Local Time 14:48 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.04 beta
     Page 3 of 5
Posted: 10:15am 03 Jul 2020
  Quote  Was this distinct from TTS ? and does TTS provide a mechanism to produce speech through the audio jack (is that what "on the DAC outputs" means) ?
It was a mechanism of playing TTS over the top of a MOD file and due to my poor proof reading didn't make the manual.
PLAY TTS outputs through the audio jack. It uses the SAM TTS code and results are "interesting"
  Quote  On a matter of procedure should we be reporting bugs we find when running 5.05.04 beta in this thread, or in the "CMM2: V5.05.03 Bug Reports" thread ?
Bugs that are in 5.05.03 in the main thread. New bugs here
Edited 2020-07-03 20:18 by matherp
Posted: 10:21am 03 Jul 2020
  matherp said  PLAY TTS outputs through the audio jack. It uses the SAM TTS code and results are "interesting"
Great, I must give it a try. You just mean TTS don't you, not PLAY TTS ... or is there a mistake in the manual?
  matherp said  Bugs that are in 5.05.03 in the main thread. New bugs here
OK ... I apologise in advance for not back-checking any "new" bugs
Posted: 02:36pm 05 Jul 2020
Hi Peter,
I reported these issues before but perhaps they became lost in the scrum.
I think they probably started when I persuaded you added support to allow the 'cmdline' argument to RUN to be a string variable/expression. If so then I put my hand up, "Mea culpa!" Am I correct in thinking that the addition of the EXECUTE command makes my earlier request superflous hopefully meaning you can just back out the offending change?
> Colour Maximite 2
MMBasic Version 5.05.04b3a
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> list "test.bas"
Print Mm.CmdLine$
> run "test.bas", "foo"
foo
> run "test.bas", "foo bar"
foo bar
> run "test.bas", "foo" "bar"
Error: Expression syntax
> *test "foo"
foo
> *test "foo bar"
Error: No closing quote
> *test "foo" "bar"
Issues shown:
1. If the 'cmdline' contains quotes then those quotes should be passed verbatim to MM.CMDLINE$. The manual specifically states: 'cmdline' is not processed by MMBasic
so it can contain numbers, commas, quoted strings, etc.
2. "foo" "bar" should be a valid 'cmdline' not an "Expression syntax" error.
3. There should be no "No closing quote" error for the examples using *.
Posted: 05:18pm 05 Jul 2020
  Quote  Am I correct in thinking that the addition of the EXECUTE command makes my earlier request superflous hopefully meaning you can just back out the offending change?
Yes: I'll back it out at some stage before 5.05.04 is properly released
Posted: 01:05pm 06 Jul 2020
Version 5.05.04b3b
Breaking change
NUNCHUK command replaced by WII NUNCHUK otherwise syntax the same
Bugs fixed
Removed the faulty ability to use the RUN command with a string variable to be passed to MM.CMDLINE$ - use EXECUTE to achieve the same result
Functional changes
Support for FR keyboard - thanks to darthvader
Implementation of CSUBs completed. Header file included in the download including a wide selection of firmware routines that can be called from a CFunction
Improved error reporting of IF statements
Edited 2020-07-06 23:36 by matherp
Posted: 02:24pm 06 Jul 2020
Thanks Peter,
Unfortunately there are still problems using the * command with quoted strings in the cmdline:
> list "test.bas"
Print Mm.CmdLine$
> run "test", foo
foo
> run "test", "foo"
"foo"
> run "test", "foo bar"
"foo bar"
> run "test", "foo" "bar"
"foo" "bar"
> *test foo
foo
> *test "foo"
"foo"
> *test "foo bar"
> *test "foo" "bar"
Posted: 03:12pm 06 Jul 2020
Please download again and make sure the executable is V5.05.04b1c. Either you somehow got an old version or I zipped the wrong one
Posted: 03:26pm 06 Jul 2020
  matherp said  Please download again and make sure the executable is V5.05.04b1c. Either you somehow got an old version or I zipped the wrong one
Looks like it was the former, I seemed to have download b1b.
