Local Time 06:25 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multiple onewire devices
Chopperp
Posted: 10:47pm 01 Sep 2020
Yes, the mod is specific to my needs & they did work with shorter times.
I was wondering why all readings were taking the same length of time.
Using onewire with multiple devices means you have to get the codes & find out which one is which is obviously done individually but you need track of them. Also, if a sensor is replaced, it's code is needed & software updated accordingly.
One thing I found out yesterday when playing & reading the data sheets & the manual etc was about the strong pull-up that is used in the parasitic mode.
I was always under the impression that you really needed an external deice to do that. (not that I did).
It dawned on me that the data input gets changed to an output & set high for the period required. It even says this for flag 8 in Appendix C.
EDIT
Of course, an external device (MOSFET) can be used if not provided in for firmware.
More playing.
Thanks.
Brian
Edited 2020-09-02 12:13 by Chopperp
ChopperP
Chopperp
Posted: 12:11pm 08 Sep 2020
FYI
Purchased 5 new DS18B20+ sensors from RS after making sure they were not the "P" type.
Results below. Definitely different.
Thanks again Jim for the help & code.
16
Power =  1  -0.5
Power =  1  2804C3360C000054   87  24
Power =  1  2804C3360C000054   163  23.75
Power =  1  2804C3360C000054   312  23.5
Power =  1  2804C3360C000054   612  23.4375
Power =  1  287A0E370C00009E   88  24
Power =  1  287A0E370C00009E   163  24
Power =  1  287A0E370C00009E   312  23.875
Power =  1  287A0E370C00009E   612  23.8125
Power =  1  28FA95370C0000B3   89  24
Power =  1  28FA95370C0000B3   166  24
Power =  1  28FA95370C0000B3   320  23.875
Power =  1  28FA95370C0000B3   627  23.8125
Power =  1  282E46360C000034   89  24
Power =  1  282E46360C000034   166  24
Power =  1  282E46360C000034   318  23.875
Power =  1  282E46360C000034   623  23.875
Power =  1  28AB29360C00004B   88  24
Power =  1  28AB29360C00004B   165  23.75
Power =  1  28AB29360C00004B   317  23.75
Power =  1  28AB29360C00004B   620  23.75
Power =  1   24  bit = 9 q =  0
Power =  1   23.75  bit = 10 q =  1
Power =  1   23.5  bit = 11 q =  2
Power =  1   23.4375  bit = 12 q =  3
Power =  1   24  bit = 9 q =  4
Power =  1   24  bit = 9 q =  5
Power =  1   24  bit = 9 q =  6
Power =  1   24  bit = 9 q =  7
Power =  1   24  bit = 9 q =  8
Power =  1   24  bit = 9 q =  9
Power =  1   23.75  bit = 10 q =  10
Power =  1   23.5  bit = 11 q =  11
Power =  1   23.5  bit = 12 q =  12
Power =  1   23.5  bit = 12 q =  13
Power =  1   23.5  bit = 12 q =  14
Brian
ChopperP
