| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12056 |
Try this version - PicoMiteRP2350. Add ",QVGA" to the open command and you will get a 320x240 image when you run CAPTURE. I've also tweaked the colours a bit to brighten the image. Motion detect will also work in the higher resolution mode but you need to allocate a big enough buffer 320*240/8-1 PicoMite.zip |
@Peter, I tested the RP2040 VGA version rc19 today, and I am very pleased to see that all programs I tried (mainly games) work flawless. rc19 is a winner. Also pleased with the file manager. I like the fact that when you run a program from the filemanager, and close it, you return to the FM at exactly where you left. very nice. If there is one minor complaint about it, it is the fact that I frequently needed the help screen to learn what keys to press for certain functions (i.e. copy) But it works very nice. Thank you Harm(Volhout). Edited 2026-06-15 00:35 by Volhout PicomiteVGA PETSCII ROBOTS |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 723 |
Hi Peter, two questions: 1) Is there any chance of an HDMIWEB version with 1280x720 resolution being released? (e.g. for the MageDok T090A) 2) Do you think it’s possible to output sound via HDMI? As seen here: https://github.com/fliperama86/pico_hdmi/blob/main/docs/hdmi.md |
No and No. 1: not enough memory, 2: Impossible as all cpu cycles are used with processing tiles, colour maps and layers |
@Peter, Some minor remarks on the built in file manager. Tested on RP2040 VGA using rc19. a/ since FM is a command you only use at commandline, could it be excluded from the keywords ? I had several programs that used the variable "fm" that needed renaming. b/ is there a reason why FM diverts from MMBasic ? Command line F4 starts EDIT (has been that way over a decade). In FM it is F2. MMBasic uses F2 to RUN. F1 to save. c/ the editor in FM makes a backup file. the editor in MMBasic does not. I was editing a file on a near full A:/ drive..... d/ I have several (text) demo programs that help me with calculations. I input some data, they show the result on screen and exit. When I start these from the file manager, I never see the result, because at exit the FM takes the screen. OK, this may not be how you should create programs, but I did. Maybe others as well. Is there a way to prevent this FM kicking in brute force ? Again, minor annoyances on a good filemanager. But maybe simple improvements exist. Volhout Edited 2026-06-15 06:18 by Volhout PicomiteVGA PETSCII ROBOTS |
a: No: it is a command, the tokeniser is used both at the command prompt and in a program and that is how it gets executed. b: No right answer. F3 in the editor is search and it is in FM. Seems odd to then use F2 to clear the search (filter) but I could swap F2 and F4 - don't have a view/care c: Yes it does if you edit a file (edit fname$) which is what FM is doing. d: Again no right answer. For programs that already do an inkey$ loop to exit you would than have to press twice and programs that just end (Petscii) it would also be an irritation. I decided to not do it and leave it up to the programmer to put an inkey loop at the bottom of programs where it is relevant. Not going to change this one. Edited 2026-06-15 07:47 by matherp |
Peter, Other FM (javavi, twofingers, dddns) are invoked with a function key (F9/F5) from commandline. No keyword. But I understand that MMBasic has keywords (RUN/EDIT) that are invoked by F2 and F4. Since these mimick NC, the use of F4 to edit, and F3 to view, it may be coincidental that F4 is used for EDIT. I noticed that in FM you (bottom, orange text) show error messages that have been produced by the running program. It may be an option to add an optional parameter to FM (i.e. FM D) to allow a stopped program to remain at commandline. So you have the option to debug the error (what was the content of a certain variable when the program failed ?). To return to FM you type FM (or FM D) again. OPTION F5 "FM D"+chr$(13) would give you the function key to return to FM in debug mode. I see this (not automatic returning to FM) as the most important improvement. Volhout P.S. for people that run working programs, the FM is a perfect browser. For me, development/debugging is 99% of the time. So for me FM D would be the preferred mode. Or I would need Claude to help me write flawless code first time. Edited 2026-06-15 16:36 by Volhout PicomiteVGA PETSCII ROBOTS |
