Forum Index : Microcontroller and PC projects : Micromite Plus Announcement
| nibbler Newbie Joined: 18/04/2013 Location: CanadaPosts: 11 |
CircuitGizmos, on my Skinnymite SPI IN is marked pin 45 and it also connects to pin 45 on the PIC32. Alan |
| boss Senior Member Joined: 19/08/2011 Location: CanadaPosts: 268 |
Sounds good. Really impressive upgrade.
@Geoff I have just two remarks: 1) PS2 keyboard is hard to find a new condition in these days. I know that PS2 protocol is simple, but what about to ad USB HID and connect data to serial. 2) If graphical support (based on SSD1963 resolution up to 800x480) will be embedded then USB mouse (connected the same way like keyboard)is highly desired as well. Of course some HW would necessary to add Btw why not use 100pin chip instead 64pin? Regards Bo |
Have you run out of I/O pins already?? |
Alan: There are definite differences between the Matherp list and the pin list for Geoff's Micromite plus. They are not the same. Pin 1-PortE5:ANALOG_IN22 | DIGITAL_IN | DIGITAL_OUT | SPI2IN* Pin 2-PortE6 ANALOG_IN23 | DIGITAL_IN | DIGITAL_OUT Pin 3-PortE7 ANALOG_IN27 | DIGITAL_IN | DIGITAL_OUT Pin 4-PortG6 ANALOG_IN16 | DIGITAL_IN | DIGITAL_OUT | SPI2CLK* Pin 5-PortG7 ANALOG_IN17 | DIGITAL_IN | DIGITAL_OUT | SPI2OUT* Pin 6-PortG8 Console RX Pin 7-RESET/MCLR | 5V Pin 8-PortG9 ANALOG_IN19 | DIGITAL_IN | DIGITAL_OUT |SPIOUT Pin 9-GROUND Pin 10-POWER (+2.3 to +3.6V) Pin 11-PortB5 ANALOG_IN5 | DIGITAL_IN | DIGITAL_OUT Pin 12-PortB4 ANALOG_IN4 | DIGITAL_IN | DIGITAL_OUT Pin 13-PortB3 ANALOG_IN3 | DIGITAL_IN | DIGITAL_OUT Pin 14-PortB2 ANALOG_IN2 | DIGITAL_IN | DIGITAL_OUT Pin 15-PortB1 ANALOG_IN1 | DIGITAL_IN | DIGITAL_OUT | PGC Pin 16-PortB0 ANALOG_IN0 | DIGITAL_IN | DIGITAL_OUT | PGD Pin 17-PortB6 ANALOG_IN6 | DIGITAL_IN | DIGITAL_OUT Pin 18-PortB7 ANALOG_IN7 | DIGITAL_IN | DIGITAL_OUT Pin 19-ANALOG REFERENCE Pin 20-ANALOG GROUND Pin 21-PortB8 ANALOG_IN8 | DIGITAL_IN | DIGITAL_OUT Pin 22-PortB9 ANALOG_IN9 | DIGITAL_IN | DIGITAL_OUT Pin 23-PortB10 ANALOG_IN10 | DIGITAL_IN | DIGITAL_OUT | COUNT Pin 24-PortB11 ANALOG_IN11 | DIGITAL_IN | DIGITAL_OUT Pin 25-GROUND Pin 26-POWER (+2.3 to +3.6V) Pin 27-PortB12 ANALOG_IN12 | DIGITAL_IN | DIGITAL_OUT Pin 28-PortB13 ANALOG_IN13 | DIGITAL_IN | DIGITAL_OUT Pin 29-PortB14 ANALOG_IN14 | DIGITAL_IN | DIGITAL_OUT | Comm1 Enable Pin 30-PortB15 ANALOG_IN15 | DIGITAL_IN | DIGITAL_OUT Pin 31-PortF4 DIGITAL_IN | DIGITAL_OUT | 5V | Comm1 RX Pin 32-PortF5 DIGITAL_IN | DIGITAL_OUT | 5V | Comm1 TX Pin 33-PortF3 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V Pin 34-UNUSED | VBUS | 5V Pin 35-POWER (+2.3 to +3.6V) | USSB3V3 Pin 36-UNUSED | USBD- Pin 37-UNUSED | USBD+ Pin 38-POWER (+2.3 to +3.6V) Pin 39-PortC12 DIGITAL_IN | INTERRUPT | DIGITAL_OUT Pin 40-PortC15 DIGITAL_IN | INTERRUPT | DIGITAL_OUT Pin 41-GROUND Pin 42-PortD8 DIGITAL_IN | DIGITAL_OUT | 5V | PWM1B Pin 43-PortD9 DIGITAL_IN | DIGITAL_OUT | 5V | I2CSDA Pin 44-PortD10 DIGITAL_IN | DIGITAL_OUT | 5V | I2CSCL Pin 45-PortD11 DIGITAL_IN | DIGITAL_OUT | 5V | SPIIN Pin 46-PortD0 DIGITAL_IN | DIGITAL_OUT | 5V | COUNT | WAKEUP/IR Pin 47-PortC13 DIGITAL_IN | DIGITAL_OUT | PWM2B Pin 48-PortC14 DIGITAL_IN | DIGITAL_OUT | PWM1A Pin 49-PortD1 ANALOG_IN24 | DIGITAL_IN | DIGITAL_OUT | COUNT Pin 50-PortD2 ANALOG_IN25 | DIGITAL_IN | DIGITAL_OUT | SPICLK Pin 51-PortD3 ANALOG_IN26 | DIGITAL_IN | DIGITAL_OUT | COUNT Pin 52-PortD4 DIGITAL_IN | DIGITAL_OUT | 5V | COUNT Pin 53-PortD5 DIGITAL_IN | DIGITAL_OUT | 5V | PWM2A Pin 54-PortD6 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V Pin 55-PortD7 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V Pin 56-VCAP:47uF TANT CAPACITOR, 10|47uF Multilayer ceramic Pin 57-POWER (+2.3 to +3.6V) Pin 58-Console TX Pin 59-PortF1 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V Pin 60-PortE0 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V Pin 61-PortE1 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V | Comm2 RX Pin 62-PortE2 ANALOG_IN20 | DIGITAL_IN | DIGITAL_OUT | Comm2 TX Pin 63-PortE3 DIGITAL_IN | INTERRUPT | DIGITAL_OUT | 5V | PWM1C Pin 64-PortE4 ANALOG_IN21 | INTERRUPT | DIGITAL_IN | DIGITAL_OUT 1 LCD D5 2 LCD D6 3 LCD D7 4 SPI 2 CLOCK 5 SPI 2 OUT (MOSI) 6 CONSOLE Rx (IN) | COM4: Rx 7 RESET Normally 10KΩ to V+ 8 SPI 1 OUT (MOSI) | INT 9 GROUND 10 POWER (+2.3 to +3.6V) 11 COM2: Tx | INT 12 INT 13 COM2: Rx 14 INT 15 INT 16 COM3: Tx | INT 17 COM3: Rx | INT 18 INT 19 ANALOG POWER (+2.3 to +3.6V) 20 ANALOG GROUND 21 INT 22 LCD CS | INT 23 COUNT | INT 24 LCD WR | INT 25 GROUND 26 POWER (+2.3 to +3.6V) 27 LCD RS (data/command) | INT 28 LCD RESET | INT 29 COM1: ENABLE | INT 30 INT 31 I2C2 DATA | INT 32 I2C2 CLOCK | INT 33 INT | DIGITAL INPUT ONLY 34 USB +5V 35 POWER (+2.3 to +3.6V) 36 USB D- 37 USB D+ 38 POWER (+2.3 to +3.6V) 39 20MHz CRYSTAL) 40 20MHz CRYSTAL) 41 GROUND 42 PWM 1B 43 I2C DATA 44 I2C CLOCK 45 COM1: Tx 46 COUNT | WAKEUP | IR 47 SPI 2 IN (MISO) | PWM 2B 48 PWM 1A 49 COUNT 50 SPI 1 CLOCK 51 COUNT 52 COUNT 53 PWM 2A 54 INT | KEYBOARD CLOCK 55 INT | KEYBOARD DATA 56 47µF TANT CAPACITOR (+) 57 POWER (+2.3 to +3.6V) 58 COM4: Tx | CONSOLE Tx (OUT) 59 COM1: Rx 60 LCD D0 61 LCD D1 62 LCD D2 63 PWM 1C | LCD D3 64 LCD D4 Micromites and Maximites! - Beginning Maximite |
Well, indeed.
That massive PCB I designed for my security system that used all three of Geoff's projects - the Colour Maximite, the Micromite and the VT100 - is now in serious jeopardy, as the new beast integrates so much of what I was doing, into the one unit, that I am looking very seriously at doing a complete re-design of this board to use the new MM+ and be done with it. I only got five prototype boards of that huge 3-in-1 design, so none are actually in service yet, as I was still prototyping.
