Local Time 20:20 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : http://garden.geoffg.net/
centrex
Posted: 04:25pm 08 Dec 2014
Hi Oldbit
If you read the article and run the program mentioned http://garden.geoffg.net you will see a pointer to the code that was used.
regards
cliff
Cliff
Oldbitcollector
Posted: 04:38pm 08 Dec 2014
<face palms>
The only place that made sense to look... I failed to see..
I guess I was distracted by all the other data displayed...
..I swear there wasn't a code link the other day when I first tried the site.. really.
Thanks.
Edited by Oldbitcollector 2014-12-10
My Propeller/Micromite mini-computer project.
Posted: 05:08pm 08 Dec 2014
At least Geoff did mention 'MicroMite' on 5 pages out of the 6 page article - I guess he can't be too 'pushy' about the MicroMite with the article title used.
Anyway - its a great article, and assuming you have the latest ESP firmware, it is a fantastic help to get things started with the cheap WiFi module.
WW
Edited by WhiteWizzard 2014-12-10
crez
Posted: 07:54pm 24 Dec 2014
I took a while to get things working so I thought I could save someone some time if I posted some info.
I downloaded the program Jman posted a link to on this thread on the 4th December and had to make a few changes to make it work:
change the baud rate from 115200 to 9600:
Open "COM1:9600, 1024" As #1
change the expected response to the AT+RST command:
SendCmd "AT+RST", "OK"
These changes are only required due to differences in the firmware of my ESP8266 module.
David
Phil23
Posted: 01:14am 02 May 2016
After dragging the old issue of Silicon Chip where Geoff was discussing the ESP8266 to the..... this morning I decided to have a look at garden.geoff.net, & sort of expected it to be off-line as it now is.
Still interested on what might be the current approach.
Am currently viewing my projects remotely in a Terminal app(VT100) via ESP link, but a much more appealing option would be to be able to see all my "projects" online via something like a simple layout on a page at "http://heating.philsstuff.com.au".
Phil.
