Forum Index : Microcontroller and PC projects : Micromite Firmware V5.03
@evbo I have started a new post for this topic rather than overtake Geoff's 5.3 release post - hope that's OK? Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| piclover Senior Member Joined: 14/06/2015 Location: FrancePosts: 134 |
Bump ! Any news on this front ? |
No, sorry. It is on the list for the next version but it is going to take some more time. Geoff Geoff Graham - http://geoffg.net |
Geoff, a small 'bug' in the V5.03.02 MMBasic Plus Manual. The top line of page 36 says: Refer to the pinout diagrams in the “Micromite Manual” for the I/O pin numbers to use with the keyboard. in reference to the clock and data pins for the PS2 keyboard. This should read: Refer to the pinout diagrams in section "Micromite Plus Connections" of this manual for the I/O pin numbers to use with the keyboard. Greg |
Thanks Greg. Geoff Graham - http://geoffg.net |
Just wondering if the SSD not connected issue can be addressed at some point in 5.3. Had a quick look in the release notes & don't see it mentioned. Noticed previously that PeterM wrote some C-code to check. Cheers Phil. |
Hi Geoff, Just noticed that Page 46 of the manual doesn't mention the flash capability of GUI LED. [Code]The GUI LED can now be instructed to flash, ie, turn on for a short time then automatically turn off. This is accomplished by setting the value of the LED (using CtrlVal(#ref) = ) to the number of milliseconds that it should remain on. As before, setting its value to one will turn it permanently on and zero will turn it off.[/code] Cheers Phil. |
Regarding defining GUI objects. Is this a feasible suggestion regarding this fragment of code. Could CtrlVal's be initially assigned when the control is defined? Bit like:- DIM INTEGER Runtime & DIM INTEGER Runtime=60 And if so, would it be correct to say it would save 52 bytes of program memory in this example? CtrlVal(SwT1) being 13 characters in the above. Just a thought that came to mind whilst looking at my code. It's the memory saving with lots of controls & longer names that had me thinking. Cheers Phil Edit: Had to give posting in colour a try. |
I cannot reproduce the "bug" that you refer to and there is nothing that I can see in the code that would make the console stop working when a display is removed. I don't know what caused the problem that you and WW experienced but it could a power glitch or a hiccup that upset Tera Term. Peter's code was related to reading from the display and not the console/LCD interaction. Geoff Geoff Graham - http://geoffg.net |
I think that I can see what you are suggesting. On the surface it looks good but it introduces a complicated and non obvious syntax. Either way you will be defining a new identifier so the memory usage would be the same. I don't think that trying to save a few bytes of RAM is worthwhile but if it was important you could just use literal numbers instead of defining constants. Geoff Geoff Graham - http://geoffg.net |
| PicFan Senior Member Joined: 18/03/2014 Location: AustriaPosts: 133 |
Hello Geoff ! Please try this, look at the Output ! V5.3.0.2 frq = 414000250 print str$(frq,9,0) frq = frq + 156250 print str$(frq,9,0) end OUTPUT: RUN 414000256 414156512 > Thank you ! Wolfgang |
Set frq as an integer and then try again. You are outside the resolution of single precision floats |
ie, use fre% instead of fre however, this isn't quite right: i=1000000 Print Str$(i) > run 10.00000e+05 > cheers, rob :-) addendum: it is actually more simply shown with: > > Print 1000000.0 10.00000e+05 > the ".0" at the end just ensures that the value isn't converted to a 64-bit integer before being printed. |
With "integer" it works correct ! Thank you ! Wolfgang |
I have finally got the time to start on the bug list and this is one of the first that I have found and fixed - the fix will be in the next version. But I just wanted to say a big thanks for the succinct demo code, it was a huge help in nailing a subtle bug. Geoff Geoff Graham - http://geoffg.net |
Hello Geoff, hello Peter M. ! First of all thank you for your fantastic work, it is great. I have a little problem with "Control C" and "Continue". It ist only with Version V5.3, Micromite MK2 and Micromite plus explore 64. V5.2 works correct. Please, try this ! OPTION EXPLICIT OPTION DEFAULT INTEGER DIM A$ DIM x DIM z REM TEST 1 OK DO PRINT "ABC" PAUSE 200 LOOP "RUN" ABC ABC ABC ... "Control C" > "CONTINUE" ABC ABC ... -------------------------- REM TEST 2 FAIL DO a_SUB1("XYZ") LOOP "RUN" XYZ XYZ ... "Control C" > "CONTINUE" [8] Loop Error: LOOP without a matching DO --------------------------- REM TEST 3 FAIL DO a_SUB1("XYZ") x = z LOOP "RUN" XYZ XYZ ... "Control C" > "CONTINUE" [8] x = Z ERROR: X not declared --------------------------- REM TEST 4 FAIL DO z = a_FUNC1(5) PRINT z LOOP "RUN" 15 15 ... "Control C" > "CONTINUE" > "CONTINUE" > With a "Function" Continue works not ! --------------------------- REM SUBROUTINE and FUNCTION sub a_SUB1(a$) print a$ pause 200 end sub function a_FUNC1(b) a_FUNC1 = b * 3 pause 200 end function I use MM-EDIT 3.7.0 Thank you ! Wolfgang |
I will look at it but my first instinct is to remove CONTINUE entirely. CONTINUE worked well in the early versions of MMBasic which were much simpler (without subs, CFunctions, etc). But now the interpreter needs to keep track of so many different states (eg, is it inside a function? is it timing a temperature measurement? etc) that it is almost impossible to restore everything after a break. Geoff Geoff Graham - http://geoffg.net |
Hello Geoff ! Please try this ! option autorun on option explicit option default integer dim test1 = 3 on error skip RTC gettime if (mm.errNO <> 0) then print "RTC NICHT VORHANDEN, interne Uhr wird verwendet !" print "" endif print test1 end "RUN" RTC NICHT VORHANDEN, interne Uhr wird verwendet ! ERROR: test1 not declared ! Thank you ! Wolfgang |
| rentner111 Newbie Joined: 18/03/2014 Location: AustriaPosts: 19 |
Hello Geoff! First - the Mikromite with your MM-Basic is the best for hobby programming in Basic of all times. I've already written some programs and used them. The programs are partly up to 40kB. but: I had to go back to Version V5.2 from version V5.3B10. The key function Control-C and the subsequent CONTINUE no longer works if a SUB is present in the program. Again: in version B5.2, CONTINUE works flawlessly, but in version B5.3 no longer works. Please DO NOT remove the CONTINUE function as it makes debugging and testing the hardware very easy for large projects. Thank you in advance |
