WhiteWizzard Guru Joined: 05/04/2013 Location: United KingdomPosts: 2994
Posted: 12:37am 08 May 2015
Ensure you have the latest FTDI driver installed but more importantly, you must use a GENUINE FTDI chip (not a cheap clone). If not genuine then you will not get it working (just search FTDI driver issues to see what I mean - they prevented fake FTDIs from working when using the latest driver).
Enjoy taking out all you frustrations while playing GTA
WW
CarlRanson Newbie Joined: 08/05/2015 Location: New ZealandPosts: 30
Posted: 12:35am 10 May 2015
ok, so some good progress here.
I've got one of the units presenting correctly as a com port and I am able to connect to it with teraterm.
The first one I did doesn't yet show up as a proper usb device. It might be that I've killed it by having the caps reversed initially. I know at one point the pic got fairly warm.
Does all the usb device presentation stuff happen from the FTDI chip only or are both involved?
thanks again for your help to date.
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10075
Posted: 12:40am 10 May 2015
The USB interface is entirely inside the FTDI chip, and establishing the USB connection is between the PC and the FTDI chip. The MM talks to the FTDI chip with a standard serial port connection between the two. The MM has no bearing on the operation or detection of the device, as far as the USB connection to the computer is concerned.Smoke makes things work. When the smoke gets out, it stops!
Posted: 08:15am 10 May 2015
@CarlRanson
As Grogster has already mentioned, the FTDI is simply the interface between the MM and a USB port. The MM uses a simple serial Rx and Tx interface to communicate with a console device so the MM signals need converting to the USB protocol when connected to most modern computers.
None of the MMBasic functionality originates from within the FTDI chip.
The module you have where the PIC got 'fairly warm' is not necessarily destroyed. The PICs are surprisingly robust but don't spend too long resolving this yet. Simply get one module working as you need it and get to 'know it better'.
The two 'weak' points of the circuit are the two chips. Out of the two, I would say the FTDI is more 'sensitive' so hence more likely to be where the issue is. When you're ready we can diagnose your issue.
