Local Time 07:58 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Newie got a few questions
     Page 25 of 25
Posted: 05:06pm 07 Jan 2021
For your original SELECT CASE statement, this from the manual applies:
"When a number of test expressions (separated by commas) are used the
CASE statement will be true if any one of these tests evaluates to true."
So for "Case IS > 0, IS  <= 1"
any number greater than 0 will satisfy the first CASE condition, so you'll always choose 1.bmp.
When you want a range, you use "TO": CASE .0000001 TO 2
But it's usually better to use a calculation when possible than a SELECT statement.
     Page 25 of 25
