Local Time 21:52 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Talking to FRAM chips with I2C....
     Page 2 of 4
jman
Posted: 10:44pm 30 Sep 2014
Hi
Thanks to Grogster I got some Fram chips today
The real simple code below proves they work just fine
I2C open 400, 100
test=197
I2C Write &H50,0,3,&H0,&H0,Test
Print MM.I2C ' Should be 0 if all is good
I2C Write &h50,0,2,&H0,&H0
I2C Read &H50,0,1,Rtest
I2C Close
Print Rtest
Jman
BobDevries
Posted: 04:21pm 01 Oct 2014
@Grogster...
Unless I'm missing something, you're using a \ instead of / in your code. Maybe a typo?
Regards, Bob Devries
Bob Devries
Dalby, QLD, Australia
Posted: 04:37pm 01 Oct 2014
You're missing something.
I did the divide thing myself as a mistake at the start of my tinkering, IE: A/256, when it needs to be A\256.
A\256 is integer divide. This was pointed out to me by other forum members.(TassyJim and G8JCF)Edited by Grogster 2014-10-03
BobDevries
Posted: 05:11pm 01 Oct 2014
Thanks, Grogster.
Now that you mention it, I do vaguely recollect a mention of that.
Bob Devries
Posted: 05:30pm 01 Oct 2014
The integer divide is a bit faster than INT(divide).
a = 1000
timer = 0
for n = 1 to 10000
b = a\256
next n
print timer
timer = 0
for n = 1 to 10000
b = int(a/256)
next n
print timer
> RUN
1310
1507
Posted: 10:14pm 01 Oct 2014
...so sounds like the one to use then.
Posted: 10:23pm 01 Oct 2014
Hi Grogs,
Two questions:
1> Which exact 256-FRAM did you end up using? (just curious as to what other functions it may have (RTC?))
2> Have you been able to do 'sequential' writes yet? i.e. set address once, then send bytes one after the other without addressing them (FRAM has auto address increment).
Regarding the second point, sequential reads are easy whereby you just need to send I2C READ (one byte), but for writing you need to send 3-bytes (Address MSB, Address LSB, DATA).
Could it be an MMBasic I2C issue do you think? How can we test this?
WW
jman
Posted: 10:33pm 01 Oct 2014
Hi
Tried the Fram with my Nokia LCD data and it seems to work ok
This the code I used to read the Fram hope it helps
I2CADDr = &H50
GoSub Codes
Print CData; " Codes Read"
End
Codes: 'Rem READ From Fram
I2C Open 400,100 'ENABLE I2C
I2C Write I2CADDR, 0,2,&H7F,&HFE 'Array size location
I2C Read I2CADDR, 0,1,C 'Read remainder of blocks from EE
I2C Read I2CADDR, 0,1,D 'Read number of blocks from EE
CData=(D*256)+C 'Array size Blocks*256 + remainder
Dim GCodes(504) 'Temporary Array for Graphics
Dim Codes(CData-504) 'Dimension array
L=0:K=0 'To Ensure we start at 0
BC=&HFF 'Complete Block
For J=0 To D 'Number of complete blocks
If J=D Then BC=(CData-(D*256)) 'Check for end of array
For I=0 To BC
I2C Write I2CADDR, 0,2,J,I
If L > Cdata-504 Then
I2C Read I2CADDR, 0,1,GCodes(K)
K=K+1
Else
I2C Read I2CADDR, 0,1,Codes(L)
L=L+1 'Increment counter
Next I : Next J
I2C Close
Return
I have attached the Write code as it is a little long with all the data statements
2014-10-02_083059_WriteFram.zip
Jman
Posted: 10:40pm 01 Oct 2014
@ WW - Sequential reads are easy - no problems. Sequential writes are impossible - no matter what I try, it fails - same as you. I can successfully sequentially write, only by issuing the address with each data byte - as did you. Would love to know how we could test this further.....
