Local Time 20:21 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : stmF7Mite repport
     Page 2 of 6
phantomnet
Posted: 09:51pm 26 Sep 2015
Zonker:
Board is STM32F746G-DISCO from ST
link
Firmware is MMBasic 4.5 like in this topic.
derexponent
Posted: 01:04am 27 Sep 2015
i just uploaded a new version (a36)
> 10 color blue,white
> 20 print "asdasda"
> run
asdasda
its not working !!!
should work now
and here a video with 3D-Objects-Functions from Fabrice
3dObjects-video
here a second video to demonstrate the multitouch
multitouch
leave a comment if spi should have more settings
(like LSB/MSB, more speed options)
UweEdited by derexponent 2015-09-28
derexponent
Posted: 01:40am 27 Sep 2015
  Zonker said   I was wondering if support for the A/D and D/A hardware would be included...
Anyway.. Nice work Gent's..!
ADC is comming next --> EDIT : ADC is working with new update A.37
but the two DAC-Ports are not routed to the Arduino connector
(and used for other functions)
but the board has a two channel sound DAC on a headphone jack
so maybe we can handle analog output at this way
or PWM at a normal GPIO with an external RC filter.
phantomnet
Posted: 11:23am 27 Sep 2015
Uwe:
SPI working good. If You can add more options it will be more flexible.
I have found another issue:
Some times (every 20-30sec) during do/loop in test sub lcd loosing horizontal synchro for 1-2 frames.
It is simple scanner using RF1100SE board with CC1101 chip.
Sub test()
graph_init() 'draw layout
spi_setup() 'spi setup
cc1101_setup() 'set CC1101 registers
For cc= 0 To 63 '64 channels
Line((cc*4)+204,210)-((cc*4)+206,20),Black,BF 'clear prev draw
spiWriteReg(&h0A,cc) ' set new channel
rr=RSSI(spireadreg(&hf4)) ' read RSSI level
Pixel((cc*4)+204,100-rr)=Red ' draw level dots
Pixel((cc*4)+205,100-rr)=Red
Pixel((cc*4)+206,100-rr)=Red
If tocz(5,22,85,72)=1 GoTo go_out 'check touch
Next cc
go_out:
SPI close 1 'close spi
Sub graph_init()
Color White,Black
Cls 0
Line(0,0)-(479,18),50712,BF 'top status bar
Line(5,22)-(85,72),50712,BF 'draw button
Color Black,50712 'color for button label
Print @(19,41) "Stop scan" 'botton label
Line(203,24)-(459,24),Blue
Line(203,222)-(459,222),Blue
'drawing dots net
For i=0 To 23 Step 4
Line(203,24+(i*8))-(459,24+(i*8)),Blue
Next i
For i=0 To 32 Step 4
For j=0 To 24
Line((i*8)+203,219-(j*8))-((i*8)+203,217-(j*8)),Blue
Next j
Next i
Function tocz(x1,y1,x2,y2)
Local n
n=MTouched(#s)
If (n=1) Then
x=MTouched(#x,1)
y=MTouched(#y,1)
If (x>=x1)And(x<x2)And(y>y1)And(y<y2) Then
tocz=1
Else
tocz=0
Else
tocz=0
End Function
' CC1101 SPI functions
Function RSSI(val)
If val>=128 Then RSSI=((val-256)/2)-74
If val<128 Then RSSI=(val/2)-74
End Function
Sub SPI_setup()
' SPI port setup
SetPin 9,din ' GDO0 = D08
SetPin 10,din ' GDO2 = D09
SetPin 11,dout ' CS = D10
SetPin 12,spi1_mosi ' SI = D11
SetPin 13,spi1_miso ' SO = D12
SetPin 14,spi1_sck ' SCLK = D13
SetPin 15,dout ' led = D14
SetPin 23,din
SPI OPEN 1,h,0
Sub spiWriteReg(addr,val)
Local sp
Pin(11)=0
sp=SPI(1,addr)
sp=SPI(1,val)
Pin(11)=1
Function spiReadReg(addr)
Local sp
Pin(11)=0
sp=SPI(1,addr)
