Forum Index : Microcontroller and PC projects : Odd serial data for micromite
you seem to be missing the SETPIN statement. cheers, rob :-) |
Can't see anything in the code which would make it MX470 specific and Jim's experience seems to support it working fine on MX170. This is precisely the sort of application it was intended for |
Thanks for the reply Rob but I only posted a snippet of the code which did have the SETPIN statements in it. Peter, thanks it looks like using the Bitbanger Csub may be the next method to try. Do you think that I could use the COM2 TX PIN as DOUT to send out the timing and serial stream query then open the COM port ready to receive the reply? Just to check my maths, 1200 bps data would mean each bit would be 0.833mS in length? Graeme |
More into the quagmire Decided to give the Bitbanger CSub a go so I loaded the code into the 170 saved the library and wrote a bit of code to test it. Pin 7 has a LED attached so I thought I would send some pulses to it but here is the result. > run [LIBRARY] CSubB bitbangerB Error: Unknown command > library list CSubB bitbangerB B B B B 00000000 B B B B 27BDFFC0B AFBF003CB AFBE0038B AFB70034B AFB60030B AFB5002CB AFB30024B AFB20020B B B B B AFB1001CB AFB00018B AFB40028B 3C109D00B 8E030000B 00808821B 8E020080B 8C640000B B B B B 00A09021B 00002821B 00C0B021B 0040F809B 8E140064B 00409821B 8E02009CB 3C0449F4B B B B B 0040F809B 24842400B 00402821B 0280F809B 02602021B 0040B821B 8E240000B 8E020024B B B B B 24050007B 0040F809B 241E0001B AFA20010B 8E020028B 0040F809B 8E240000B 8E520000B B B B B 8E030040B 005EF004B 0060F809B 00122080B AFA20014B 12400013B 0040A821B 0000A021B B B B B 00008821B 3C139D00B 0014A080B 02D41821B 8C640000B 8E620058B 8E70007CB 0040F809B B B B B 02E02821B 26310001B 0200F809B 00402021B 02B4A021B 0232182BB AE820000B 1460FFF2B B B B B 0220A021B 8FA30014B 3C040008B 8C620000B 2442FFFDB AC620000B 3C03BF88B AC641064B B B B B 3C03BF88B 00001021B AC601068B 40824800B 8FA50014B 8FA30010B 2652FFFFB AC7E0000B B B B B 8CA40000B 00442021B 40024800B 0044182BB 1460FFFDB 00000000B 1640FFF6B 24A50004B PRESS ANY KEY ... > ? mm.ver 5.0404 Can someone help with the reasons I get all these "B"'s saved with the CSub? |
No problems here I tried it with V5.2 and 5.4.4 Is all OK when you do a LIST befroe saving into the library? Jim VK7JH MMedit |
Jim, all looked ok before I saved it to the library. I will clear the chip and try again. Graeme |
It seems the corruption is happening when I paste from TERATERM. The code in the TERATERM Clipboard is OK but the B's appear when I paste using AUTOSAVE. I had originally saved the code from Peter's post to a text file for future reference and this post had diagrams imbedded so there must have been unprintable characters imported across. Cutting and pasting from Jims post fixed the problem and guess what the LED flashes. Now to see if I can talk to this device................... Graeme |