As to the actual part number, it is a Ramtron FM24W256.
jman
Posted: 11:04pm 01 Oct 2014
  Grogster said   Sequential writes are impossible
To quote the data sheet " All writes begin with a slave address then a memory address"
This normal for EEprom's not just the Fram
You need to specify the memory address with every write.
You can write more than byte at a time ie
i2c write slave address, 5, 0, 0, byte1, byte2, byte3
This will write bytes1 - byte3 sequentially to location 0,1,2
If you want to write one byte at a time then you need
i2c write slave address, 3, 0, 0, byte
This what I use to sequentially write to EEprom / Fram
2CADDR=&H50 'Address of Fram
BC=&HFF 'Complete block
For J=&h0 To S 'Number of blocks to write
If J=S Then BC = CData-(S*256) 'Full block or remainder
For I=&h0 To BC
I2C Write I2CADDR, 0,3,J,I,Codes(Cnt) 'Write to EE
Cnt = cnt + 1 'Increment array counter
Next i: Next j
I2C Write I2CADDR, 0,4,&H7F,&HFE,BC,S 'Write item count to EE
I2C Close
Jman
centrex
Posted: 11:46pm 01 Oct 2014
Has anybody looked at how it is done with the Arduino, I am waiting for a fram from Adafruit.
They have a sample file in their library, I know they have things like the .h files but it could give a clue.
Keep up the good work.
Cliff
Cliff
Posted: 11:55am 02 Oct 2014
@ jman - if you look back in this thread, you will see that we've tried to write multipule bytes at a time, but it is not working. Individual bytes as you are showing them will work, but sending a string won't.
It is very possible I am still doing something wrong, but if you look back, you will see that the likes of writing a string, which the manual says you should be able to do in a single write, fails every time - MMBASIC complains.
I have a feeling it is because MMBASIC's I2C write only supports writing strings for byte-addressed memory. As soon as you add the extra address byte for word-addressed memory, MMBASIC falls over.
Have a look at page 59 of the uM manual. Last example for writing a string is I2C WRITE &H6F, 1, 3, STRING$ - this probably works.
However, with word addressing, there is an extra byte in the command, and this seems to be throwing MMBASIC out: I2C WRITE &H6F, 1, 5, 0, 1,STRING$ - throws an error if you try to specify the write address before the string.
I guess you could always add the address bytes to the string - someone else here suggested that earlier, but I thought there MUST be a way to do it other then that. Once you start adding address bytes to the start of the string, it is bound to confuse anyone trying to read you code, however - I suppose that is where a commented line of code would be a good thing......
I will try that as an experiment later today.(add MSB and LSB to a string, then add D$ to the end of that, and send that using the first example from the manual.)
Posted: 12:23pm 02 Oct 2014
OK, progress - jman WAS right, I was just interpreting the syntax for writing strings wrong.
Here is the SEQUENTIAL WRITING test routine:
[code]
FW2:
D$="Hello there, backshed people.":A=15000
MSB=A\256:LSB=A Mod 256
D2$=Chr$(MSB) + Chr$(LSB) + D$ + Chr$(13) 'Build address + string
I2C open 400,100
I2C write &B1010000,0,Len(D2$),D2$ 'Write address + string
I2C write &B1010000,0,2,MSB,LSB 'Reset start address
I2C read &B1010000,1,1,B
D3$=D3$+Chr$(B)
If B=13 Then Exit Do
Print D3$
End
[/code]
Posted: 12:43pm 02 Oct 2014
@Grogster,
This is what we had before and not what I would call sequential writing (you're just adding two address bytes to the data string, but still writing it in one line of code).
If you refer back to my first example, there I was writing a string into memory after first writing the one address byte (for my FRAM only requiring one byte for address byte - yours needs two). All this was in one line of code.
I am saying that sequential writing is to write the start address in one line of code, and then use multiple lines just writing the data byte(s) without specifying an address (as the FRAM will auto increment the address for each byte written; with roll-over when reaching last address location).
I am still trying various things here but no joy whatsoever (yet!)