spiReadReg=SPI(1,0)
Pin(11)=1
End Function
Sub cc1101_setup()
spiWriteReg(&h30,&h00) 'command SRX
spiWriteReg(&h0b,&h0b) 'FSCTRL1(0x0B)=0x0B
spiWriteReg(&h0C,&h00) 'FSCTRL0(0x0C)=0x00
spiWriteReg(&h0D,&h10) 'FREQ2(0x0D)=0x10
spiWriteReg(&h0E,&h10) 'FREQ1(0x0E)=0xA7
spiWriteReg(&h0F,&h62) 'FREQ2(0x0F)=0x62
spiWriteReg(&h10,&h2D) 'MDMCFG4(0x10)=0x2D
spiWriteReg(&h11,&h3B) 'MDMCFG3(0x11)=0x3B
spiWriteReg(&h12,&h73) 'MDMCFG2(0x12)=0x73
spiWriteReg(&h13,&h22) 'MDMCFG1(0x13)=0x22
spiWriteReg(&h14,&hF8) 'MDMCFG0(0x14)=0xF8
spiWriteReg(&h0A,&h00) 'CHANNR(0x0A)=0x00
spiWriteReg(&h15,&h00) 'DEVIANT(0x15)=0x00
spiWriteReg(&h21,&hB6) 'FREND1(0x21)=0xB6
spiWriteReg(&h22,&h10) 'FREND0(0x22)=0x10
spiWriteReg(&h18,&h18) 'MCSM0(0x18)=0x18
spiWriteReg(&h19,&h1D) 'FOCCFG(0x19)=0x1D
spiWriteReg(&h1A,&h1C) 'BSCFG(0x1A)=0x1C
spiWriteReg(&h1B,&hC7) 'AGCCTRL2(0x1B)=0xC7
spiWriteReg(&h1C,&h00) 'AGCCTRL1(0x1C)=0x00
spiWriteReg(&h1D,&hB2) 'AGCCTRL0(0x1D)=0xB2
spiWriteReg(&h23,&hEA) 'FSCAL3(0x23)=0xEA
spiWriteReg(&h24,&h0A) 'FSCAL2(0x24)=0x0A
spiWriteReg(&h25,&h00) 'FSCAL1(0x25)=0x00
spiWriteReg(&h26,&h11) 'FSCAL0(0x26)=0x11
spiWriteReg(&h29,&h59) 'FTEST(0x29)=0x59
spiWriteReg(&h2C,&h88) 'TEST2(0x2C)=0x88
spiWriteReg(&h2D,&h31) 'TEST1(0x2D)=0x31
spiWriteReg(&h2E,&h0B) 'TEST0(0x2E)=0x0B
spiWriteReg(&h00,&h0B) 'IOCFG2(0x00)=0x0B
spiWriteReg(&h02,&h06) 'IOCFG0(0x00)=0x06
spiWriteReg(&h07,&h04) 'PKTCTRL1(0x07)=0x04
spiWriteReg(&h08,&h05) 'PKTCTRL0(0x08)=0x05
spiWriteReg(&h09,&h00) 'ADDR(0x09)=0x00
spiWriteReg(&h06,&hFF) 'PKTCTRL1(0x06)=0xFF
spiWriteReg(&h31,&h00) 'command SFCTXON
spiWriteReg(&h34,&h00) 'command SRX
Any suggestions ?
Edited by phantomnet 2015-09-28
darthmite
Posted: 01:23pm 27 Sep 2015
Hi
I found this too , but don't forget , it's a alpha version :)
With the code compiled in debug mode this issue appear some times , with full optimization of the code it appear often.
We think to add a low level dma2d interrupt to know when we can start the next writing on screen.
On the background rotating map with Sprites running in front at full optimization it's just too fast for the dma2d , well , i think this project will eat me some night up everything is working ... and i think Uwe night will not be better
Cheers.
PS : you got a nice setup on your st7 Disco Edited by darthmite 2015-09-28
derexponent
Posted: 08:51pm 27 Sep 2015
@phantomnet,
the SPI-Pins dont have to set manualy.
because they hardwired you can't change them anyway
(like the com ports)
so the code for your spi_setup is :
Sub SPI_setup()
' SPI port setup
SetPin 23,din ' user button
SPI OPEN 1,h,0 ' SPI(D11,D12,D13)
and you can use the arduino label names for the pins :
(perhaps i add the user button as 'B0')
Sub SPI_setup()
' SPI port setup
SetPin D8,din ' GDO0 = D08
SetPin D9,din ' GDO2 = D09
SetPin D10,dout ' CS = D10
SetPin D14,dout ' led = D14
and remember, like Fabrice said, its an ALPHA
the finetuning comes in BETA
and its a long way till that day
if you found major bugs let us know
and go on testing
phantomnet
Posted: 06:05am 28 Sep 2015
@derexponent,
Thanks for info.