Perhaps it can go into the Rictech museum! Smoke makes things work. When the smoke gets out, it stops! |
SPI IN (MISO) for channel 1 is on pin 45. I need to update the documentation. Something has gone wrong with the pin allocations related to COM1: as Tx should not be on pin 45. So (for the moment) COM1: is not working. It should be an easy fix and I will have a go at it over the next couple of days. That is correct, you must use the MM+ documentation. If you are asking for USB keyboard support, that is in my long terms plans for the MM+. The 64-pin chip was used on the Explore 64 board because of space constraints. Grogster and/or myself are planning a PCB that will plug onto the back of a 5" SSD1963 display and that will probably use the 100-pin chip (might even call it the Explore 100). Geoff Geoff Graham - http://geoffg.net |
Thanks. I have a board put together with the Mather version of the I/O. I'll need to wait to use this "Plus" version until the pin-out is solid. Micromites and Maximites! - Beginning Maximite |
| geraldfryjr Regular Member Joined: 02/03/2014 Location: United StatesPosts: 61 |
Thanks Geoffg !!! I ordered some 64 and 100 pin types today just in case!!
jer Keep on DIYin' !!! |
| ztoti Regular Member Joined: 27/10/2011 Location: CanadaPosts: 65 |
Simple speechless. Thank you Geoff for your hard work. |
@Geoff That is really great news, with 100pin version you can dedicate ~20pin for TFT display, add a SD card and reserve two serial ports for Keyboard/Mouse and still have plenty of pin remaining for application. Anyone needs more peripherals? Bo |
Thanks Geoff This makes a Micromite into MAXIMUM-MITE Regards Jman |
| retepsnikrep Senior Member Joined: 31/12/2007 Location: United KingdomPosts: 134 |
This is great project and extension of the huge range of MAXI stuff. Can I make a plea about casing the unit with displays especially the bigger 4.3/7" units. I've seen so many projects (including my own) let down by terrible cases and hacked about project boxes. Do we have any ideas on a case for the display/rear mounted pic unit combined? 3d printed perhaps? Gen1 Honda Insights. |
A question: on a first look it seems that the internal RTC is not supported. Have I missed it or that's the case? It would be good to have it I think (I can assist with that if necessary). Would it be too hard to include? http://rittle.org -------------- |
3d printed perhaps? I am considering designing a sheet-metal case that is laser-cut then powder-coated. This may be more exotic then people want, but I am thinking about it - a friend of mine used this to make some server cases, and they came out beautifully, and they weren't that expensive to have laser cut and folded. Smoke makes things work. When the smoke gets out, it stops! |
No, the internal RTC is not used. The internal clock is managed by MMBasic using its millisecond interrupt. I thought about using the RTC but it is not as simple as it seems. The MM+ uses a crystal therefore the current clock is quite accurate while the MM+ is powered. So the RTC is only useful when power is removed. But the PIC32 does not have a separate power input for the RTC so the whole chip must be powered to keep it running. This means that Vdd must be switched to a battery and the chip put to sleep. But this in turn has a pile of issues. The switching circuit is one, detecting when the power has failed is another and minimising the sleep current is difficult, if not impossible, when there are devices connected to the I/O pins. It is much simpler to use a cheap $3 external RTC that can be queried for the time on power up. Geoff Geoff Graham - http://geoffg.net |
3d printed is slow and expensive if you want a case that can last some time. I have 3d printers and i only use them for prototyping, less and less so because it causes you to design with the capabilities of a 3d printer and not for processes or machines that can be used for quantities (even for small amounts). Seen too many examples of people going completely crazy when they have to make a few, 3d printing scales terribly and quality is pretty low if you want it to be affordable. At the makerspace people come for the 3d printer,they stay for the laser cutter and cnc. HIPS would be an ok material.Vacuum forms great, and can be get in many colors. Otherwise cnc is a good option. Microblocks. Build with logic. |
.......... Geoff Makes complete sense. Thanks! PS. Something for fixing in the documentation: in the 64-pin devices pin 15 is clock, and pin 16 is data for firmware programming (PGEC1 and PGED1 respectively) http://rittle.org -------------- |
Does that also mean that Microchips Harmony library is tackled? :) Microblocks. Build with logic. |
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
what a fantastic work ! I have a dream and Geoff do it ! thank you Pierre I need a PCB for a 100 pins PIC : is it already available ? 73s de F1FCO |
| shoebuckle Senior Member Joined: 21/01/2012 Location: AustraliaPosts: 189 |
@Geoffg. Geoff, sounds like a great project for a series of articles in Silicon Chip, especially if integrated with a small screen, keyboard and external RTC. Hugh |
