Local Time 13:02 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 7 segment number font
palcal
Posted: 11:27am 22 Feb 2016
It's not a wall plate it is actually a box from Jaycar I had lying around. It is powered from a 5v. plugpack or USB socket.
The code is basically Geoff's clock code with a couple of additions. It needs a bit of cleaning up I will release it when finished.
Paul.
Posted: 06:32pm 23 Feb 2016
Paul,
I have released the first attempt at a font tweaking program
It includes a seven segment font with the 1,4 and 7 stretched a bit.
http://www.thebackshed.com/forum/forum_posts.asp?TID=8386&PN=1&TPN=1
It has a few rough edges but should do the job.
mbramwel
Posted: 06:35pm 25 Feb 2016
Just a reminder for you linux guys out there, I wrote a small program that will convert common bdf fonts to maximite format.
If you can find a font out there that looks good, convert it and use it on your machine.
http://www.foxhollow.ca/maximite/?menu=fonts
mbramwel
Posted: 06:52pm 25 Feb 2016
Just to followup to my own reply... I did a google search for "led.bdf font" and found lots of very interesting True Type downloadable LED styled fonts.
download the True Type font.
Use the linux ttf2bdf converter to make a X11 bdf font.
then use my script to convert the bdf font to a maximite font.
