Local Time 23:20 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beta Testers Wanted
     Page 24 of 26
JohnL
Posted: 01:08pm 11 Feb 2014
Question for Geoff I guess?
I need to read more precise Analog inputs and a more precise external Analog Vref < AVdd.
Pin 2 on MX150-28pin is designated as external +Vref.
External +Vref can be selected through AD1CON2 bits 13-15 register.
Is there anything to you knowledge that may cause issues in MMBasic by changing AD1CON2 bits 13-15 using Peek/Poke?
bit 15-13 VCFG<2:0>: Voltage Reference Configuration bits
VREFH VREFL
000 AVDD AVss
001 External VREF+ pin AVSS
010 AVDD External VREF- pin
011 External VREF+ pin External VREF- pin
1xx AVDD AVSS
JohnEdited by JohnL 2014-02-12
Posted: 11:11pm 11 Feb 2014
Unfortunately that will not work. To reduce the power consumption (important when the chip is put to sleep) the ADC is turned off most of the time. It is only turned on when a measurement is about to be made (ie, the PIN() function) and also at that time the reference sources are set. So you can poke but it will be overruled when the measurement is made.
I could build a custom version for you with pin 2 as Vref if you like. The issue is that I cannot keep rebuilding a special version every time I come out with a new release so you will be fixed at that version number.
MOBI
Posted: 11:18pm 11 Feb 2014
  johnl said  I need to read more precise Analog inputs
I wonder if building an accurate and stable power supply for the uMite would be a solution. If it is for the uMite, it should be do-able, not sure if the on board PS of the Maxi would get in the way?
David M.
Posted: 11:47pm 11 Feb 2014
Gday John,
A good power supply would be a must but could you read your accurate referrence in via analog in and adjust your inputs acordingly?
For example..
Your referrence is exactly 2.5v but reading with the uMite you get 2.4v.. You could adjust the other analog inputs you read up by 0.1, or would it be a ratio of ( read voltage x 0.1/2.5 x 3.3)..
I dont know for certain that it will work for you but it is worth a go.
Posted: 11:50pm 11 Feb 2014
By no means intending to hijack this thread on it's 39th page, but how are you these days, Mick?Edited by Grogster 2014-02-13
Posted: 11:55pm 11 Feb 2014
Doing really well thank you Groggy,
Had two stents to fix two blockages and back and fully functional... New drug is slowing me down a bit too much but cardio side is all going strong.. Will discuss with the doc when i see him next month...
Posted: 12:08am 12 Feb 2014
Excellent - nice to see you back around the forums again.
JohnL
Posted: 12:59am 12 Feb 2014
Thanks Geoff, Mobi and Mick.
I have applications where precise/stable full 10 bit resolution would be useful for inputs less than 3.3v and the simplest I thought would be to use a typical precision external Vref.
With a more precise/stable supply regulator, may not need a separate external precision Vref?
Analog power and ground are also separate from digital supply and can be from 2.3V to 3.6V, will need to play with that.
I like Micks idea about reading an accurate external Vref via one the analog inputs and use it as a calibration reference for other analog inputs.
External I2C, 10-12 bit ADC is another option, good quality with faster conversion can be expensive. At the moment don't need more than 5 samples (conversions)/sec.
I will play with other options before considering a custom version. Thanks very much for the offer Geoff.
Good to hear that you are getting better Mick.
vasi
Posted: 01:16am 12 Feb 2014
John, what if accepting the offer will help Geoff in Micromite development? Will you reconsider it?
Elvish name: Mablung Miriel
Beyound Arduino Lang
JohnL
Posted: 01:35am 12 Feb 2014
  Quote  John, what if accepting the offer will help Geoff in Micromite development? Will you reconsider it?
Absolutely, but as Geoff has indicated that he can not provide ongoing support for this modification in future updates. I think it would probably be more appropriate to wait until micromite is fully released and becomes more stable. Hopefully after the next firmware release there won't be any significant bugs left, so far only very few bugs have been found.
atmega8
Posted: 03:02am 12 Feb 2014
Ok,
i think "peeking and pokeing" is very interesting and challenging but keep in mind that this could destabilize mmbasic very easy.
If you will be the "master of the beast", than use a compiler or Assembler...
So i think in generall that this is not a good idea, although i asked in this thread for being able to do more with it before ( i have changed my mind about this).
On the other side i would like to ask Geoff why peek and poke ist still a possible instruction?
Also under the aspect that you are searching for every free bit in the PIC.
The concept of mmbasic on a pic (for my understanding) is to provide an easy, robust and cheap Environment. But this also means that the System must be somewhat a closed shop(not in terms of not beeing able to dive in the sourcecode).
If we need more accurancy, higher Resolution for ADC or any other, then i think there are enough Solutions and Chips on the market that can be connected via I2C, SPI, or just Serial protocols.