If you please, add the info about default functions of each pin
and explain what is SPI SCLK frequency in Mhz for L,M,H speeds.
I stil remember that it is an ALPHA so i'm trying to test it as much i can and report bugs
Posted: 03:16am 02 Oct 2015
Fabrice
I'm playing with the sprite editor and can't make sense of the .bin file
I assume the colours are in RGB565?
Reading the file with a hex editor I get:
red= FC00
green=83E0
blue=001F
cyan=83FF
magenta=FC1F
yellow=FFE0
white=FFFF
black=8000
It seems there is an extra bit set in red (bit 10) and also bit15 seems to be set incorrectly in other colours. Is this a bug or am I missing something?
Peter
darthmite
Posted: 09:55am 02 Oct 2015
Hi Math
The new version from the program is making argb1555 pixel format for be used with the
new sprite command integrated in the stmF7mite.
So we don't have to take care on the transparent colour because the dma2d made that
in background.
If some here want a rgb565 output i can add one button for save in this format.
The bit15 is what tell the dma2d that this colour is the transparent one.
Cheers.
darthmite
Posted: 10:46am 02 Oct 2015
I added the Load/Save in RGB565 option.
But i cant attach the file here because the 500kb limitation.
I will give the last version to Uwe Becker and he will put it on his page.
You can load original maximite sprite file 2bit(black/white) and 3bit(8 colours) too.
Now i think the soft must be complete
Cheers.
Here a picture from version 2.2:
Posted: 10:13pm 02 Oct 2015
  Quote  I added the Load/Save in RGB565 option.
Excellent - I look forward to trying it
derexponent
Posted: 01:41am 03 Oct 2015
i have uploaded the new version A.33
and the Sprite-Editor 2.2
new in this version :
command "config" stores settings in external flash
(write limit = 100.000 :-)
8 different speed settings for SPI
(190kHz up to 50MHz -> have a look at the manual)
Fabrice adds a few commands to handle polygons
(demo is also online)
UB.Edited by derexponent 2015-10-04
Posted: 04:01am 03 Oct 2015
Fabrice
the RGB565 save works great except I am struggling with one thing:
I've set the last sprite to 1 in my test as I have two simple images. However, when I save the file and then reload it the number reverts to 499 and looking at the .bin file the first two bytes are F4, 01 =500
If I patch these bytes with the hex editor and then load the file the "last sprite" number is correct and stays correct after a subsequent save and reload.
darthmite
Posted: 06:14am 03 Oct 2015
Ok Math , thanks for this info , i go look that now
darthmite
Posted: 06:31am 03 Oct 2015
Correction done.
Up that Uwe Becker drop it on his page you can use this workaround.
Enter the new Last Sprite THEN press enter
This was a funny one ... he he
You will the see the scrollbar under the sprite resize his cursor , and you will
not able to scroll more than the Last Sprite.(it was supposed to work like this from start).
The new version read the textbox again before it go to save the file for prevent this
to append again.
Cheers.
derexponent
Posted: 09:15am 03 Oct 2015
bugfix is online
picman
Posted: 12:20pm 21 Oct 2015
Is the source code for this project available, or is it another closed source project?
I have designed a new PCB with the stm32f7 which has HDMI and a fpga plus lots of other goodies and need some software, this looks like a good starting point. Better than starting from scratch.
Posted: 12:33pm 21 Oct 2015
They are working under my license which restricts distribution of the source. When they are finished I plan to make the source available (with their permission) in the same manner as the current source to MMBasic is available.
darthmite
Posted: 05:57am 24 Oct 2015
Hi
I finished the mpu6050 lib integration (in c) and put the whole to new
mmbasic command/function.
Uwe is doing the i2c library , soon it will be ready
The "Wii classic controller" lib is done but don't work now ...
I wait up to Uwe finish the i2c lib and try again with this one
For the Joystick it will be new command/function created in mmbasic too ...
And with a very little effort , the Nunchuk can be integrated too , just good that
i have some at home for testing
See you soon for next news.
Cheers.
derexponent
Posted: 03:49am 25 Oct 2015
i2c is running with 10 kHz to 400 kHz
(but only in mode 0 = 8bit Slave-Address)
MPU6050 is implemented but i cant test it
(waiting for Fabrice
i have also added RTC support (PCF8563 or PCF8583)
but still some bugs to fix
CU
     Page 2 of 6
