Local Time 16:29 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ssd1306
Posted: 03:27pm 28 Aug 2022
> option list
OPTION SYSTEM I2C GP8,GP9
OPTION LCDPANEL SSD1306I2C, LANDSCAPE
> print mm.devices,mm.ver
0       5.0704
It was a faulty ssd1306 it seems. I did try all suggestions but mik's no pullup and run ssd from 3.3V worked.
If he was fed up think what I felt like... get another hobby stan :)
Posted: 03:41pm 28 Aug 2022
Sorry I shared flogging a dead horse. Both displays were working or I would have binned it. Maybe they are like batteries.
It has taught me not to assume things and given me more confidence to try other i2c devices.  I can hear the forum say arghhh no! Thanks for help with the display guys.
Posted: 03:50pm 28 Aug 2022
Glad it's working. :)
One of the problems you can get is cheap breadboards. I've learned from experience that once a Pico is plugged in don't be tempted to take it out to use the board for something else. The pins sometimes stretch the cheap and nasty breadboard connectors enough to prevent them closing onto thin wires in the future - and you can't tell it's happened.
Another problem can be bad crimps on the Dupont connector leads. Impossible to spot sometimes. A test meter (or continuity tester of some sort) is your friend here.
I like these little displays. Cheap enough to build into something just as a debugging aid so that you don't have to plug a laptop or something in as a console. More flexible than a few LEDs and less pins. :)
Edited 2022-08-29 01:55 by Mixtel90
Posted: 04:20pm 28 Aug 2022
Glad you got it working. You left the "$" off of mm.devices$, otherwise it would have given you the name of the device--"RP2040 PicoMite" for the non-VGA picomite, "PicoMiteVGA" for the VGA version of the firmware. Early on, this would have provided the clue that you were not using the appropriate firmware for the I2C display.
Posted: 04:30pm 28 Aug 2022
  Mixtel90 said  Glad it's working. :)
I agree and now will take nothing for granted.
I was always sceptical about electrolytic caps and always measured their esr.. they are like batteries in that they fail.
There used to be alternatives to perforated strip board/veroboard, had pads, do not see that now.
Breadboard is quick but not electrically sound.
I test the jumper leads now!
The display is neat. How does it work? I made line code on picaxe with ssd1306 but gcb uses a 1k buffer so some pics not enough ram. How does mmbasic use it please? If that is off thread please ignore.
Posted: 04:46pm 28 Aug 2022
  lizby said  Glad you got it working. You left the "$" off of mm.devices$, otherwise it would have given you the name of the device--"RP2040 PicoMite" for the non-VGA picomite, "PicoMiteVGA" for the VGA version of the firmware. Early on, this would have provided the clue that you were not using the appropriate firmware for the I2C display.
> print mm.device$,mm.ver
PicoMite         5.0704
? is print
teraterm is still new to me but learning. It is not optional. Everyone else seems happy using it.
Posted: 04:56pm 28 Aug 2022
You can get perf board with individual pads for each hole very easily on ebay. You can link the pads with fine wire or solder blobs. You used to be able to get it with short strips of 3 holes, but I've not seen that for ages - and it was a pig to work with. You can get perf board with the same strips as breadboards now, in the same sizes. I've not used them myself.
Tera Term is just a terminal. It sends characters that you type and displays what comes back. It sets up what happens when you press the Enter key (CR, LF or both). It also does a similar thing to get the display right when one or more of those characters is returned. It's not interested in the programming or editing process at all, it's just a "pipe" for characters.
Edited 2022-08-29 03:03 by Mixtel90
Posted: 05:04pm 28 Aug 2022
  phil99 said  To see if your display is correctly connected to System I2C load and run this little program.
Print "System I2C Address Scanner"
' Prep table
Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F"
' loop col/row
For y=0 To 7
Print Hex$(y,2);": ";
For x=0 To 15
 addr = y*16+x               ' calc address
 I2C write addr, 0, 1, &H00  ' write zerp to that adress
 If MM.I2C=0 Then            ' check for errors
   Print Hex$(addr,2);" ";   ' found one!
 Else
  Print "-- ";               ' nothing here..
Next x
Print
Next y
Print MM.DEVICE$, MM.VER
The output should look like this, but showing a different address. This is for two other devices sharing System I2C with addresses &H50 and &H68
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
01: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
02: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
03: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
04: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
05: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
06: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
07: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
thank you phil... on a working display I got
> RUN
03: -- -- -- -- -- -- -- -- -- -- -- -- 3C -- -- --
05: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
06: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
PicoMite         5.0704
Nice one.
Nothing works on a duff display.