This is the change I intend to make to FM - comments? Function keys FM Now FM Proposed F1 N/A HELP HELP F2 RUN EDIT RUN (same as return) F3 LIST SEARCH LIST F4 EDIT CLEAR SEARCH EDIT F5 USER COPY COPY F6 USER STOP AUDIO STOP AUDIO F7 USER VOLUME DOWN VOLUME DOWN F8 USER VOLUME UP VOLUME UP F9 USER LIST SEARCH F10 AUTOSAVE MKDIR CLEAR SEARCH F11 XMODEM R N/A MKDIR F12 XMODEM S N/A N/A Edited 2026-06-15 18:19 by matherp |
@Peter, just playing around with a ST7789P3 LCD panel. So far got it working, but: LINE AA seems to have an issue with this driver, as running the code below > list Poke display hres 302 Poke display vres 157 CLS Line 18,82, 301,157 Pause 200 Line aa 18,82, 301,157 > I get an error: [6] Line aa 18,82, 301,157 Error : Display not configured interestingly, the "normal" LINE command (in line 4) runs without any problems, just the AA forces the error. Has nothing to with POKE DISPLAY settings btw. Environment is: > option list PicoMite MMBasic RP2350A V6.03.00RC19 OPTION SYSTEM SPI GP2,GP3,GP4 OPTION SYSTEM I2C GP0,GP1 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION HEARTBEAT OFF OPTION CPUSPEED (KHz) 252000 OPTION DISPLAY 40, 145 OPTION LCDPANEL ST7789, LANDSCAPE,GP5,GP6,GP7,GP8,INVERT OPTION SDCARD GP11 OPTION PLATFORM ST7789-Test 73 de OE1HGA, Gerald |
The ST7789 driver does not support reading from the framebuffer which is required for LINE AA. You could try modifying the ST7789_320 driver instead |
> option list PicoMite MMBasic RP2350B V6.03.00RC19 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM SPI GP14,GP15,GP12 OPTION SYSTEM I2C GP4,GP5 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION PICO OFF OPTION CPUSPEED (KHz) 378000 OPTION LCDPANEL CONSOLE 7 OPTION DISPLAY 30, 53 OPTION LCDPANEL ILI9341, LANDSCAPE,GP16,GP17,GP18,GP11 OPTION DEFAULT FONT 7, 1 It runs perfect now, my main problem was a faulty connection on the data bus. That didn't cause a software error but messed up the colours..sorry my fault. Never the less your tweaking gives a real nice picture. Many thanks! Image taken with save image and QVGA resolution: ![]() Edited 2026-06-15 18:41 by dddns |
@Peter, I think the changes match MMBasic better. Thanks. What about FM D parameter ? Can that be done ? Volhout PicomiteVGA PETSCII ROBOTS |
No, I don't even know it could be done. You could try a mm.end subroutine in the library |
The camera support is very nice and with the QVGA resolution useful for e.g. a selfmade webcam or QR scanner. I tried option lcdpanel ILI9341buff, SSD1963 and virtual_c which are not supported. Would it be possible having an option to let it stream into memory and use blit to display/save? |
Buffered drivers can't work - wrong resolution. You really don't want 153600 bytes permanently allocated to a buffer which is why the ILI9341 is used. Then just use image save to copy the image to disk. In any case, this is complex timing critical code and I'm not making any more changes. Edited 2026-06-15 21:07 by matherp |
Hi Peter, I think your proposed F key changes in FM are a good idea, so that run, list & edit match the command prompt functionality :-) Thanks. |
Peter, I don't know if it is possible to get LIST PINS ALL to work? Jan. |
@Peter, I don't recall exactly, but I thought I had already mentioned this: Perhaps you could consider renaming the file manager command after all? Using just two characters for a non-standard BASIC command is risky, as two-character variables are quite common; this makes conflicts with existing programs inevitable and ensures they will likely crop up frequently in the future. How about "MM.FM" or simply "MMFM" for the file manager command? Otherwise, I think the file manager is great! I did briefly test the last version three weeks ago, though — I’ve been on vacation since then. Best regards. bfwolf Edit: Another idea for different name: How about "FMAN" ? "MMFM" would be easier and faster to type though.. ![]() Edited 2026-06-16 06:10 by bfwolf |
V6.03.00RC20 PicoMiteRP2040V6.03.00RC20.zip PicoMiteRP2350V6.03.00RC20a.zip PicoMiteRP2350V6.03.00RC20b.zip PicoMite_User_Manual.pdf UI changes to the FM command - see the chapter in the manual Fixes bug in LIST SYSTEM I2C Camera command now supports 320x240 capture for applicable RP2350 versions (now including HDMI and HDMIUSB) |
Peter, Thanks. This also solves the problem with LIST PINS. And the explanation in help(F1) in FM is much clearer now. Are F7 and F8 missing? Jan. |
