Local Time 21:54 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Thinking about a very low power Micromite
Posted: 02:59pm 06 Nov 2018
More progress:
I've got IR working and by making the IR pin the same as the wakeup pin it means you can use an IR transmitter both to wake up the Armmite and then with a second press to instruct it what to do - in the case of the example below it just prints the IR code. Count inputs are working as is DS18B20. The COM port is working with RS485 support, and PWM works (only three pins).
In the case of DS18B20 the CPU speed is automatically adjusted temporarily if required just for the duration of the onewire communications so that the CPU speed can be very low but you can still read the sensor.
Still to do is getting the ADC working and then adding some display support.
Geoff has confirmed it is OK to distribute the firmware so I should be able to post something fairly complete in the next few days.
CPU sleep 'sleep at 3.3uA until an IR signal is received
IR init a,b,irint 'set up to receive a real command
Loop While c=0
c=0
IR close
End
Sub irint
Print "IR ",a,b
c=1
Pause 200 'needed to stop IR re-triggering the sleep immediately
OA47
Posted: 07:49pm 06 Nov 2018
Fantastic work Peter.
OA47
Posted: 08:11pm 06 Nov 2018
The DHT22 humidity sensor was removed from the firmware and relegated to a CFUNCTION.
Any chance of it returning (or a CFUNCTION for it)?
Just planning where the new critters are likely to end up around here.
palcal
Posted: 09:03pm 06 Nov 2018
@ Jim
RS Components have them $25 but its free courier delivery
Nucleo Dev Board
Posted: 09:25pm 06 Nov 2018
  palcal said   @ Jim
No problems here. I was part of the early rush at Element14.
Mine should turn up this week.
Bill7300
Posted: 09:29pm 06 Nov 2018
Supply could tighten up further, as I see element14 has only 30 available globally. My order is in, so fingers crossed here.
Andrew_G
Posted: 10:11pm 06 Nov 2018
Jim,
are you thinking DS18B20/DHT22 with an HC-12 that is woken up every x minutes if a value has changed? (I've JUST finished converting my 3x "AA" powered units to 5V).
Anyone want to design a carrier PCB?
Andrew
(Off topic but related to the run on supplies - 40 years ago, in the early days of good dehydrated food and computer auto-stocking, I purchased a month's worth for 3 people from a UK supermarket (cleaned them out). I came back from the Himalayas to find they had trebled the shelf space for that product! I kept watching and they hardly sold any more - after a few months they returned to the original shelf space . . .) A.
Posted: 10:45pm 06 Nov 2018
  Quote  The DHT22 humidity sensor was removed from the firmware
Not in my versions
Posted: 12:59am 07 Nov 2018
Not in my versions
My hothouses will be happy
and that makes my wife happy
and that makes me happy.
viscomjim
Posted: 02:17am 07 Nov 2018
@matherp
This port is most excellent and very exciting. Thank you for your effort. uA current is going to lead to very interesting projects!!!!
