Local Time 04:53 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4L: MMBasic for Linux alpha release
     Page 3 of 11
Posted: 01:16pm 25 Sep 2021
  lizby said  I thought it might have been the "sudo"s in the code. Removing them all got further in the program, but it again died with a "permission" error. Oddly, if I reran, it got further, and after doing that 8 times, it ran fine
sudo is funny like that. once you've done a sudo and supplied the password, it can, for some short length of time thereafter, be run again without requiring the password to be entered.
i believe the 'correct' way of doing it from within a script or program is to use pkexec. for example, see the below shell script:
#!/bin/bash
cmdU=""
cmdB=""
for port in $(find /sys/bus/pci/drivers/ehci-pci/0000* -maxdepth 1 -type l)
do
 cmdU=$cmdU"echo -n "$(basename "$port")" > $(dirname "$port")/unbind;"
 cmdB=$cmdB"echo -n "$(basename "$port")" > $(dirname "$port")/bind;"
done;
for port in $(find /sys/bus/pci/drivers/xhci_hcd/0000* -maxdepth 1 -type l)
do
done
cmdstr="sleep 1;"$cmdU"sleep 3;"$cmdB"sleep 1"
echo $cmdstr | sed 's/;/\n/g'
pkexec su -c "$cmdstr"
if [ $? -eq 0 ]
then
 paplay /usr/share/sounds/LinuxMint/stereo/system-ready.ogg
fi
this particular script brings the USB subsystem back up once a pico had knocked it over. can be very useful!
rob   :-)
Posted: 02:24pm 25 Sep 2021
  lizby said
  JohnS said  Rob's idea looks good, but if it doesn't work look at the owner of the gpio ports.
Thanks. How do I do that?
Something like
ls -l /sys/class/gpio/gpio*
You probably want to see the group and become a member of it.  Commonly you'd have to re-login for an adduser (addgroup etc) to take effect.
Posted: 02:33pm 25 Sep 2021
  robert.rozee said  sudo is funny like that. once you've done a sudo and supplied the password, it can, for some short length of time thereafter, be run again without requiring the password to be entered.
Right, and I've seen that, but this didn't ask for a password (and I didn't provide one)--it just failed back the the MMB4L prompt. This was in attempting to write "out" or "in" to the direction file., e.g. /sys/class/gpio/gpio12/direction.
But apparently it did create the file, because pressing up-arrow and <Enter> to run again moved on to the direction file for the next pin, which failed. When I did this for all 8 pins (4 out and 4 in), it ran successfully.
Posted: 02:37pm 25 Sep 2021
  JohnS said  Something like
pi@raspberrypi:~ $ ls -l /sys/class/gpio/gpio*
lrwxrwxrwx 1 root gpio 0 Sep 25 09:17 /sys/class/gpio/gpiochip0 -> ../../devices/platform/soc/20200000.gpio/gpio/gpiochip0
Edited 2021-09-26 00:37 by lizby
Posted: 03:35pm 25 Sep 2021
See https://www.raspberrypi.org/forums/viewtopic.php?t=97334
"The default policy for sudo within Raspbian is not the same as for Ubuntu etc. To change this you need to edit /etc/sudoers using visudo. More details can be found within the man page for sudo and within the file itself. Normally there is no root user and user pi has been given enough privileges to perform essential tasks w/o re-asking for a password."
Or to put it another way it appears tha even though Raspbian / Raspberry OS is a *nix it isn't configured/secured out of the box like a typical multi-user *nix system.
Posted: 04:11pm 25 Sep 2021
OK, so you're either not included in group gpio or need to re-login.
You can check with commands such as
id
or
groups
Posted: 05:47pm 25 Sep 2021
  JohnS said  OK, so you're either not included in group gpio or need to re-login.
id
or
groups
After power-cycling:
pi@raspberrypi:~ $ groups pi
pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
pi@raspberrypi:~ $ id
uid=1000(pi) gid=1000(pi) groups=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),
60(games),100(users),101(input),108(netdev),997(gpio),998(i2c),999(spi)
pi@raspberrypi:~ $
Edited 2021-09-26 03:52 by lizby
Posted: 06:02pm 25 Sep 2021
  robert.rozee said  pkexec su -c "$cmdstr"
Then I get:
> load "pinpi1.bas"
> run
==== AUTHENTICATING FOR org.freedesktop.policykit.exec ===
Authentication is needed to run `/bin/su' as the super user
Authenticating as: root
Password: Error in line 37: Command could not be run
If I run it with sudo mmbasic, I don't get the "AUTHENTICATING" error, but get:
pkexec su -c  echo '12' > /sys/class/gpio/export 2>/dev/null
Posted: 06:15pm 25 Sep 2021
  lizby said  ...
I need to include the actual return value from system() in that error message.
Bit busy at the moment though, having to rebuild my mum's laptop
scruss
Posted: 04:44pm 26 Sep 2021
  thwill said  It's not my area, but I've had the briefest of looks and it appears you are expected to have sudo privileges to access the GPIO on the Pi.
