Local Time 07:48 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: Tuning the clock
Zonker
Posted: 11:56am 20 Sep 2016
Awesome Peter..!
Perfect timing... I wanted to use the timer count as an engine hours meter for the RTC gauge... I put in a MB85RS64 Fram IC on the Rev-B interface PCB to store the timer val as well as service counters, engine start/stops, ect... Without your CAL procedure, setting this up would take way longer..!
BTW, I now have the Rev-B Gauge engine PCB in and test built the first... Works like a champ.. So, I was wondering if you are still wanting another one to play with..? Would be no problem on this end... Will send a built up interface PCB as well...