Found more information on the device which mentions that the serial logic is reversed and needs to be logic 0 @ 3.5-5.5V and logic 1 @ -0.5-1.0v. To over come this I had a spare 2803 inverter which gives me the required logic levels and inversion. I have tried the following code with the Bitbanger outputting on PIN 14 and monitor the outgoing and incoming with COM1 RX. The query command needs to have the address as the first character (represented in earlier documentation by the letter a)so the query for info should be >12mS Break (3.5-5.5V) followed by a >8.5 mS Mark (-0.5-1.0V),then the address 0 (all units supplied at address 0 and can be individually changed)followed by the letter I then ended by the Exclamation Mark. I seem to be setting up the Query string OK as monitored by the COM1 port but I still cannot capture a REPLY. If someone can see an error in my code or a bad assumption I would love to know. RTC GETTIME SetPin 2,AIN 'PV Voltage SetPin 3,Ain 'SLA Voltage SetPin 4,AIN 'EXT ANALOG IN 2 (SOL 2 Pressure) SetPin 5,AIN 'EXT ANALOG IN 1 (SOL 1 Pressure) SetPin 6,DOUT 'SOLENOID 1 SET [5V] (Prev DS18B20) SetPin 7,DOUT 'INDICATOR LED (COM1 EN|DIGITAL|INT|ANALOG|3V) SetPin 9,DOUT 'COM2 TX (Pin 3 Labelled OUT on connecter) SetPin 10,DOUT 'COM2 RX (Pin 2 Labelled IN on connector) SetPin 14,DOUT 'SOLENOID 2 RESET [5V] SetPin 15,DIN 'MODEM CD AND TEST BUTTON (DB15[14]) SetPin 16,DOUT 'MODEM PTT (WAKE FROM SLEEP & DB15[13]) SetPin 17,DOUT 'RTC I2C CLK (DIGITAL|COUNT|5V) SetPin 18,DOUT 'RTC I2C DATA (DIG|COUNT|5V) PREV CIN RADIO AF OUT 'SetPin 21,DOUT 'COM1 TX (DB15[2] J2-??) 'SetPin 22,DOUT 'COM1 RX (DB15[4] J2-??) SetPin 23,AIN 'EXT ANALOG IN 3 SetPin 24,AIN 'EXT ANALOG IN 4 SetPin 25,DOUT 'SOLENOID 1 RESET SetPin 26,DOUT 'SOLAR SHUTDOWN & LED D3 (PREV PWM OUT/RADIO AF IN) Dim BRDTEMP Dim REPLY$ RTC GETREG 2,BRDTEMP Print Time$,Date$,"BOARD TEMP=";BRDTEMP;" DEG C" Open "COM1:1200,INV" As #1 'OUTPUT VIA 2803 TO GET 5V & INV Dim FLOAT TRQ(30) For I =0 To 17 Read A TRQ(I)=A Next I Pin(7)=1 'SET THE INDICATOR LED TO ON Pin(14)=1 'START THE BIT TRAIN AT 0V BITBANGER(14,18,TRQ()) Pin(7)=0 'SET THE INDICATOR LED TO OFF Pause 100 REPLY$=Input$(10,#1) Close #1 Print " 8 BIT QUERY STRING IS ";Left$(REPLY$,3) Print " 8 BIT REPLY STRING IS ";Right$(REPLY$,(Len(REPLY$)-3)) Print "CHR#","8BIT ASC","7BIT ASC" For J = 1 To Len(REPLY$) Print J,Asc(Mid$(REPLY$,J,1)),,Asc(Mid$(REPLY$,J,1)) And 127 Next J 'ADDRESS QUERY ?! 'ACKNOWLEDGE ACTIVE 0! 'SEND IDENTIFICATION 0I! Data 12500,8500 '12.5mS BREAK THEN 8.5mS MARK Data 4165,1666,1666,833 '0 = -----__--_ Data 833,833,1666,833,1666,2499 'I = -_--_--___ Data 833,833,3332,833,1666,833 '! = -_----_--_ > RUN 20:16:38 28-06-2017 BOARD TEMP= 32 DEG C 8 BIT QUERY STRING IS 0É! 8 BIT REPLY STRING IS CHR# 8BIT ASC 7BIT ASC 1 48 48 2 201 73 3 33 33 |
Pin(14)=1 'START THE BIT TRAIN AT 0V should be Pin(14)=0 'START THE BIT TRAIN AT 0V You really need a logic analyzer or storage cro! Jim VK7JH MMedit |
Thanks for the comment Jim, I am a long way from the shed at the moment so I have to try and deal with the minimum of test equipment. The most sophisticated equipment I have is a 30 year old digital multimeter with a low battery. The reason that the PIN(14) is around the other way is because I am inverting the output through the 2803. Graeme EDIT; Just re-measured to be sure, pin(14)=1 is 0.64v and pin(14)=0 is 5.02V |
| GoodToGo! Senior Member Joined: 23/04/2017 Location: AustraliaPosts: 188 |
Do you have a link to any datasheets or info on the module you are trying to communicate with? Might help us try to work out what's going on..... Cheers, GTG! ...... Don't worry mate, it'll be GoodToGo! |
Thank you @GTG for taking an interest in my plight, I have found many snippets of information some that seem to conflict with others but here are a couple: PROBE COMMANDS User Manual Using arduino to talk to sensors sdi-12 support group @ Peter. Is there a way that I can use the Bitbanger CSub with a variable for the number of transitions so that I can dynamically build the pulse train with Basic? Graeme |