That used to be the case, but in the last couple of years (== aeons in Raspberry Pi time) it hasn't been necessary. Unfortunately, there's no one clear way of doing it:
* WiringPi, while still supplied as a system package, is no longer supported. The author walked away from it after a bad experience from Raspberry Pi clone manufacturers. For now, there's some community support, but it may not work on newer machines.
* pigpio is well supported and runs on all Raspberry Pis. It has a daemon that runs with root privileges, and user processes talk to that.
* the official/"correct" way is the kernel /dev/gpiochip* devices, but support for that is very limited so far.
Nice work on this port to all involved, btw. I'm glad it doesn't run a core flat out like the Raspberry pi version used to.
toml_12953
Posted: 07:06pm 26 Sep 2021
It wouldn't hurt to try staring BASIC with sudo just to test it.
Posted: 10:11pm 26 Sep 2021
  toml_12953 said  It wouldn't hurt to try staring BASIC with sudo just to test it.
That's the only thing that has worked for me with this SYSTEM method of reading/setting pins.
Posted: 06:52am 27 Sep 2021
If you want maximum speed then pigpio calls are the way to go but in that case the process must be started with sudo. If you use the pigpio daemon then the process won't need to be run with sudo but there are limitations to what the daemon supports. "File" access to I/O is very slow.
I recommend the book "Raspbery PI IOT in C" by Harry Fairhead (ISBN 9781871962468). He explains the various options with lots of code examples
Posted: 09:09am 27 Sep 2021
  scruss said  Nice work on this port to all involved, btw. I'm glad it doesn't run a core flat out like the Raspberry pi version used to.
Thanks, I'm please some people are having fun with it.
The MMB4L process takes brief naps when keyboard input is expected but not available (e.g. whilst waiting at the BASIC prompt) or when processing the PAUSE command (though before anyone shouts it doesn't naively just sleep for the length of the PAUSE). This does make PAUSE less accurate (both by limiting its resolution and I believe by increasing the likelyhood of another process grabbing the CPU). I imagine there will need to be some further titivation of this code but in the end Linux is not an RTOS so even if all the digital I/O is implemented there are many controller tasks for which MMB4L on the Pi (and presumably the PiCRomite) are unsuited.
  matherp said  I recommend the book "Raspbery PI IOT in C" by Harry Fairhead (ISBN 9781871962468). He explains the various options with lots of code examples.
Many thanks for the recommendation Peter, I'll add it to my Christmas list.
Posted: 10:59am 27 Sep 2021
  lizby said  After power-cycling:
pi@raspberrypi:~ $
Does it now work without needing to be root/sudo? The above looks good.
Posted: 03:09pm 27 Sep 2021
  JohnS said  Does it now work without needing to be root/sudo? The above looks good.
No. Still fails at "echo 'out' > /sys/class/gpio/gpio12/direction" with "sh: 1: cannot create /sys/class/gpio/gpio12/direction: Permission denied"
But when I immediately run it again, it works for gpio12 and fails at gpio16. If I run it 8 times, it progresses 1 pin further each time, and on the 9th run works. With "sudo mmbasic" it works from the beginning.
Puzzling.
toml_12953
Posted: 03:12pm 27 Sep 2021
Puzzling.
Puzzling is an understatement! Once all pins work, do they keep working for runs 10 and up?
Posted: 03:43pm 27 Sep 2021
  Quote  But when I immediately run it again, it works for gpio12 and fails at gpio16. If I run it 8 times, it progresses 1 pin further each time, and on the 9th run works. With "sudo mmbasic" it works from the beginning.
I wonder why I gave up on the Raspberry Pi
Posted: 04:16pm 27 Sep 2021
Puzzling.
Your previous response showed you had no gpio12 so please explain where it has come from.
You look to have left out important information, thus making assistance impossible.
Please try to provide the same level of detail that Peter would ask for.
BTW, despite Peter's unhelpful snipes (which you would be wise to ignore) I'm afraid it's something you're doing or not doing rather than something wrong with Linux.
Edited 2021-09-28 02:35 by JohnS
Posted: 04:44pm 27 Sep 2021
  JohnS said  BTW, despite Peter's unhelpful snipes (which you would be wise to ignore) I'm afraid it's something you're doing or not doing rather than something wrong with Linux.
Perhaps that is part of it, but the Pi does appear to be quirky and apocraphally GPIO seems to be in a constant state of flux, with different people (I'm not talking about the denziens of TBS) reporting different things on different versions and then writing incoherent solutions that looks like they've done a lot of random sh*t and then guessed what fixed their problem ... or maybe that is just me.
Is there something that needs to be done with /dev/mem ?
https://www.element14.com/community/thread/19995/l/anyone-know-how-to-access-raspi-gpio-without-sudo
Edited 2021-09-28 02:47 by thwill
     Page 3 of 11