Anyway it works now, thank you,
Posted: 03:33pm 06 Jul 2020
  Quote  Looks like it was the former, I seemed to have download b1b.
Actually it was very useful as I found a really obscure bug. I have a directory called "test" but not a file "test.bas". When I tried to EDIT "test" I got an error "File not found" instead of it creating the new file - WTF?. This was because the check for existence found the directory and returned OK but when I tried to open it it failed so I've now been through the entire system and now added a check for the return being a directory whenever I test for a file existing.
Andrew_G
Posted: 04:06am 07 Jul 2020
Hello Peter,
Could you possibly check that the link and zip are as you intend?
  Quote  Version 5.05.04b3b
It gives me CMM2V5.05.05b3d.bin but the README.TXT gives the latest as V5.05.04b2d and in your comment on Lunar Lander you refer to 5.05.04b3d as being "just posted".
I am confused . . .
Cheers,
Andrew
(PS: the Lunar Lander works a treat, thanks - not that I have landed it yet)
Sasquatch
Posted: 04:27am 07 Jul 2020
I also downloaded the latest Beta version and it reports 5.05.04b1r on the start screen and CSub is not working?
-Carl
KeepIS
Posted: 05:41am 07 Jul 2020
Have you tried refreshing the cache on the browser, I've downloaded that this morning and the screen says says 5.05.04b2b
Edit that was for the one yesterday evening.
The new file download has the bin file is labelled CMM2V5.05.05b3d.
The file I downloaded late yesterday had a bin file labelled CMM2V5.05.04b2b and that's what is displaying, I have not installed the one I just downloaded via that link.
Mike.
Edited 2020-07-07 15:45 by KeepIS
Posted: 07:09am 07 Jul 2020
  Quote  It gives me CMM2V5.05.05b3d.bin but the README.TXT gives the latest as V5.05.04b2d and in your comment on Lunar Lander you refer to 5.05.04b3d as being "just posted".
Typo in the readme - sorry. Now fixed
Posted: 09:54am 07 Jul 2020
New version is V5.05.04b3e
Bug fixes
Fixed minor colour variations between sprites and drawing commands in Legacy mode
Imposed checks on MODE and OPTION LEGACY commands to only allow legacy in 8-bit colour mode
Allow comment lines in CMM1 sprite files
New Functionality
Additional items added to ARMCFunctions.h
Added additional parameter to SPRITE READ SPRITE READ [#]n, x , y, w, h [,page_number]
This specifies which page to read from. If omitted it defaults to the write page
Other
MMBasic for dos CSUB generation program added to ZIP file
Posted: 01:15pm 07 Jul 2020
  matherp said  New version is V5.05.04b3e
Wow, now that's slipping in a big one. I assume that will allow for graphics--the biggest thing lacking in MMBasic DOS (in my opinion). But if MMBasic/DOS is being looked at for improvement, perhaps I will await developments.
Posted: 01:34pm 07 Jul 2020
  Quote  Wow, now that's slipping in a big one.
Wrong end of the stick I'm afraid
What's included is a program written in MMBasic for DOS that converts .ELF files for the CMM2 into Basic statements
Posted: 01:39pm 07 Jul 2020
Ahh, dang.
Posted: 01:42pm 07 Jul 2020
And, doh.
It's already easy to compile MMBasic for DOS if someone wishes to add features, assuming the appropriate C skills and understanding of the program's structures (so as far as "easy" goes, YMMV).
Edited 2020-07-07 23:43 by lizby
Sasquatch
Posted: 01:43pm 07 Jul 2020
It's actually a MMBasic DOS program that helps generate the MMBasic code for CFunctions (actually CSub) on the CMM2.  So it's really not an enhancement to MMBasic DOS.
Edit: Peter responded while I was typing.  Any way to delete a post?
Edited 2020-07-07 23:45 by Sasquatch
-Carl
Posted: 09:53pm 07 Jul 2020
BUG: RUN is still not passing cmdline verbatim
> list "test.bas"
Print Mm.CmdLine$
> run "test.bas", foo/bar
foo»bar
> run "test.bas", foo\bar
foo¼bar
     Page 3 of 5