I have scratched together some very clumsy and untidy code that will dynamically re-order the bit train from a LINE INPUT command string to a 1200,7,e INVERTED serial stream. The device echoes the commands accurately so I think I have the coding right but still refuses to reply with any data. '****************************************************************************** '* Micromite MMBasic Version 5.4.4 on PICMX170F56B-50I/SP 28 PIN DIL Chip * '* * '* File: RCSV6SDITEST8 PROGRAM FOR SDI-12 SOIL MOISTURE PROBE 01/07/2017 * '* * '* ENVIROPRO SOIL MOISTURE SENSOR SDI-12 (1200,7,E,1,INV) * '* * '****************************************************************************** Option EXPLICIT RTC GETTIME SetPin 2,AIN 'PV Voltage SetPin 3,Ain 'SLA Voltage SetPin 4,AIN 'EXT ANALOG IN 2 (SOL 2 Pressure) SetPin 5,AIN 'EXT ANALOG IN 1 (SOL 1 Pressure) SetPin 6,DOUT 'SOLENOID 1 SET [5V] (Prev DS18B20) SetPin 7,DOUT 'INDICATOR LED (COM1 EN|DIGITAL|INT|ANALOG|3V) SetPin 9,DOUT 'COM2 TX (Pin 3 Labelled OUT on connecter) SetPin 10,DOUT 'COM2 RX (Pin 2 Labelled IN on connector) SetPin 14,DOUT 'SOLENOID 2 RESET [5V] SetPin 15,DIN 'MODEM CD AND TEST BUTTON (DB15[14]) SetPin 16,DOUT 'MODEM PTT (WAKE FROM SLEEP & DB15[13]) SetPin 17,DOUT 'RTC I2C CLK (DIGITAL|COUNT|5V) SetPin 18,DOUT 'RTC I2C DATA (DIG|COUNT|5V) PREV CIN RADIO AF OUT 'SetPin 21,DOUT 'COM1 TX (DB15[2] J2-??) 'SetPin 22,DOUT 'COM1 RX (DB15[4] J2-??) SetPin 23,AIN 'EXT ANALOG IN 3 SetPin 24,AIN 'EXT ANALOG IN 4 SetPin 25,DOUT 'SOLENOID 1 RESET SetPin 26,DOUT 'SOLAR SHUTDOWN & LED D3 (PREV PWM OUT/RADIO AF IN) Dim BRDTEMP 'TEMPERATURE MEASUREMENT FROM RTC Dim REPLY$ 'ECHOED QUERY AND STRING RETURNED BY DEVICE Dim ASV(10) 'ASCII VALUE OF EACH CHARACTER TO SEND Dim BINV$(10) 'MSB-LSB BINARY STRING OF EACH CHARACTER TO SEND Dim INVB$(10) 'LSB-MSB BINARY STRING OF EACH CHARACTER TO SEND Dim PAR$(10) 'INVERTED EVEN PARITY BIT(CALCED ON ZEROS NOT ONES) Dim TENBIT$(10) 'TOTAL TEN BITS INCL PARITY, START AND STOP BITS Dim PARTLENGTH(10) 'TOTAL PULSE TRANSMISSION TIME Dim BL=833 'NUMBER OF uS FOR EACH BIT LENGTH AT 1200 BPS Dim FLOAT BitBangTrain(49)'BITBANG ARRAY ALLOWING FOR 50 TRANSISTIONS Dim F,G,H,I,J,K,L,M Dim QUERY$ 'COMMAND READ AT LINE INPUT Dim ZEROS 'ZERO COUNT IN BINARY STRING Dim BITS$ 'EACH BINARY BIT READ OUT OF STRING Dim BITLENGTH 'No OF TRANSITIONS IN BIT TRAIN RTC GETREG 2,BRDTEMP Print Time$,Date$,"BOARD TEMP=";BRDTEMP;" DEG C" Print "ENTER COMMAND "; Line Input QUERY$ For F=0 To 49:BitBangTrain(F)=0:Next F BitBangTrain(0)=12500 BitBangTrain(1)=8500 H=1 'BitBang ARRAY POINTER For I = 1 To Len(QUERY$) ASV(I)=Asc(Mid$(QUERY$,I,1)) 'GET THE ASCII VALUE OF EACH LETTER BINV$(I)=Bin$(ASV(I)) 'CONVERT THE ASCII VALUE TO BINARY 'PAD OUT BINARY TO 7 BITS If Len(BINV$(I))=2 Then BINV$(I)="0"+BINV$(I) If Len(BINV$(I))=3 Then BINV$(I)="0"+BINV$(I) If Len(BINV$(I))=4 Then BINV$(I)="0"+BINV$(I) If Len(BINV$(I))=5 Then BINV$(I)="0"+BINV$(I) If Len(BINV$(I))=6 Then BINV$(I)="0"+BINV$(I)'HAVE 7 BIT BINARY FOR EACH CHAR ZEROS=0 For J= 7 To 1 Step -1 BITS$=Mid$(BINV$(I),J,1) INVB$(I)=INVB$(I)+BITS$ 'CONVERT BINARY STRING TO LSB-MSB If BITS$="0" Then ZEROS=ZEROS+1 'COUNT THE ZEROS IN THE 7 BITS Next J 'SET PARITY BIT TO 1 IF EVEN If ZEROS Mod 2=0 