Local Time 20:51 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC GETTIME....
paceman
Posted: 03:14am 10 Sep 2017
I bought half a dozen when you posted that link Mick. Couldn't get the first one to work then found it had a dry joint to the battery. Fixed that and up it came but only for a few days and then the battery died. About half of them had stuffed batteries but the others were OK - still good though in that they're really cheap and tiny. Pity that the pin-out is a bit different but as you say it's easy to change.
Greg
Posted: 12:07pm 10 Sep 2017
I bought mine without batteries and sourced them elsewhere - this way I only start the battery when required... blimey - just checked - it was a year ago
here are the cells I gotEdited by CaptainBoing 2017-09-11
isochronic
Posted: 02:41am 11 Sep 2017
Are they working Grogster ?
If the battery is spot-welded in, they are probably meant as throw-aways anyway. I guess the question becomes, how much confidence can you now have, that they will keep functioning or how accurate they will be.
paceman
Posted: 03:07am 11 Sep 2017
The tabs are spot-welded onto the battery and the tabs then soldered to the PCB. Similar arrangement of tabs to CaptainB's link except the +ve tab has a double right angle bend so that it extends down alongside the -ve tab to solder to the PCB pad. At a pinch CaptainB's could be soldered to the same position as these without a small link.
The batteries on the ones I got from Mick's link had CR1025 buttons, not CR1220's but the CR1220's would probably fit; there might be a very small PCB overlap.
Greg
Posted: 11:57am 11 Sep 2017
@ chronic - Yes, the new ones seem to be working fine - time included. I have used these ones before, and had no problems, so this thread was a new one to me. Again, you can't expect too much with the clones - if anything reliable at all. As mentioned, I suppose I could extract the clone and put a genuine Dallas chip on the module if I wanted to be really sure.
Chrisk
Posted: 08:30am 14 Dec 2017
Hi Grogster and All
I have just had the same problem. Did a search on TBS and found your post.
Can you give me the site from which you purchased the good ones. I don't want to purchase more of the same.
Chris K
Posted: 03:11am 15 Dec 2017
Page two, post two....
Chrisk
Posted: 09:34am 15 Dec 2017
Thanks Grogster.
Couldn't see for looking.
Did it really take 30-50 days? Seems a bit slack.
I noticed it doesn't have the pin outs labelled.
Found it on a Bigmik post.
Posted: 10:35pm 15 Dec 2017
30-50 days - not sure. I've had a quick scan through this thread, but can't see where I reference that kind of delay. Some things do indeed take ages to arrive. eBay is notorious for that. I prefer AliExpress these days, as they seem to be much faster on the whole.