For example a 1,50$ MICROCHIP - MCP3421A0T-E/CH - 18BIT ADC,4SPS,1CH,SOT23-6 http://www.farnell.com/datasheets/1669442.pdf
Let's concentrate on the "Basics";-).
Go further, faster...
Greetings
from Germany with sunny and spiderless 10-12 degrees temperature
Dietmar
Edited by atmega8 2014-02-13
MOBI
Posted: 11:03am 12 Feb 2014
  john said  External I2C, 10-12 bit ADC is another option, good quality with faster conversion can be expensive. At the moment don't need more than 5 samples (conversions)/sec
I did a post about a year ago using a PIC16F88 as an I2c slave running 7 channels of 10 bit ADC.
At the moment, the control byte only contains the number of the adc channel and starts conversion. The Vref is set to VDD. There is no reason why the control byte could not be used to set up for internal Vref or external Vref. The i2c would allow at least 100 samples per second.
If you are interested, I'm prepared to alter the firmware. Source code (assembly) and Hex code is available. I think we would lose one channel. Then there is the PIC16F1503 which is soic and 14 pin with 8 channels. All do-able
David M.
JohnL
Posted: 11:58am 12 Feb 2014
  Quote  If we need more accurancy, higher Resolution for ADC or any other, then i think there are enough Solutions and Chips on the market that can be connected via I2C, SPI, or just Serial protocols.
1. External devices have always been the option. But that defeats the purpose where you have modern advanced microcontroller with these features already built in.
2. Don't know where you get your pricing $1.50 for MCP3421A0T-E/CH, possibly if you buy them in thousands. In qty 1-25 from Microchip direct they are $2.39 and it is 1 channel device, MCP3428 is 4 channels at $3.56 each. On top of this you need pcb and associated hardware which brings the cost to well over the cost of micromite MX150.
Posted: 01:04pm 12 Feb 2014
FORTY FLIPPIN' PAGES OF THREAD!
Simply WOW.
Life begins at forty....
JohnL
Posted: 03:16pm 12 Feb 2014
I don't know if I should be posting this here, this thread is already getting very long and this post may not be exactly relevant to this thread.
Anyway, Been playing a fair bit with RS485 UART serial ports lately on both Duinomite and Micromite.
Micromite supports DE option on hardware UART com1 with baud rates up to 230400, GREAT! DE option is fantastic for half duplex RS485.
Duinomite as far as I can tell in the 4.4B version only supports DE on COM1 software port that is limitted to 19200 baud.
This is not an urgent requirement, but it would be nice if Duino could use DE on one of its faster hardware UARTS, to be more compatible with Micromite on higher speed RS485 network.
On a separate note.
Both Micromite and Duinomite Uart receive pins are floating (tri-state) when connected to RS485 transceiver in NON receive mode, and this is clearly seen on the scope with a fair bit of floating noise when not receiving data. This may not be a real issue, but I prefer to keep inputs clean and in known state by placing a pull up resistor (4.7K) on RS485 driver or Micromite/Duinomite Uart receive pin.
Edited by JohnL 2014-02-14
Posted: 03:53pm 12 Feb 2014
After I have Finished with the Micromite I intend to retrofit a lot of its features into the Maximite/Duinomite/ColoutMM/etc.
It won't be immediately but that is on the roadmap.
CircuitGizmos
Posted: 05:10am 13 Feb 2014
  Geoffg said   After I have Finished with the Micromite I intend to retrofit a lot of its features into the Maximite/Duinomite/ColoutMM/etc.
THAT is EXCELLENT to hear! Thank you Geoff!
Posted: 02:43am 20 Feb 2014
minor typo in manual, page 12:
"any input change (hi to low or lo to hi)."
(inconsistent usage of lo/low)
page 18:
"uses the DS16B20 function"
(should be 18, not 16)
the above are just from a cursory glance at some bits of the manual.
and a suggestion (if it is not already possible), allow for the LCD and KEYPAD commands to share pins. assuming the r1..r4 pins are driven when scanning the keyboard, there is no reason they can not be shared with the lcd as d4..d7. when the en pin of the lcd module is low these pins are ignored. this would save 4 pins.
rob :-)Edited by robert.rozee 2014-02-21
Posted: 03:37am 20 Feb 2014
page 54:
"OPEN "COM1: 4800, 9BIT" as #1
PRINT "1" + CHR$(211);
PRINT "0" + CHR$(23);
PRINT "0" + CHR$(0);"
shouldn't there be a #1 after each print? (print #1, "1" ...)
page 57:
"Similarly, I2CSEN
is now I2C SLAVE WRITE, etc."
is this not I2C SLAVE OPEN?
kermess
Posted: 01:30am 28 Mar 2014
Good morning.
I would like to participate in the beta testers.
I have a programmer PICKIT3 and several pieces of PIC32MX150F128B.
It is possible that I can provide sufficient documentation and software to get started.
And thank you very much.
David PM
     Page 24 of 26