WW
EDIT: SORRY GROGSTER - just re-read the thread - I didn't post my code that I thought I did! I have it in my notes here though!
Anyway, the above still stands in my definition of sequential writing.
Edited by WhiteWizzard 2014-10-03
Posted: 01:20pm 02 Oct 2014
Hi WW. I will play with that idea now. One would THINK that if you held onto the bus after the first write, you should be able to do it again......
My latest routine is:
[code]
FW2:
D1$="Hello there, backshed people.":A=15000
D2$=D1$ + D1$ + D1$ + D1$ + D1$ + D1$ + D1$ + D1$ 'Build large string
D3$=Chr$(MSB) + Chr$(LSB) + D2$ + Chr$(13) 'Build address + string
I2C open 400,100:Timer=0
I2C write &B1010000,0,Len(D3$),D3$ 'Write address + string
T1=Timer:Timer=0
D4$=D4$+Chr$(B)
T2=Timer
Print D4$
Print "Data length: ";Len(d4$)
Print "Write time : ";T1;"ms"
Print "Read time : ";T2;"ms"
End
[/code]
This builds a nice big(and useless!) text message, then writes it in one operation to the FRAM. Averages 6ms write time, which is excellent, and I never need to worry about page boundries - yay!
Posted: 01:44pm 02 Oct 2014
Yeah, WW - I can't make it work for me either.
[code]
FW3:
D1$="Hello WhiteWizzard!":A=10000
X1$="Tra-la-la...":D3$=""
D2$=Chr$(A\256) + Chr$(A Mod 256) + D1$
I2C open 400,100
I2C write &B1010000,1,Len(D2$),D2$
I2C write &B1010000,1,Len(X1$),X1$
I2C write &B1010000,1,1,13
I2C write &B1010000,0,2,A\256,A Mod 256
LAST=Len(D1$) + Len(X1$) + 1
For X=1 To LAST
D3$=D3$ + Chr$(B)
If B=13 Then Exit For
Next
Print D3$
End
[/code]
I have replaced the read DO/LOOP with a FOR/NEXT, as I kept getting string length errors. First write works, the next ones don't WITHOUT addressing byte(s).
palcal
Posted: 08:17pm 02 Oct 2014
I have a use in mind for these chips, they seem to be a bit of a problem to read and write to. When we have the 170 chip is this something that Geoff could conjure up a read and write command for or are there too many variables for it to be generic.
Paul
Posted: 08:54pm 02 Oct 2014
They are not a problem really. It just requires a little time to work it all out, then once we have a working routine, I will probably submit it to the library.(with credits to all other members who chimed in with ideas)
Reading is no problem - I have done some tests reading the entire memory inside a loop. That is no issue. The issue is continuous sequential writing, and this is only really an issue, if you CAN'T contain all you want to write at any one time, within the 256 byte limit of MMBASIC strings.
IE: Assuming that you can get all you want into a string, and it is less then 256 bytes in length(including address bytes), then there is no problem at all.
WW and me are trying to work out why you can't write heaps to the device once you have opened it and sent the initial address - more for academic reasons, then reasons of practical application.(I think! I hope!)
Posted: 09:23pm 02 Oct 2014
@palcal, Just re-enforcing what Grogster has just posted.
There isn't really a need for incorporating any 'FRAM' commands into MMBasic (unless there are surplus 'command indexes' for Geoff to play with then it would be a nice inclusion).
The sequential write is something I see useful; however, what Grogs & I have both confirmed working so far is more than usable for using these brilliant devices.
I have mentioned & recommended FRAM's before in several posts; but now thanks to Grogster, we are now starting to share how to incorporate them.
Posted: 09:26pm 02 Oct 2014
The first 2 bytes sent to the FRAM as a 'write' are assumed by the FRAM to be address bytes.
If you don't keep track of the address yourself, and send it at the start each time, strange things will happen.
Fortunately, keeping track of the address pointer is easy to do.
I have some FRAM chips on the way but I don't expect them too soon.
     Page 2 of 4
