01-09 16:53 by Volhout
Posted: 08:33am 09 Jan 2025
From the manual
  Quote  Unless you need to return a value via the argument you should not use an argument as a general purpose
variable inside a subroutine or function. This is because another user of your routine may unwittingly use a
variable in their call and that variable could be "magically" changed by your routine. It is much safer to assign
the argument to a local variable and manipulate that instead.
Posted: 08:36am 09 Jan 2025
I think this makes sense in BASIC as it always evaluates bracket values first. What we are seeing is two different meanings for brackets. The first meaning is that the command has an argument, the second is that there is a value to be calculated.
myfunction(A) shows this more clearly, the brackets are not optional.
A is being passed by reference
myfunction((A+1))
will cause the evaluator to evaluate the contents of the brackets first and replace them with a temporary value for the call. It detects that this is needed by the fact that the value to be calculated is in its own brackets.
myfunction((A))
will force the evaluator to evaluate the contents as A+0 or simply A as there is nothing else, but the evaluator has been triggered so it has to be a value that is passed.
I wouldn't say that this use of brackets is a "hack". I think BASIC is supposed to work in this way. FORTRAN (which has several influences on BASIC) also passes by value by default, although it uses the VALUE keyword to force passing by value.
Passing values by reference can lead to errors, true, but within a SUB or FUNCTION you should be using LOCAL or STATIC variables if you want them to be private. That makes the behaviour of the routines completely predictable under all circumstances.
Posted: 11:12am 09 Jan 2025
I think ANSI full BASIC passes by value.
(But MMBasic doesn't claim to be that.)
bfwolf
Posted: 11:46am 09 Jan 2025
Microsoft would it describe it like this:
"We confirm this behavior not being a bug but a feature!"
Some years ago when I read the MMBasic manual, I noticed, that there is no "language option" to specify whether ByRef or ByVal is requested. So I played (I think with the MSDOS version?) and looked, what happens, when I enclose argument variables with brackets - and it worked!
  matherp said  From the manual
Yes, Peter, I'm with you! It's bad style to modify parameter variables unless they are "return values" - and it's always cleaner, to make a local copy of arguments, that are no "return values", and modify those, if necessary.
But it's "double safe", if the caller may protect it's arguments against modification. This would be achieved (clearly) by having ByVal.
Using the "trick" with enclosing argument variables with brackets and force them being "expressions" (which could be variables, formulas or constants) works until then.
At the moment I see the keywords ByVal and ByRef "nice to have"..
bfwolf
zeitfest
Posted: 11:58am 09 Jan 2025
  Quote   FORTRAN ... also passes by value by default,
Did you mean, ... passes by reference by default ...
Using values as call-by-reference arguments in calling statements can lead to ah, unfortunate happenings.  In exact call-by-reference, the argument is expected to be the name of a variable, not a value. Some early language compilers were a bit
vicious and would simply treat the value as a name, so say
call mysub(3)
would simply create and use a variable called '3', probably not the expected
result.
Posted: 12:20pm 09 Jan 2025
Sorry, yes - FORTRAN passes by reference.
I bet there's no room to implement these on the Micromite version of MMBasic. Geoff used magical unicorn power to get stuff into that!
Edited 2025-01-09 22:27 by Mixtel90
bfwolf
Posted: 01:33pm 09 Jan 2025
Ok - if it breaks compatibility amongst different platforms, it's hard to solve.
We could live with the brackets "trick".
@Peter: How do you think about my FSEEK(), FREAD$(), FWRITE() ideas?
I recently saw, that the present INPUT$() mostly behaves the same way as FREAD$() would. But I have now idea, how to substitute FWRITE() by PRINT #nbr, ...
And the SEEK command also behaves different - not possible to seek +/- from current position or to file's end. We must track the current position ourselves then instead..
As both LittleFs and Chan's FatFS (probably used for SD-CARDs?) supply the functions to realize FSEEK(), FREAD$(), FWRITE(), I wouldn't expect much work?
bfwolf
Posted: 03:39pm 09 Jan 2025
Bearing in mind that the features are frozen now and only bug fixes being done, you may have a wait, especially for things which are hardly important.
bfwolf
Posted: 05:29pm 09 Jan 2025
Just made an experiment using the DOS/Windows-version (to view the resulting file):
It seems, that
' Note the pending ';' !
PRINT #nbr, wdata$;
just writes the data contained in wdata$ and doesn't append a CR, a TAB, a space or anything else, so this could replace the wanted FWRITE().
Can anybody confirm this behavior for other MMBasic ports?
Maybe I'll write a library, having also a FOPEN() like C offers, and track the current file position with a "hidden" variable e.g. "_current_fpos". The FOPEN() then would initialize the current file position and FSEEK(), FREAD$() and FWRITE() would update it accordingly.
bfwolf
Posted: 05:37pm 09 Jan 2025
It's standard BASIC that a ; with PRINT does that.
The user manual I have even says it does that...
Edited 2025-01-10 03:40 by JohnS
bfwolf
Posted: 05:57pm 09 Jan 2025
Yes, I knew that an ending ';' supresses CR and TAB but was uncertain if perhaps a space would be added. But I think the space is leading numeric variables PRINTed? (for the sign if negative?)
@Geoff, Regarding the user manual:
Within the description for the OPEN statement, a WRITE statement is mentioned but never described in detail anywhere else..
Is the WRITE statement "just an alias" for PRINT or are there differences?
bfwolf
Posted: 09:34pm 09 Jan 2025
AFIK there is no individual WRITE command. Write is just a component of other commands.
eg I2C WRITE, SPI WRITE
     Page 3 of 4
