Forum Index : Microcontroller and PC projects : PicoMite/VGA/Web V5.08.00: back to betas
V5.08.08b3 https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes the couple of bugs identified above and also a bug I'd introduced in audio playback from directories other than root. There a couple of facilities that I may not have mentioned before MM.INFO(UPTIME) returns the number of seconds since the Pico was booted as a float MM.INFO(TRACK) returns the filename that is currently playing on the audio output |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 727 |
I come back to the display waveshare Pico-ResTouch-LCD-3.5 ( https://www.thebackshed.com/forum/ViewTopic.php?TID=16248&P=17#213230 ). Thanks @Peter, the backlight command works again! And the problem with the GP22 and the SD card is also solved. The problem has nothing to do with IDC2, even though the Pico W version of the GP22 lacks it. The pin is only used for CS and it works. BUT only after activating the touch function! This is quite unusual. So the Pico W alias WebMite works with the Waveshare board mentioned above. Here is the options list: > option list WebMite MMBasic Version 5.08.08b2 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION LCDPANEL ILI9488W, RLANDSCAPE,GP8,GP15,GP9,GP13 OPTION WIFI *****, ******, PicoLCDw OPTION TOUCH GP16,GP17 GUI CALIBRATE 1, 3597, 489, -1347, 10358 OPTION SDCARD GP22 > Matthias A blessed 1st of Advent. |
Not unusual, well known and repeatedly discussed. With touch CS floating the touch controller corrupts the SPI bus. If you don't want to enable touch you can set the pin high manually or with a pullup resistor |
| javavi Guru Joined: 01/10/2023 Location: UkrainePosts: 624 |
matherp, PicoMite V5.08.08b3 in its pure form it gives an error when compiling [build] C:\ARM\PROJECTS\PicoMite\PicoMite\Audio.c: In function 'cmd_play': [build] C:\ARM\PROJECTS\PicoMite\PicoMite\Audio.c:1946:17: error: too few arguments to function 'checkend' [build] 1946 | checkend(); [build] | ^~~~~~~~ [build] In file included from C:\ARM\PROJECTS\PicoMite\PicoMite\MMBasic_Includes.h:31, [build] from C:\ARM\PROJECTS\PicoMite\PicoMite\Audio.c:32: [build] C:\ARM\PROJECTS\PicoMite\PicoMite\MMBasic.h:271:6: note: declared here [build] 271 | void checkend(unsigned char *p); [build] | ^~~~~~~~ [build] mingw32-make.exe[3]: *** [CMakeFiles\PicoMite.dir\build.make:467: CMakeFiles/PicoMite.dir/Audio.c.obj] Error 1 Previous versions were compiled without such errors in this environment Pico SDK 15 VSCODE on W11 using GCC 12.3.1 arm-none-eabi |
Something for the audiophiles to contemplate. The LCD backlight frequency was raised from 1kHz to 50kHz to minimize its effect on audio quality. Might there now be an intermodulation artefact between 50kHz and the 44.1kHz audio PWM? The sum frequency is unimportant but the difference is 5.9kHz. My geriatric ears notice nothing but others might. If anyone does might 44.1kHz be a better backlight frequency? |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1158 |
Your favorite OPTION strikes again! MATH M_PRINT a%() with OPTION BASE 1 prints one extra column and row so runs out of data. test_print: LOCAL a%(BASE%+15,BASE%+7) Math set 3,a%() MATH M_PRINT a%() Matrix Integer 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3 3, 3, 3, 3, 3, 3, 3, 3, 3, 7598259076605371764, 2126958, 0, 0, 0, 0, 0, 0 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 Edited 2023-12-04 13:46 by disco4now F4 H7FotSF4xGT |
V5.08.00b4 https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip New command and function OPTION PLATFORM name$ ' This command allows a user to identify a particular H/W configuration that can then be used to control a program. name$ can be up to 31 characters long MM.INFO$(PLATFORM) ' returns a string previously set with OPTION PLATFORM NB: Will erase all options and A: drive on a WebMite Special request, Please could anyone with a WebMite application test this version Edited 2023-12-05 21:26 by matherp |
Thanks Peter, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Note: OPTION LIST will show junk in OPTION PLATFORM (VGA and PicoMite) until you set it or do an OPTION RESET. The final release will force a reset so this will only be an issue for beta upgraders. Also fixes M_PRINT bug as reported Edited 2023-12-05 21:34 by matherp |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6199 |