Then PAR$(I)="1" Else PAR$(I)="0" TENBIT$(I)="0"+INVB$(I)+PAR$(I)+"1" 'FINAL TEN BITS=TENBIT$(I) BITLENGTH=1 'THE FIRST TRANSITION BL IN LENGTH For K=1 To 10 '2ND AND FOLLOWING TRANSITIONS 'CHECK FOR CONSECUTIVE HIGHS OR LOWS If Mid$(TENBIT$(I),K,1)=Mid$(TENBIT$(I),K+1,1) Then BITLENGTH=BITLENGTH+1 'ADD TO TRANSITION FOR EACH CONSEC Else PARTLENGTH(I)=BITLENGTH*BL 'TOTAL TRANSITION TIME H=H+1 'INCREMENT BitBang ARRAY POINTER BitBangTrain(H)=PARTLENGTH(I) 'ADD TRANSITION TO BITBANG ARRAY BITLENGTH=1 'RESTORE TRANSITION TO ONE BIT EndIf PARTLENGTH(I)=0 Next K Next I Pin(7)=1 'SET THE INDICATOR LED TO ON Pin(14)=1 'START THE BIT TRAIN AT 0V 'OUTPUT VIA 2803 TO GET 5V & INV Open "COM1:1200,INV" As #1 'MONITOR OUTGOING AND READ INCOMING BITBANGER(14,50,BitBangTrain()) Pin(7)=0 'SET THE INDICATOR LED TO OFF Pause 250 REPLY$=Input$(20,#1) Print " 8 BIT SERIAL MONITOR ";REPLY$ Print "CHR#","8BIT ASC",,"7BIT ASC" For J = 1 To Len(REPLY$) Print J,Asc(Mid$(REPLY$,J,1)),Chr$(Asc(Mid$(REPLY$,J,1))), Print ,Asc(Mid$(REPLY$,J,1)) And 127 ,Chr$(Asc(Mid$(REPLY$,J,1)) And 127) Next J Print "_____________________________________________________" Close #1 Here is the RUN screen... RUN 15:57:29 01-07-2017 BOARD TEMP= 21 DEG C ENTER COMMAND 0C5! 8 BIT SERIAL MONITOR 0Ã5! CHR# 8BIT ASC 7BIT ASC 1 48 0 48 0 2 195 Ã 67 C 3 53 5 53 5 4 33 ! 33 ! _____________________________________________________ > This command is supposed to return the temperature of the probe.......... I am running out of ammunition at this stage so any help or comments would be greatly appreciated. Graeme |
Does it need a CR or CR/LF ? VK7JH MMedit |
Gday Jim, I did read on one piece of info that the commands did need a CR/LF and I did try it to no avail but most of the other reference material state that the exclamation mark is the character that denotes the end of the command. Thanks |
Reading the SDI12 spec, the sensors can take up to 100mS to wake up after a break is detected. So you may have to do a few retries. Have a look at sections 7.0-7.2 of the SDI Spec. I haven't got any SDI12 sensors so I can't test your code. Cheers, GTG! ...... Don't worry mate, it'll be GoodToGo! |
Thanks for the reply GTG, I have monitored the 12V current draw of the probe which sits at 500uA on idle and up to 18mA once queried, so I believe that the probe is waking from sleep ok. Graeme |
I would start with the ?! command. Until you know for sure what the address is, the rest is hit and miss. The SDI-12 spec sheets make it look so simple! I haven't read anything obvious yet. Jim Edit: What are you doing to the TX line while you are listening for a response? I think it would have to be high impedance to stop swamping the response from the probe. Can the inverter you are using go tri-state? Jim VK7JH MMedit |
Jim, thanks for your input, I don't think there is any way I could make the ULN2803 line driver chip go tri-state. Currently I have the output pulled to 5v via a 1K resistor. I could possibly increase that value and try to maintain the correct logic voltages. Graeme |
From the SPI specs also: From that, I understand that the internal impedance of your sensor when transmitting is 1-2K The 1K at the 'mite end will certainly get in the way. You need some way of making it high Z when not transmitting. You do need some sort of level translator because the bus needs the 5V to work. Got any 4016 IC's in the drawer? VK7JH MMedit |