Peter, OPTION PLATFORM works (on VGA). Tested it with several ASCII patterns. You could default with OPTION PLATFORM MM.INFO(DEVICE) Regards, Volhout Edited 2023-12-05 21:47 by Volhout PicomiteVGA PETSCII ROBOTS |
I'm building the PicoMite firmware from source code and it works. But when I add files according to the instructions and build PicoMiteVGA, the firmware is built but does not work. This started with the beta version of PicoMite 05.08.00b1 What could be wrong? Who can check the PicoMiteVGA firmware build from these sources? https://github.com/UKTailwind/PicoMite https://github.com/UKTailwind/PicoMite-VGA-Edition |
Beta 4 works well on my WEBmite. Jim VK7JH MMedit |
V5.08.00b3 source code for PicoMite and PicoMiteVGA compile and run ok albeit with limited testing. The WebMite code does not compile when it cannot find a header file (from & within code in the sdk!). Something funny going on there and I haven't had a chance to track that down yet. Compiling on RaspberryPi, sdk v1.5, arm-none-eabi-gcc v10.3 No suggestion as I'm sure you have already tried a "clean slate" approach. @Jim Beta 4 has not been updated into the source code repo led Edit: Suggestion Ignore the Include.h in the VGA repo, and just use the Include.h of the main PicoMite repo. The former has not been updated for some defs. I do, and, PicoMiteVGA compiles. led Edited 2023-12-06 12:16 by led-bloon Miss you George |
Yes, I understood the reason for my failures with compiling the PicoMiteVGA ! Apparently the GitHub code of the PicoMiteVGA repository has not been updated since version 5.08.00b0 https://github.com/UKTailwind/PicoMite-VGA-Edition In the end, I managed to correct the code in the files: include.h and SMakeLists.txt By analogy with the same files in the PicoMite codes |
MATH SHIFT a%(),nbr , b%() has an issue when B(63)=1 Once B(63) is set any following shift right will will populate the new B(63) as a 1. test_shift: This value (hex) 0000000000000001 shifted left 63 gives 8000000000000000 now shifted right 63 gives FFFFFFFFFFFFFFFF FAIL (1/1) 1: Assert equals failed, expected 1 but actually -1 F4 H7FotSF4xGT |
This correct. The value is signed and propagates the MSbit on right shifts UPDATE In the next release I'll add an optional parameter to force unsigned shifts MATH SHIFT a%(),n,b%() [,U] Edited 2023-12-07 20:40 by matherp |
Great!!! Is this also possible for the shift operators << >>? |
Regarding WebMite: Something "happened" between V5.08.00b3 and V5.08.00b4: With V5.08.00b4 my MQTT application was running rather reliably over days; with V5.08.00b4 I get random errors, such as: [222] "Cint(pow(1) = getVal(FLD_POW, 1) *POW_CORR Error : Invalid character: " But the line is fine, if I look at it the editor. As if the flash was corrupted. If I write the program again to flash slot 1 (flash overwrite 1), the program runs again but freezes 1-2 min later (reset needed). Puzzeled Thomas P.S.: here is the code. The options are: > option list WebMite MMBasic Version 5.08.00b4 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION AUTORUN 1 OPTION COLOURCODE ON OPTION DISPLAY 64, 80 OPTION LCDPANEL ST7789_320, LANDSCAPE,GP8,GP15,GP9,GP13 OPTION WIFI Elchland3, ****************, PICOE6614104037 OPTION TOUCH GP16,GP17 OPTION SDCARD GP22 |
It already seems to do that. A:/> n = 2^62 * -1 A:/> ? n -4.611686018e+18 A:/> ? hex$(n,16) C000000000000000 A:/> ? bin$(n,64) 1100000000000000000000000000000000000000000000000000000000000000 A:/> m = n >> 16 A:/> ? bin$(m,64) 0000000000000000110000000000000000000000000000000000000000000000 A:/> If that isn't what you mean then read the MSBit (n>>63) and if 1 change it to 0 before shifting and after shifting multiply by -1 to recover the sign, if its needed. eg A:/> clear A:/> n = 2^62 * -1 A:/> ? bin$(n,64) 1100000000000000000000000000000000000000000000000000000000000000 A:/> if n>>63 = 1 then m = n and (2^63 - 1) A:/> ? bin$(2^63 - 1,64) 0111111111111111111111111111111111111111111111111111111111111111 A:/> ? bin$(m,64) 0100000000000000000000000000000000000000000000000000000000000000 A:/> p = m >> 16 A:/> ? bin$(p,64) 0000000000000000010000000000000000000000000000000000000000000000 A:/> ? p 7.036874418e+13 A:/> q = p * -1 A:/> ? bin$(q,64) 1111111111111111110000000000000000000000000000000000000000000000 A:/> ? q -7.036874418e+13 A:/> Edited 2023-12-08 14:25 by phil99 |
Please could you try the attached. I made some changes to try and improve stability in b4 but the fact it made it worse has given me a clue as to what the problem was. I hope this improves it PicoMiteWeb.zip |
